Question about Whirlpool ED2FHEXN Side by Side Refrigerator
WHIRLPOOL 25.3 CU.FT MODEL ED5FHEXNT00
FRIDGE SIDE NOT COLD FREEZER SIDE GETTING FROST IN IT
  • Rich P Jan 15, 2008
    I have the same problem,except the frost is building up near the bottom of the wall between the freezer & frig. No matter where I set the freezer temp control, it doesn't change the sub-zero freezer temp or the or the frig side not being cold enough. Please help.
  • Anonymous Mar 15, 2014
    what are the dimensions of the amana ars266rbw 23.2 cu ft. side by side unit
  • 125 Answers
If the frost is on the back wall of the freezer then you most likely have a defrost problem or a bad evaporator fan motor.
Posted on Jan 08, 2008
Possibly freezer drain blocked causing ice build-up behind back freezer wall. This internal wall should be accessible by removing screws.Check fan motor in that area is working and also check that all door seals have no cracks or tears. This can cause ice build-up and motor to run longer than normally. benham's suggestion another possibility.Naturally have power off when dismantling anything.
Posted on Jan 11, 2008
  • 35 Answers
REPLACE THE DEFROST HEATER
Posted on Jan 17, 2008
My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Mar 07, 2012 | GE Refrigerators
Freezer not as cold even when set on the coldest setting getting accumulation of frost inside freezer supposed to be frost free
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 21, 2011 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The things in the freezer are not frozen and there is ice in the milk in the refrigerator. It a 6 year old Whirlpool side by side.
You possibly have a 2 part problem. Do a 12 defrost and make sure the product in the fridge is not near the auger (cold inlet vent into the fridge). Fridge gets its frost from the freezer compartment.
Nov 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side .
Please send me the model number so I can help you better, Thanks Sea Breeze
Apr 01, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
MY FREEZER FREEZING AND FRIDGE IS NOT COLD ON MY BLACK SIDE BY SIDE WHIRLPOOL
hi thanks for the question i would check to see if the fan in your freezer is working that could be the problem make sure the back of the fridge is clean where the compressor is located also make sure no frost has built up in freezer thanks the appliance doc
Sep 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool fridge with top freezer.( no ice maker )
check if you have frost build up at the back side of the freezer section.
if you do, then it is a defrosting problem.
you could have a problem with the defrost timer, the defrost heater , or the bi-metal.
if there is no frost accumulation, that would be something more and you have to elaborate on what you observe with the unit to help me further troubleshoot your unit.
tnx 4 using fixya,
drcool
Sep 11, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Side by Side Refrigerator not getting cold
hi there,
is it just the fridge or the freezer as well?
Sep 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Fridge Model WRX57H Defrost Timer
if you couldn't find a defrost timer then just unplug it or switch it off until all the frost (ice) melts!
Nov 19, 2007 | Whirlpool 19.6 cu. ft. Upright Freezer...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
453 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
