Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
My Macbook Pro (Intel) will no eject the CD. Finder and disc manager don't show it, holding down the track button whilst rebooting doesn't work, there is not a little hole to push paper clip into. Is there a MacBook expert out there?
    Master:
  • Apple Master
  • 956 Answers
Device manager/drives/ check to see if prog is loaded/if yes/disable/reload/restart sys.
Posted on Nov 13, 2009
    Problem Solver:
  • 12 Answers
Isnt there an icon on the desktop of a disk,if so just right click it so the tab comes up and click eject.
2 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: My Macbook Pro (Intel) will no eject the CD.
1. Restart the computer. If necessary, use the reset/interrupt button.
2. Immediately after the system startup tone, press and hold the Command-Option-O-F key combination. The computer starts up to a text-only screen, indicating that you are in Open Firmware.
3. At the prompt, type: eject cd
4. Press Return.
5. Type: mac-boot
6. Press Return
Posted on Sep 25, 2009
How do you force eject a disc from a macbook pro?
Five ways to eject a stuck CD or DVD from the optical drive
Ejecting the stuck disc can usually be done in one of the following ways:
1. Restart the computer and after the chime press and hold down the left mouse button until the disc ejects.
2. Press the Eject button on your keyboard.
3. Click on the Eject button in the menubar.
4. Press COMMAND-E.
5. If none of the above work try this: Open the Terminal application in your Utilities folder. At the prompt enter or paste the following:
/usr/bin/drutil eject
If this fails then try this:
Boot the computer into Single-user Mode. At the prompt enter the same command as used above. To restart the computer enter "reboot" at the prompt without quotes.
Regards,
Alex
Aug 14, 2014 | Apple MacBook Pro Laptop Computer with...
A dvd has become stuck in my macbook and when i reboot, the screen remains blank and will not start up
If it is physically stuck, you will need to take it in for service.
If you just need to eject it, hold down the eject button or the trackpad button as you power on and continue to hold it down until the disc ejects.
Dec 29, 2010 | Apple MacBook Pro Laptop Computer with...
I have macpro 13inc.my problem is my disc is not working with the eject is not function.so still my dish is inside of my disc unit how can i remove manually pls. give me instruction properly thanks lot...
Thanks for contacting Fixya Support.
With the Macbook Pro 13" having a Superdrive or Combo optical drive, you are dealing with a slot-loaded drive. As a result, if you have a disc that is loaded into your optical drive, which will not eject, then there isn't a manual way to remove the disc without causing damage to either the optical drive or the disc itself.
In most cases, of a potentially stuck disc in a Apple notebook's optical drive, a visit to your local Apple Retail Store Genius Bar or local Apple-authorized service center would be highly recommended.
With that noted however, here are some troubleshooting steps to try from the Mac OS X side first before having to take that step and visit an Apple service provider:
- CD DVD EJECT -
- - Reboot your Macbook Pro 13"
- - Hold down your Media Eject key on your keyboard pad prior to the Apple Chime starting.
- - Keep holding the Media Eject key down while your Macbook Pro 13" boots up
- - The disc should eject before you reach your Desktop
- - When it does, simply release your Media Eject key.
If that does not work, try this:
-EJECTING DISC USING TERMINAL-
From your Desktop:
* Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
* From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
* Locate and open the Terminal application.
* At prompt, type: drutil eject and press the Return key on your keyboard
This command line should eject the disc from the drive, unless there are mechanical issues with the drive.
If neither of these steps work, then I would be remiss as an Apple Certified Tech, if I did not recommend you proceed to take your Macbook Pro 13" in for service.
I hope this helps.
Best Regards,
-Mactechtrainer
Aug 26, 2010 | Apple MacBook Pro Notebook
I can't eject a dvd from my mac pro desktop
Try these tips.....usually holding down the touchpad buttton while tapping the eject button during bootup works.
picexporterror Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
picexporterror If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
picexporterror Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
picexporterror Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
picexporterror Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
picexporterror Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
picexporterror Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
picexporterror If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Oct 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Hi- I've just inserted a CD into my MacBook Pro
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Oct 13, 2009 | Apple MacBook Pro Laptop Computer with...
My cd is stuck in macbook and is not being read by my computer it only makes a funny sound when i reload it
A CD or DVD disc can become stuck in your Macintosh. It may not be appearing on your desktop or could be causing the computer to lock up if the computer cannot recognize it properly.
[edit] Solutions
  • First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu.
  • If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X.
  • Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
  • If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
  • Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
  • Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
  • Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
  • Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
  • Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
  • If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Sep 30, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
My Macbook Pro (Intel) will no eject the CD. Finder and disc manager don't show it, holding down the track button whilst rebooting doesn't work, there is not a little hole to push paper clip into. Is...
4. Press Return.
5. Type: mac-boot
6. Press Return
Sep 25, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
DVD stuck in MacBook Pro but my laptop registers nothing...
If you look on the dvd drive there is a little round hole. Just get a paper clip and straighten it out and stick it into that hole. There is a little button that you push with the paper clip that is a manual eject button for cases like this.
Aug 22, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
CD not coming out of my MacBook
Things I might try that you may or may not have tried already:
  1. Reboot and try to eject again.
  2. Reboot and hold down your mouse button during start up.
  3. Reboot and hold down your the eject button during start up.
If those don't work, check to see if your disk drive is warped in anyway. My old MacBook would only eject if I pried the slot open a little.
I hope you can get your disc out.
Jun 04, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
APPLE MACBOOK WOULD BOOT. THE BOOT CD IS
unfortunately on the newer mac computer including the macbook you cannot boot to open firmware but there are other options
option 1)simply try holding down the mouse button or track pad button during boot after the first chime is sounded this will instruct the computer to eject the cd through the firmware
option 2) you can bypass the cd boot by holding down the option key after the first boot chime another simple solution this will allow you to choose a startup disk during...startup after which you can try the eject button on the keyboard or select the disk in finder and eject via trash can or eject symbol(symbol located in the open folder view of finder)
option 3) there is also a manual eject button though it may be harder to locate as they have change placements of it over the years however it can usually be found by probing the top center or far right of the cd slot with a paper clip just be gentle you don't want to damage an expensive piece of equipment by just carelessly jamming metal in it
you may want to try searching apple with your particular model and search for manual cd eject
best wishes, Crash
Apr 24, 2009 | Apple MacBook Mac Notebook
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
128 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
