Question about Acer 91.63X07.001 Keyboard
When I push the space bar I get a c followed by a space pushing m gives me ,m Holding the key down gives correct letter in succession.
    Master:
  • Acer Master
  • 956 Answers
It appears your keyboard prog is setup wrong. gointo your mouse/keyboard prog and reset language details?
Posted on Nov 13, 2009
Reset computer
when computer is plugged in and powered off, hold down apple and option keys on left side of space bar and p and r keys. Keep them all pressed and hold them and push the power button, keep them down and listen for the boot chime to happen three times.
THis is resetting the pram or nvram.
Also try disk selct by holding down the option key or maybe try safe mode by holding down the s key.
Apr 08, 2014 | Apple MacBook Air
O want to install a new key . What are the steps ,please
A key falling off of a keyboard might be an annoyance, but it is not a reason to buy a new keyboard. Regardless of which key falls off, it can be replaced fairly easily. Although the method of replacing typical letter keys is a little different than replacing the space bar, replacing either of these types of keys can be done in a few minutes.
Carefully pry the key from the keyboard next to the key that has fallen off. This key can easily be pried by sliding a flat-head screwdriver underneath it and popping the key out. Be careful to make sure the key retainer underneath the key stays in place, especially if the key retainer has also fallen off the key you are attempting to fix. Look closely at the key retainer underneath the key that was just removed. Notice there is a notch in each corner of the key designed to hold the key in place. Place the key retainer back into place if it has fallen off the key you are trying to fix. Make sure it is positioned exactly as the key retainer next to it is. Put the key on top of the key retainer. Use your index finger to firmly push straight down on the key to lock the key back into place. Do the same to the key that was taken off to view the other key retainer. b> Replacing the Space Bar b> Turn the space bar upside down and use a flat-head screwdriver to separate the retainer from the back of the space bar key. Place the retainer into its place on the keyboard. The retainer will hook into small hooks on the left and right sides. The small metal bar from the retainer should line the bottom of the area where the space bar will be placed. Put the space bar back into the place where it belongs. Spread the ring finger, middle finger and index finger across the space bar, and push firmly until the key snaps into place. Put the space bar key back in place and gently press on it with fingers until it snaps back in place.
b>
Jan 16, 2013 | Computers & Internet
How to fix a key that has come off the keyboard
If it has just been levered off the keyboard, it should push back on where it came from. don't be afraid to use a little force :)
hopefully it is a letter key, because putting a space bar back on can be a little painful, they have a small metal brace under them which must be oriented correctly for smooth functioning.
I hope this helps
Apr 03, 2011 | Acer Computers & Internet
I have a advent laptop, i am looking onlibe for a new keyboard as my little boy got hold of laptop this morning and pulled every key off, i need to know wat number adven my laptop is how do i find out...
I do not know about a new keyboard but your model number is usually found on the base of the machine.
If you have the parts the boy pulled off you be able to stick them right back - most keyboard letter buttons fit in with a simple push. The Shift, Caps lock and space-bar have little wires that need to be hooked into a matching part in the base before you push it in. Hook the wire while holding the part level and above the keyboard, then pull back and push in. Good luck!
Thank you for rating fixya answers.
Feb 14, 2011 | Computers & Internet
Certain keys on samsung N150 not working. space bar 2 key 3 key G letter key
Some dust or liquid must have entered or dropped on the keyboard. If it is just dust try using a compressed-air spray canister to blow in the space around the key.
If that does not work you can use a thin knife or flat screwdriver to pry the keys off. Do that with the 3 key first as the space bar is more difficult to put back in - there are a couple of springs that have to be fitted just right. Clean away any dirt and push the key in place.
If it is a liquid then you must open the entire keyboard panel and clean it from the inside. If you have the confidence and skill to do that you can try searching samsung support about how to do that. It is not that difficult if you follow the instructions carefully, but if you yank the flat cable connector off it may be difficult for you to snap it back in.Otherwise ask for professional repair.
Jan 05, 2011 | Samsung N150 (36725723009) Netbook
The sapcebar had poped off and all the parts are still fine and arent missing or broken is there anyway that I can fix it without bringing my computer back to get it fixed?
Just place the space bar back on the keyboard, align it in its correct position and push down on the space bar key until it clicks in place.
Dec 24, 2010 | Computers & Internet
I just purchased a 1923 royal typewriter from ebay - the big kind with glass sides. It was supposed to be in excellent working condition, however upon arrival the space bar doesn't move the typewriter...
Suki,
Evidently your typewriter got damaged in shipping. The problem you describe could be caused by any one of a dozen things. It would be virtually impossible to diagnose the problem without looking at it personally. I wish I could help you.
Michael (deacon-frazier@sbcglobal.net)
Jan 15, 2010 | Office Equipment & Supplies
My keyboard spaces about 5x after hitting it once
in this case you need to do the system restore to the earlier date and that will resolve the issue .
Apr 01, 2009 | Gateway 7001433 Keyboard
Keyboard not responding to EVERY stroke
MAY BE BECAUSE THE KEYS DON'T COME IN CONTACT WITH THE PLASTIC LAYER IN KEYBOARD OR MAY BE COMPUTER DOESN'T GET CORRECT INPUT SIGNALS
Jan 22, 2009 | Logitech 967437-0403 Keyboard
Space bar sticking on Saitek lighted keyboard
For me, I popped of the space bar, cleaned the junk underneath and fidgeted with the plastic push-button and all was better. Thanks for the suggestion!
Feb 21, 2008 | Saitek Eclipse II
Acer 91.63X07.001 Keyboard Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
