Question about Kenmore Dryers
My Lady Kenmore Ultra Fabric Care electric dryer model #86692100 abruptly stopped heating. Fuses are okay and venting is fine. Need troubleshooting information
  • Kenmore Master
  • 19,396 Answers
Hi.
Test the heating element and the thermostat.
Both are tested using a multimeter to read impedance. Set multimeter at Rx1, on Ohms.
To test the element disconnect element and point tester probes at element contact.
If there is no continuity, and the circuit is open, then the element is faulty.
The thermostat can be tested jumping its wires to bypass it, but there are many safety concerns doing this kind of test.
Better disconnecting the thermostat and reading Ohms, as for the element.
At room temp the thermostat must have low impedance, if it goes to infinity, and circuit is open at room temperature, then the thermostat is bad.
If both test good, and you have no heating at all, then it may be a bad electronic control, or a wiring problem.
The model number you gave does not match.
Try Entering correct model number on this website to get parts and diagrams.
Regards.
Posted on Nov 13, 2009
Electric Dryer wont heat up
Dryers don't have fuses, I would say the heating element has went bad, not to hard to change
Sep 27, 2012 | Kenmore Dryers
Ultra fabric care electric dryer model 96588210 stopped heating all of a sudden. I cleaned vent tube out. Flipped circuit breakers. still not heating. Thank you
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 06, 2011 | Kenmore 62622 Electric Dryer
Kenmore Ultra Fabric Care dryer Model/stock number 96595220 65952 Dryer shuts off all the time. Runs, heats, works, then just stops. This happens repeatedly. Please help!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 13, 2010 | Kenmore 659 Electric Dryer
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Mar 25, 2010 | Kenmore Dryers
Kenmore ultra fabric care dryer runs, but does not heat up Same as Christy's. Runs no heat, however, the exhaust vent is clear. Could this be the fuse or heating coil?
could be a thermal fuse,heating element or a heating element relay.if you pop the trim caps off of the sides of the console,and remove the 2 phillips screws in the corners and lift up console you will find a tech sheet inside.if you have a multimeter that you can check continuity with along with the tech sheet,you might be able to figure it out..good luck
Sep 28, 2008 | Kenmore 62622 Electric Dryer
Kenmore Electric Dryer
check your fuses.one runs the dryer and other heat the dryer.
check to see if belt is broke or wire is burned off of motor.
Mar 08, 2008 | Dryers
check the thermal fuse the operating therostat and the igniter is this a gas or electric dryer
Jan 12, 2008 | Kenmore 62602 Electric Dryer
only thing i can think of without being there and able to test parts is your door catch could be faulty
Aug 10, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
555 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
