Do i have to pluy in both 3 pin cables on my pny gts 250 512mb
Do i have to plug in both 3 pin cables on my pny gts 250 or just one to the power supply? as there are two identical 3 pin cables coming off the small six pin end that goes into the graphics card? thanx.
  • 111 Answers
Yes you need to plug in both cables.
Posted on Jan 25, 2010
I have installed two diferent graphics card, #1 was MSI 5459 and #2 was a Nvidia GeForce 250. Bth ran fine afor a short period of tme #1 for a month an #2 for about 2 weeks. After these periods of time...
I don't find the MSI 5459 graphics card, William.
Am familiar with the Nvidia GeForce 250 GTS, though.
Using the GeForce GTS 250 as an example, the graphics card requires a 6-pin PCI-Express power cable, for additional power, along with the power it gets from the PCI-Express x16 slot it is in.
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
The unit is furnished with an adapter power cable, that converts 2 Molex power cables, (4-pin Peripheral power cables, actually), into 1 PCI-Express 6-pin power cable.
Note that the 6-pin PCI-Express power cable, has two Yellow wires in it.
Let's look at a 4-pin Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note there is one Yellow wire, one Red wire, and two Black wires.
The Red wire is a 5 Volt wire, and not used by the adapter power cable.
The two Black wires are Ground wires, and only one is used by the adapter power cable.
The Yellow wire is a 12 Volt wire, and is used by the adapter power cable.
The 6-pin PCI-Express power cable requires TWO Yellow 12 Volt wires.
(And three Black Ground wires)
This means Two 4-pin Peripheral power cables MUST be used.
Failure to use two 4-pin Peripheral power cables, to that adapter power cable, means the GeForce GS 250 is NOT receiving enough power.
This will burn the connection at the graphics card, burn the adapter power cable connector, and burn the PCI-Express x16 slot it is sitting in.
Takes time, but will happen.
Could this be what you have done?
It also requires 150 Watts all by itself. You need more power for the rest of the computer.
(The 6-pin PCI-Express power cable is designed to provide up to 75 Watts of power. This means 75 Watts of power, also comes from the PCI-Express x16 slot, it is sitting in)
Nvidia GeForce GTS 250,
http://techreport.com/articles.x/16504
For additional questions post in a Comment.
Regards,
joecoolvette
May 20, 2012 | HEWLETT-PACKARD HEWLETT RECERTIFIED...
1976 Ducati 860 GTS - backfire
Hi, Anonymous and the usual suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Backfiring
http://www.ducatimonster.org/forums/general-monster-forum/202081-exhaust-backfire.html Ducati 860 GTS GT 1976 1999 Service Repair Manual Download Manuals...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 04, 2012 | 1976 Ducati 860 GTS
Bfg 8600 GTS OC
While BFG used to have a good warranty, they went out of business in late 2010, which makes a replacement under warranty very unlikely.
If you have another PC you can install and test it in, I would try that. But it does rather sound like a graphics card problem to me. Which means a replacement will most likely be needed.
Luckily, you can get a very decent, if not better, card to replace it for less than $100. I would recommend anything in the Fermi graphics card,either 400 GTS or higher, which I have (with or without rebates) in the $100 range. PNY, Gigabyte, or XFX are all brands I have used, they have at least 3 years warranty on them.
Jan 21, 2012 | BFG Technologies GeForce 8600 GTS OC 256MB...
My gpu card is not being detected at all.its a pny gts 450
Hi there.
I suggest you make sure that you are running the latest diplay drivers for your GTS 450.
You can get them at the Nvidia download center here.
Just select the following from the drop-down boxes.
Product Type: GeForce
Product Series: GeForce 400 Series
Product: GeForce GTS 450
Operating System: Your current operating system.
Language: The language that you want the setup to be in.
Then click the search button.
Click download on the next page. Once downloaded, run the setup and it will install the driver. You will need to restart to finish the process.
Slasher_X
Jul 07, 2011 | PNY Technologies Pny Geforce Gts 450 PciE...
My cousin recently upgraded his PNY video card, so he gave me his old one. It's a VDCARD, 8800, GTS 640MB PCIE. When I try and install it in my TA760G M2+ (Biostar) motherboard it makes a loud, cringing...
This Graphics card needs a system with at least a 450Watt power supply. As your cousin upgraded to a newer card, we can therefore assume that this card works and the problem lies with your computer. The power supply being the most obvious. I recommend a Cooler Mater Extreme Power Plus 460W or greater.
Dec 23, 2010 | PNY XLR8 GeForce 8800GT 512MB PCI Express...
I have vertical red lines generated by my Nvidia 8800 GTS graphics card
Its a GPU problem.
It can be overcome by doing reflow technique.
You need to do following.
1. Uncover ur PC casing
2. Locate the nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get scrambled display/wavy screen, but wait for 5 minutes.
7. Press reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10. Connect the power supply pin back as it is.
11. Power on ur PC.
thats all.
Removal of fan power, makes the GPU to get high heat, it a reflow technique.
Remember, not to touch the GPU portion (heat sink), as it may be in higher temperature.
Try this, it works most.
Clarifications:
gnaveendra@gmail.com
Feb 22, 2010 | ASUS NVIDIA GeForce 8800 GTS (512 MB) PCI...
Ok So i have a Biostar TA785GE 128M with a Phenom II X4 965 Processor. So ive plugged everything in and the problem is that when i plug the monitor cable thing into my video card, the monitor doesnt have a...
if your mobo has built in video output, connect your monitor to that 1st. if your able to get to the bios, change the primary vga port to PCI-e,save and exit. then reconnect your monitor to your video card..
Hope it helps!
Feb 14, 2010 | Biostar TA785GE 128M AM2+/AM3 AMD 785G...
Nvidia geforce 8800 gts code 43 due to vista home premium
Well if you installed the correct drivers for your video card and have the proper power supply requirements, then the vertical lines you're getting most likely indicate that your video card is bad.
Try it in another computer if available, or get another video card.
Jun 19, 2009 | PNY XLR8 NVIDIA GeForce 8800 GT 512MB...
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
