Question about HP 1020 Plain Paper Thermal transfer Fax
CAN THE MEMORY BE LEAGNTHED ON HP1020 TO HOLD IN MEMORY MORE FOR INCOMING FAXES OR ELIMATE HOLDING RECEIVE FAXES AND PRINT PAGES AS THEY ARE RECIEVED INSTEAD.
I found the manuel on line and found out how to print the faxes in memory to release the memory. So next time a big fax comes thru I will try to print and release faxes from memory.
Posted on Nov 14, 2009
I have samsung clx3305fw am getting secure recieve
Hi, secure receive is for the incoming fax requires a password in order for the fax to be printed out which you had activated on the fax setup. Try removed it or you need a reset memory back to default.
Feb 07, 2015 | Samsung Office Equipment & Supplies
Cannot recieve fax on hp pro 400
HI,
Set Fax Forwarding:
You can set your product to forward incoming faxes to another fax number. When the fax arrives at your product, it is stored in the memory. The product then dials the fax number that you have specified and sends the fax. If the product cannot forward a fax because of an error (for example, the number is busy) and repeated redial attempts are unsuccessful, your product prints the fax.
If the product runs out of memory while receiving a fax, it terminates the incoming fax and only forwards the pages and partial pages that have been stored in the memory.
When it is using the fax-forwarding feature, the product (rather than the computer) must be receiving the faxes, and the answer mode must be set to Automatic .
  1. From the Home screen on the product control panel, touch the Fax button.
  2. Touch the Fax Menu button.
  3. Touch the Receive Options button.
  4. Touch the Forward Fax button, and touch the On button.
  5. Use the keypad to enter the fax-forwarding number, and then touch the OK button.
If not solved i share a link please visit and follow instruction.
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay?javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalState%3DdocId%253Demr_na-c03266760-14%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01&ac.admitted=1403114393261.876444892.492883150
Thanks,
HP Phone Number
Jun 18, 2014 | HP Photosmart C6180 All-In-One InkJet...
Canon PIXMA MX330 multifunction printer. I get a lot of faxes. Is there a way to save ink & paper by having all faxes come in without printing them & just putting them to memory & review them...
unfortunatly not!The m/c will print each and every fax!I can suggest getting a fax to email nr and recieve the faxes on your pc and then printing what u need!Memory does keep about 258 pages depending on the coverage on the pages!
Feb 22, 2010 | Canon PIXMA MX330 Multifunction InkJet...
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Fax in receiving faxes but not printing them.
noavatar.png Incoming faxes automatically go into memory. We can't print them out. Would like incoming faxes to print out as they used to. have tried the on off button but it didn't fix the problem
Apr 16, 2009 | Canon FAX-JX200
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
200 page fax sent to me incorrectly
turn the machine off, hold down the stop button and turn it back on, this will clear the memory
Jan 29, 2008 | Brother FAX-2920 Plain Paper Laser
Received in Memory
To clear recieved faxes from memory that are not printed out after a print failure. Perform the following. Lift the panel press data registration then press #. Press the down arrow to test and press set and set again. this will perform a memory test and wipe out the contents that hold the documents while leaving the speed dial memory.
Aug 03, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
HP 1020 Plain Paper Thermal transfer Fax Logo
116 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
