Question about ICOM Informatique GP-360ML GPS Receiver
Antenna Plug/Connector The antenna plug on my 360ML is defective. ICOM says they do not sell the plug and I have to buy the entire antenna unit. I thinbk it is silly to pay over $70 for a $2 plug. Where can I get the plug.
Www.aandetrading.com
Posted on Jul 18, 2008
  • shvy Jul 18, 2008
    i think tou can get the plug at this web site www.aandetrading.com
My ssb antenna was stollen, I NEEd another antenna for ICOM SSB model IC707, any antenna can I use to replace this, or where i can buy this antenna in the philippines
Check with ICOM on their web site or with HAM RADIO OUTLET, a large chain in North America---you may find a source that ships overseas or even one in Manilla.
Dec 14, 2012 | Televison & Video
My SSB ICOM IC 707 antenna was stollen, I need another antenna what brand should I use beside Icom
Hi Tats,
Sticking with the brand/Make is always the best & recommended option, having stated this fact, you would do well by looking on websites such as ebay, under electronics, then radios, then Parts and Accessories, there is always a heap of new and refurbished gear for all Makes of radios including ICOM, and they're not expensive.
I hope this helps you to resolve your problem.
Cheers,
Peter
Dec 14, 2012 | Radio Communications
It doesn't pick up signals as good as other R10's
Assuming you already tried a different antenna, check antenna connections inside the case ... the antenna connector's centre conductor should be firmly soldered to the circuit board, and another solder connection from the circuit board to the antenna connector barrel. If the antenna connector has been twisted too much, these solder joints may be cracked and you could try re-melting the solder.
Dec 01, 2009 | Icom IC-R10 Handheld Scanner
I have a Siriusconnect Home Tuner and an XM Ready Receiver. Will they work together? What do I need to make the connection from the 8-pin mini DIN on the Tuner to the XM connector on my Denon AVR-587?
Not gonna work, sorry to say. You need the little two-piece "XM Ready" tuner unit (with antenna) to plug into your XM Ready receiver. Sell the Sirius Connect Home Tuner and buy the XM unit. XM unit still available at some Best Buy stores.
Sep 19, 2009 | Sirius Satellite Radio Receiver
Power antenna motor will not shut off
I assume that the power antenna unit is an original equipment unit, if so.
1. Does it run for about a minute then stop? If this is the case, your antenna shaft needs to be replaced. This is a very simple procedure that your local radio install shop can do for you in about 20 minutes.
2. If the motor never shuts off as long as the key is on, you probably have a defective relay on the antenna motor. At this point you need to replace the entire unit. A job that can be a bit pricey because of the price of the unit itself. A cheeper fix is to replace the power antenna with a manually telescopic unit, (no motor), or a fixed unit, (doesn't go down). If you opt for the latter, remember to unscrew or lower the antenna in automatic car washes!
Jul 07, 2009 | 1984 Cadillac Eldorado
I have an icom m304marine vhf with a shakespeare
Sound like you have an antenna issue. Try a different antenna with coax. If the problem is still there, than you have a problem with the radio. Icom makes really good marine radios but you could have a defective one.
Jun 30, 2009 | Cobra Mr F75b Marine Vhf Radio Fixed Mount...
External FM antenna
The fix for the problem is simply go to Radioshack and purchase their part number 278-267 which is an "F" jack to 1/8" Male Plug. The cost is $6.09. This should solve your problem. The 75-Ohm antenna plug can now be screwed or connected to the "F" connector.
Aug 31, 2008 | Bose Wave Music System CD Shelf System
ICOM GP-360ML GPS Receiver
I had this problem about a year ago. If all you need is the firmware update they will update it at no charge and they told me if it needs repairs they most likely will not have the parts becaus it is a discontinued model. They also said they did checked it and found no other problems. Sent it in to Icom:
Icom America
2380 116th Ave NE
Bellevue WA 98004
They did the firmware update and sent it back to me free of charge. It works great now and my chart cards work great.
Sep 09, 2007 | ICOM Informatique GP-360ML GPS Receiver
ICOM Informatique GP-360ML GPS Receiver Logo
279 people viewed this question
Top ICOM Informatique GPS Experts
Steve
Your Consultant
Are you an ICOM Informatique GPS Expert? Answer questions, earn points and help others
