Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Have a Craftsman Garage door opener - doesn't activate, only the light blinks. Neither sensor has any lights lit. Any suggestions?
    President:
  • 3,197 Answers
If you mean the main light blinks when you try to close the door then you have bad door sensors or the wiring going to them. Make sure the connections are tight and the wire is not broken somewhere.
Posted on Nov 13, 2009
MY LIFT MASTER 1245 IS HUMMING AND GARAGE DOOR STOP HALF WAY DOWN LIGHT BLINKS
If the main light is blinking 10 times check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Jan 31, 2011 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 102-1499A Opens w/ remote. Will not close w/remote.
If when you try to close the door the main light flashes 10 times and the door reverses to the open position you have a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on you have a bad sensor.
Jul 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
For 1/2 HP belt drive opener: With the belt off, the motor sprocket only turns 1/8 - 1/4 turn each time the door opener button is pressed. Although nothing is obstructing the door or the sensors, the...
If the main light blinks 10 times when you try to close the door it is a door sensor problem. Make sure the small light on each sensor is lit and not blinking. Tweak them a bit if necessary.
Oct 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
We have a 3/4 hp Craftsman garage door opener that has stopped working. It opened fine, but will not close. The lights on the unit work but the Training Light is blinking.
If by training light you mean the LED next to the smart/learn button then this is normal if it is random blinking. Make sure your door sensors are properly aligned and pointing at one another. Each of them has a small light that should be lit and not blinking when they are aligned.
Jul 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener (1/2 hp) won't close proper
Check your door sensors. They have probably been bumped. Tweak them until they are pointed at one another and the small light on each one is lit and not blinking.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
When try to use remotes or wall control to close garage door, lights blink 8 times. Can only close by holding down wall control the entire way.
Your door sensors are most likely misaligned. Each of them should have a small light that is lit and not blinking. Tweak them until both are lit.
May 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door closes all the way but then opens again and lights blink 10 times :/
Most likely your sensors are out of alignment. Check to make sure the small light on each sensor is lit and not flashing.
Apr 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close with remotes
Yeh, read manual. Do both sensors have led lit. try aligning. you have safety beam problem,
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
My craftsman wall keypad for the garage door opener blinks when activated, won't open door. I changed the battery thinking this was the problem, no fix. I tried temporary password option and no fix. I...
You need to reprogram the keypad. Press and realease learn button. Within 20 sec. press 4 digits and press and hold enter. The light will blink on the opener. You are done
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
627 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
