Question about Cannon Magnum 10 Hs Electroncs Downrigger
I JUST RECEIVED A CIRCUIT BREAKER FOR AM MAG 10 DOWNRIGGER AND THERE ARE NO INSTRUCTIONS DO I RUN THE POSITIVE WIRE THROUGH THE BREAKER AND THEN ATTACH IT TO THE BATTERY?
Hey Strech thanks again there are six terminals on switch the red is on the one 10:00 and that is going to the circuit breaker underneath the dash the blue is on the one about 1:00 that also is going to...
The older Knuckleheads (and flatheads) and early Pans had 5 terminals, but later ones (like yours) had 6 terminals.
You keep saying the BLACK one goes back to the battery, but you haven't told me (I have only been ASSUMING) if it goes to the POSITIVE terminal of the battery, NOT the negative, correct?
IF the BLACK wire is in fact coming from the battery's POSITIVE side, hook it up to the 4 o'clock position - the jumper wire going from this terminal to the one at 1 o'clock IS NEEDED TO FUNCTION PROPERLY!
You stated, "the red is on the one 10:00 and that is going to the circuit breaker underneath the dash the blue is on the one about 1:00 that also is going to the circuit breaker"
Does this mean BOTH the RED and BLUE wires are going to the SAME circuit breaker?
If so, do they BOTH connect at the same circuit breaker terminal stud, or one to one stud (at one end of the circuit breaker), and the other to the other stud (at other end of circuit breaker)?
Feb 11, 2014 | Cars & Trucks
I am connecting a 1000w Cobra Power inverter to a deep cycle marine battery that will be used to run small appliances while camping. How do I properly connect the inline circut breaker for maximum safety?
The breaker goes in in series.
So, that means (for example) you remove the hot wire to the unit, from the positive battery power source, and hook this wire to one side of the breaker, then connect the other terminal to the positive battery power source.
This will stop current flow if anything over 40 amps happens on the line.
You actually can hook the breaker anywere along the circuit, but the closer to the power source, the better you are protected.
Mar 02, 2011 | Inline 40 amp. In-Line Circuit Breaker
How do I wire my 60 gal 3 hp IR commpressor? What size wire, what size breakers, and where on the motor do I attach my wires. Motor says 15 amp, 220 volt. Thanks, Clint
I would use a # 10 wire size with a 30 amp breaker. The motor should already wired to the pressure switch unless it has a mag starter. If no mag starter incoming power should go to pressure switch not motor. If unit has a mag starter incoming power should go to top of mag starter.
Jan 12, 2011 | Ingersoll Rand Single Stage Cast Iron 3 Hp...
Looking for parts & service: mag 10A cannon downrigger
Your best bet for price is looking on ebay, there are lots of links off of an inquire.
Apr 12, 2010 | MAG Cannon Mag 5 HS Downrigger
15A breaker tripping; Is this the right size breaker for the unit?
The breaker is sized according to the size of the wire used in the circuit. The breakers task is to protect the wire from an over current.
The allowed sizes are
#14 wire .... 15 amp breaker
#12 wire ..... 20 amp breaker
#10 wire .. 30 amp breaker
To check if the oven and circuit are compatable .. run an extension for the oven to an outlet outside the kitchen and see if it holds.
Please Vote !!
Mar 08, 2010 | Hotpoint RVM1435 Microwave Oven
IHAVE A CANNON MAG 5 AND THE CABLE RUST UP ON ME CHANGED CABLE AND IT DID IT AGAIN IN ONLY 4 HRS
Corrosion is caused by small amounts of electrical current flow following the path of least resistance and jumping off one piece of metal to another one thus taking a small piece of metal with it when it goes. You have to either eliminate the current flow or slow it down or make it go somewhere else. The positive ion control in these downriggers can probably add to the problem. Also if you're fishing in salt water, it is a natural electrolyte and if two differnt kinds of metal are in saltwater, they creat a natural battery and produce enough electrical current to corrode the metal. I would suggest maybe using a sacrificial anode. It's a piece of metal with lower resistance to electrical current flow than the metal you're trying to use, thus is corrodes the anode before corroding the metal you're protecting. Anodes are made of metals like aluminum, zinc and magnesium. If you had a small piece of one of those metals and wrapped it around the downrigger spool before you wound the cable onto it, it would rust it out before rusting your cable. You can also try turning down your Ion Control. I've seen my cable rusting a little bit but it doesn't seem to be that bad or rust so fast. I'm wondering if you're using a different kind of metal for your cannonball?
Oct 15, 2009 | MAG Cannon Mag 5 HS Downrigger
Cannon Magnum 10 Hs Electroncs Downrigger Logo
48 people viewed this question
Top Cannon Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Cannon Boating Expert? Answer questions, earn points and help others
