Fixing my input jacks.
Want to know how to take the front off of my peavey bandit 65 so I can re-solder the connections on my input jacks.
    President:
  • 1,126 Answers
Peavey classic chorus 1991 -how do you connect a distortion pedal the power amp jacks at rear tried affects loop in front bid drop in power-do you connect same way as effects loop with send /return
Pedals operate at a different level then rack units that go in the effects loop.
It needs to go in front of the amp input. Guitar to pedal to amp input.
Nov 12, 2016 | Peavey Music
I bought a peavey bandit 65 it's getting power but is barely making a sound?
There are a lot of possible problem areas it could be. I would first check that the speaker is working correctly. If so, I'd clean all jacks and pots. If that doesn't do it, it'll be time to take it to the shop.
Mar 28, 2015 | Peavey Music
Peavey bandit 112
cracked solder joint, bad pot, dirty insert jack
Aug 14, 2014 | Peavey Bandit 112 Guitar Amplifier With...
Hello, I am new to forums, this is my first time. I have a Peavey 696f power mixer, last night the left speaker channel stopped working, what do you think is causing this problem?
the pa1 or the pa2 input jack on the front of the unit is dirty, or you have a cracked solder somewhere, as these units are gettting old.
Jun 18, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
How do I replace cord jack on a Peavey bass guitar?
You'll need needle nose pliers, small phillips head screwdriver, soldering iron, electronics-grade solder, socket screwdriver or 1/4" wrench, black electrical tape. Purchase necessary replacement jack. Remove plastic electronics cover plate, located on the back of the body, behind control knobs. This will expose the electronics cavity. Locate existing jack and its wire connections inside the exposed cavity. Remove any electrical tape covering the jack connections. Using a hot soldering iron, touch each of the two soldered input jack connections, one at a time, just until the soldered connection melts. Then, disconnect the associated wires (taking note of which wire connects where!). Once disconnected, loosen and remove the nut on the outer part of the jack that holds it onto the guitar body. Remove the old jack. Insert the new jack (with the nut removed) into the existing hole, from inside the electronics cavity and tighten it in place, on the outside of the guitar body, with the nut. Re-attach the wires to the new jack, by using needle nose pliers to wrap them tightly around the correct posts. Touch the hot soldering iron to each post and apply a small amount of solder to the post as it's being heated. Once the molten solder runs over the connection and looks shiny, remove the tip of the soldering gun. This process takes only 2 to 3 seconds. Let the connections cool for a few seconds. To insulate, wrap connections with black electrical tape. Replace cover plate.
Apr 27, 2014 | Peavey Music
I just bought a used valveking 100 half stack and the 1st channel does not work, second channel works but seems to have a loose input jack as connection is intermittent and affected by wiggling the input...
Same thing... they probably broke both jacks. Sometimes the guts of the jack is broken and it doesn't appear to be broken but is broken internally. You may find broken solder on the pins to these jacks as well.
Note that the two input jacks have a different gain.
Here is schematic: http://elektrotanya.com/peavey_valveking_100_212.pdf/download.html
Dec 02, 2010 | Peavey Valveking Head
Peavey sound board 2 channels not working
check for cold solder joints from the input jacks and the fader. If any look suspicious (dull or grainy) re-solder.
Apr 29, 2009 | Peavey Pv 2600 Power Amplifier
PV 2600, couple years old, light usage. Connected to two PV SP3K speakers. One channel started to cutout somewhat but not all the way, Switched a few input cables, swapped L&R. Then whole amp shutdown....
Hi..
I've worked on similar units.
Things I'd check first :
Dust in the unit.
Weak solder connections /crusty debris stuff on the input jacks or output terminals
Any flex cables soldered in tend to be a problem on peavey amps I resolder all those contacts.
Checking the amp w/o a load IS NOT a good suggestion.
What style output connections are you using?
1/4 inch, binding post, or Neutrik style?
Dec 29, 2008 | Peavey PV® 2600 2-Channel Amplifier
Peavey 112 Bandit Lead channel problem.
Open it up check the back of the switch.
if its disconnected or poorly connected re-solder it if that does not work, or you dont know how to; get a new switch
[you can easily get them at the Source or some electronics store]
Dec 17, 2007 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
111 people viewed this question
 Grubhead
Grubhead
