Question about Troy Garden
Troy bilt string trimmer has spring assist. now when i pull it the string just recoils and will not start
StickyBeets
SOURCE: put string on tb425cs troy bilt trimmer
there are two ways to install the string..the cool way is without pulling the inner reel off the trimmer..just leave it in place..cut (2) approx.two arms length (thats spreading your arms out like airplane wings) of .095 string..now, align the arrow of the inner reel (it turns counter clock-wise..the arrow points outward) with the arrow on the outer spool (pointing inward)..holding the spool and reel together so the inner reel doesnt move, push one of the cut strings through the eyehole in the side of the outer spool, and it should come up to the right, through a slot next to a small round hole the diameter of the string..if it doesnt, it just missed the exit (as i call it)..pull out and try again..let about an inch come thru..now take that end of the string and push the line into the little round hole until it stops, which should be about a little more than 1/8 of an inch..hold it in while pulling the excess line outside the spool to keep it in place..now do the same with the other string for the other side..once you have both lines in place, turn the inner reel counter clock-wise to draw in both lines through the eyeholes of the outer spool..you may or may not get all of the line to wind in..not a problem..you will still have enough to do what you need to do..just cut off the rest..one problem you may or may not have that i do most of the tyme is that it gets hard to turn the inner reel..one solution is to bump the top of the 'bump knob' with your fist, then pull both strings at the same tyme, then continue to turn..this method is quicker and easier than the second way of having the inner reel out and trying to wind both lines at the same tyme and trying to place the reel back in the spool..hope this works for you...
Posted on May 19, 2009
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
  • 28 Answers
SOURCE: troy bilt string trimmer starter rope
you need to rotate the starter pulley up first to tension the spring.... then feed in your rope tie a not and let it retract the rope into the starter pulley
Posted on Aug 06, 2009
SOURCE: Need info on putting line on troy bilt 4-cycle
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Posted on Apr 05, 2010
  • 63 Answers
SOURCE: TB465SS trimmer won't rev up
change spark plug and check the gap between points
Posted on Jul 24, 2010
Troy bilt pull cord wont retract
Recoil spring is broken or slipped out of retention slot. Coil needs to be retentioned or replaced. Unless you have done this before I recommend taking to pro. This is easy job if you have the jig but almost impossible if you don't.
Jun 29, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Won't start. String pull will not go more than a few inches. Engine seized?
Try the clutch. I just fixed this problem.One of the clutch springs ate it's way though the red housing where the spring for the pull start is at. When the housing came apart the engine seized and I couldn't move the pull start. For the schematic on the engine here is the web address http://www.searspartsdirect.com. Hope this helps.
Aug 20, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Cannot get the housing off so that I can change the pull cord on my troy bilt tb70ss grass trimmer
If you are holding the unit where the drive cable goes in, there is a screw in there. It is a #15 or 20 TORX screwdriver. Take out the screw and it will allow you to get to the starting spool. Good luck...Lee
May 29, 2010 | Troy Bilt Tb70ss Gas Trimmer
I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Apr 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Garden Logo
329 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
