Question about Marantz Audio Players & Recorders
MARANTZ CDR300 no signal display - Marantz Audio Players & Recorders
  • Marantz Master
  • 19,396 Answers
Hi.
If there is no display, and unit is completely dead with no power, then you may have a defective power board.
If there is no display, but unit is responsive, then it is a faulty LCD display, or the cable to LCD has slipped out from connector.
If the unit is not responding, the power led is on, and there is no display, then there is probably an internal fault on digital board. Not a minor fault, since the unit is not on protect mode.
You can try disconnecting everything, including speakers and power cord (first power cord).
Wait ten minutes and restart the unit.
If the CD player is still in the same condition, then it must be fixed by a technician.If you have technical training grab multimeter and service manual and start testing components, beginning with the power board.
To have it repaired call the service number listed on the Marantz user manual.
Let me know if you need more help.
Posted on Nov 13, 2009
2 Suggested Answers
djnick989
  • 1067 Answers
SOURCE: Marantz cdr300
try turing off opc in menu see if that helps use hi end meadia only memerex i like
Posted on Jan 19, 2008
Marantz CD4000 dim display fix?
CD 4000 have two types of displays. Flourocent type and LCD type. It yours' have flourocent type, the display module is faulty. If it is LCD type, backlight LED is faulty. This LEDs can be replaced.
Jun 05, 2012 | Marantz CD-4000 CD Player
I bought a second hand marantz receiver. my problem is when i push the cd button the display read like this: CD/DIG2/STEREO/NO DATA and the it will go back by it self to CD/DIG. what should i do? please...
the receiver is ok. it is telling you that CD is assigned to digital #2 input, surround mode is stereo and there is no input signal. You need to connect a source to digital2 input (coaxial or optical) and you'll get sound from it.
Jun 01, 2012 | Marantz SR-7000 Receiver
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Hi,i have connected phono cables from mixer to anolog in on marantz dr4050 and from anolog out on marantz dr4050 to input on amp,there is no sound unless you turn levels to max and then it is very quiet...
So you're saying an unnamed mixer is feeding a potential analog signal to a CDR. You're monitoring the CDR output at an unnamed amp.
You haven't established that there is any signal to BE heard.
WHAT is the actual source sound device (BEFORE the mixer)? Is the source input visible on the CDR when it's in Record Mode?
Have you perused the manuals?
NEVER USE EXCEPTIONALLY HIGH VOLUME SETTINGS FOR TROUBLESHOOTING. If a signal is inaudible at half volume it's effectively not there. YOU WILL BLOW SOMETHING UP WHEN YOU FIND THE MISPLACED CONTROL AND FLIP IT.
Jun 07, 2011 | Audio Players & Recorders
I recently purchased a used Marantz CDR300 CD Recorder. Everything powers on but when I put a cd in the tray, it doesn't close automatically when I press the close button and when I manually close it, the...
CDR error means the trouble is in the laser eye,maybe the eye is faulty already or dirty. If the laser eye is dirty,then you need to clean it with a cotton buds.Open the unit then wipe the laser eye tenderly with the cotton buds or buy a DVD / CD cleaner kit.Just click this link;
http://electronics.bizrate.com/search__SEARCH_GO--GO__SEARCH_GO.x--36__SEARCH_GO.y--16__keyword--dvd+lens+cleaner__search_box--1__sfsk--1.html
Hope its help:
Regards;
VOTIT
Jun 27, 2009 | Marantz CDR-300 CD Recorder
Marantz: Rereading ..... error
Put a lens cleaner into it for the first troubleshoot.
Aug 07, 2008 | Marantz Audio Players & Recorders
Marantz sr-7200 no OSD
Press AMP then OK on your remote. If the menue does not appear press 9 on the remote. You must have your monitor connected through composit Monitor Out or S-VHS.
Also check your multiroom settings. Maybe your OSD signal is diverted through to other room. I do not have SR-7200 any more, unfortunately.
Jul 24, 2008 | Marantz SR-7200 Receiver
Marantz cdr300
Jan 18, 2008 | Marantz CDR420 CD Recorder
60 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
