Have high pich sound out of audio - Televison & Video
  • landryele917 Nov 19, 2009
    it comes from speaker and goes up and down with vol. thank you
    President:
  • 1,462 Answers
It could be a leakage problem that is getting into the audio amplifier and the sound is coming out from the speakers. Or, it could be the high voltage generator that was disturbed during the move that caused it to create an acoustical output when expanding and contracting during the high voltage generation cycles.
Here is what you can do: Listen carefully. Does the sound go up and down with the volume control or does it remain constant. If it goes up and down, put your ear up to the speakers and verify the sound is coming from the speakers.
Likewise, if you don't think the sound is coming from the speakers, turn the sound level control to zero and listen to the set and try to determine form whence the sound IS coming. If from inside the set, near the back, then it may be the high voltage transformaer, changing the transformaer would solve your issue....
If you are very handy, you may be able to fix it your self, but only after it has been diagnosed as to exactly what is the cause.
If it is coming from the speakers, here is one idea: If the set has external audio outputs (most big screens do), then you can use an external amp and speakers and with the tone control turn down the high frequencies to reduce the high pitch sound.
If it is internal, sometimes you can remove the back cover and find the source of the sound and by changing the mounting or even adding some isolation to the source, slow down the transmission of sound. Sometimes a part maybe has worked loose and tightening up the mounting hardware improves the sound.
Since this ailment has come upon the set since it was moved, the idea of some physical disturbance to one of the acoustical generating components inside makes a lot of sense. Now, you just have to find out where it may be coming from and follow my steps to solve your issue...
Please leave me comment, if you need further assistance
Thanks for usinf Fixya!
Rnj VINODKUMAR
Posted on Nov 16, 2009
High pitched whine
The most common cause would be a defective power steering pump.
Aug 29, 2012 | Cars & Trucks
High piched squeal
Sounds like a color wheel. Bearings in color wheel make such a sound when bad.
Nov 27, 2010 | RCA R52WM24 52" HDTV Projection Television
My traxxas revo 3.3's gears are grinding, the car has slowed down
sounds like engine is running to lean. count how many times the high end needle is out. will have to retune engine before piston seizes completly up.
Jul 20, 2010 | Traxxas Rc Revo Nitro Monster Truck
I have 4.3 L and i keep on hereing a high piched noises
You need to determine which pulley your noise is coming from,the best way is to use a long extension and place it on each item and just touch it to your ear,then you will be able to hear how each of them have there own sound.but from here,i'll place my money on the alternator,they do put off a high pitch noise when the front bearing is drying out on them
Dec 18, 2009 | 1996 GMC Jimmy
Noise from drivers side
hi how are you.there is a couple of things that will cause a rubbing sound.if it is a high pich sound then look at your dust cover behind your brake rotor.a low pich or a growling noise check your wheel bearing/hub assembly.with wheel off the ground wiggle it side to side and up and down you will have alot of play.or there is something hitting the tire.
Feb 02, 2009 | 2001 Daewoo Lanos
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Kac-8401 buzzing noise
If the buzz is real high pich the faster you go and lowers to a low pich when you slow down then it is you alternator on your engin.
The only way to stop this is to go to an caraudio store and buy a noise filter which will stop the noise. The only bad thing about getting an noise filter is that it will cause the watts on your amp to go down a little bit because the noise filter runs your power source through a box with a step up transformer and a step down transformer. I hope i helped you with your problem
Jan 25, 2008 | Kenwood KAC-8401 Car Audio Amplifier
No Picture/High Piched Sound
bring it to the authorise service center man, simple. Fred-Modern Home Qatar
Jan 26, 2007 | Panasonic CT-36D11 36" TV
Televison
The high pitched sound is probably comming from the power supply, possibly due to its trying to drive voltage into a shorted component in the high voltage deflection circuits. You may be lookng at about a $250 repair. If it has been used a lot and its picture quality didn't knock your socks off, I would replace it with a HDTV set. A 37 inch LCD from Toshiba might be a good place to start and should do nicely for you.
Jan 24, 2007 | Panasonic CT-36D11 36" TV
Televison & Video Logo
Top Televison & Video Experts
