Question about Ricoh Aficio 450 Copier
Ok WHile I waited for the reset directions I took the fuser and roller assemblies off the 2035 I had and put them on this 2045. Still had the error. So I put them back on the 2035. Put the originals back on the 2045. Did the reset of the code. printer is happy execept when it prints it only spits blank pages. No errors nothing. Did I put something together wrong?
    President:
  • Ricoh Master
  • 990 Answers
Hello sir; I don't know what's the problem of the machine, anyway I can give you reset procedure; Press "clear/mode" "107" and press and hold "clear/stop" key for 3 sec.until screen change, then turn off the power and back on again.
Posted on Nov 14, 2009
C546
change the fusing unit completely and put on the machine.
if the error appears again, enter the sp mode by
1,press the yellow key say three times and enter keys 107
2,press and hold the stop/clear key for say 5 seconds .the machine will take you into the sp mode.
3,put of the machine for about aminute and put it on again .
I believe when you follow this step well ,thie problem will be solved
GOOD LUCK.
Jun 11, 2014 | Ricoh Aficio 2045e 2035e Copier...
Error code H5-01 and the coppier doesn't start
H5-1 means, the copier jammed more than 2 times at the fuser unit. Check the unit if any the fingers are ok, check if the fuser gear is ok. Inspect if fuser rollers condition. Once you figuer out the problem, you need to reset the error code. The procedure of resetting error codes depends on the model.
Dec 06, 2013 | Sharp Office Equipment & Supplies
Kyocera km 2035 has error c-6
The error codes for Kyocera Mita are usually in this format: X-XXXX.
I am assuming the error is C-6XXX so i'm going out on a limb to say it is a fuser error. Check the power source for your copier. Make sure you have a good earth ground. Reset the fuser error. If it does not reset then replace the fuser.
Dec 03, 2013 | Kyocera Office Equipment & Supplies
C3202 error
C 3201;C 3202 Fusing motor malfunction.Remove the fusing unit and inspect the upper and lower fuser roller and the drive mechanism gears.If is OK reset the error.To reset turn OFF the copier.Press and keep pressed the Uility key and turn ON the copier.Keep pressed the Utility key and wait to displayed Trouble Reset message.Release the key and touch the message then turn OFF the copier.Wait 1 minutes and turn ON.
Apr 03, 2013 | Konica Minolta Office Equipment & Supplies
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
I have copier ir 400s sir i am getting error when i started the machine the error is E014 thank you
This is an indication that the fuser ( hot rollers on left side of copier ) are not turning. This could be caused by several things. Try turning the green knob behind front door. Does it move smoothly? If it doesn't then remove the left side fuser door and remove the fuser assembly. The bearings for the upper and lower rollers could be bad. If the fuser moves easily, then it could be a white gear that is located on the upper right of the fuser assembly. This is the drive gear for the fuser. The gear tends to wear out over time and has to be replaced. This should get you in the right direction to solve the problem.
Mar 28, 2011 | Canon imageRUNNER 400S Copier
LANIER 5637 FAULT CODE SC542 UPON POWER UP
You have a Fuser Temperature warm-up error, Hot roller warm-up error.
Verify the heater lamps, thermistor and thermofuse continuity.
Enter in the SP mode, turn OFF the main switch, unplug the machine, wait 10 seconds,
plug in and turn ON the copier.
If you need to reset the fuser,
Enter SP 5-810 (SC code reset) and
select "1". Then simultaneously press the Original Type key and the OK (or
R/#) key. (There is no need to turn the main switch off and on.).
Jan 22, 2011 | Lanier Office Equipment & Supplies
Sc 990 ERROR PROBLEM ON RICOH 2045/2035. how can i solve this problem..
replace drum, drum cleaning blade,charge roller. this will sort Sc 990
Sep 14, 2010 | Ricoh Office Equipment & Supplies
What is error code SC548 on RICOH Aficio 2035/2045 machine. Functional problem within the copier. How do i reset the copier to operate normal?
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Jul 19, 2010 | Ricoh Aficio 2035 Copier
My magicolor 2530 DL
Hi Condeleeza,
Normally smoke would be caused by label residue being left on the fuser rollers, I am assuming your use of the word label is correct and not a transparency (which is a common jamming source in laser printers) especially when someone mistakenly puts a inkjet transparency through a laser printer or mistakenly puts a clear plastic divider sheet through.
If you are sure all of the original label has come out and there is was no residue left directly on the fuser rollers, and the fact you now have smoke and an error code (which I do not have access to find service codes for Minolta), I suspect the fuser assembly is overheating now which is causing the error message (after probably 10 seconds after switch on from cold). This could mean the temperature sensor monitoring the fuser temp is either not touching the fuser due to label fragment lifting sensor off fuser roller surface or sensor is bent or damaged due to label revolving aorund or subsequent removal efforts.
Take a closer look and see if you can find a stray fragment stuck to a thermocouple sensor wiping against the fuser roller. Failing this then you probably need to send into service and ask for a quote to repair. Be aware that the fuser may have become scratched or otherwise damaged depending upon your label removal techniques....over zealous use of letter openers, nail files and small screwdrivers have destroyed many a good fuser assembly.
Good luck
Kiwi-Mark
Jan 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Ricoh Aficio 450 Copier Logo
247 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
