Printer keeps printing shamrocks hearts and other symbols
    President:
  • 2,306 Answers
The symbols happen when you plug in your printer while it's on. You need to check your print que in the computer, delete any jobs waiting and turn off and on the printer after clearing the que.
Posted on Nov 13, 2009
I have a hp laser printer p2035 & the top symbol is blinking what is it?
This symbol represents a paper jam. Try removing the paper tray and opening any doors available to find the paper in question.
Oct 16, 2012 | Office Equipment & Supplies
I want to use non HP Ink ! but this happened !!!
Send a test print to it from the printer properties. If you did not have any issues before you re-charged the printer cartridge, try another cartridge.
Oct 10, 2012 | HP Photosmart C7280 Laser Printer
How can I get my HP Laser Jet 1320 printer to get unlocked from red flashing light that prevents prnter from working? When I printed a three page e-mail report, after the first three were printed, an...
I had similar problems with my Printer also. Believe me, it can happen if the printer driver is corrupted or if your windows installation or windows update caused some conflict issues with the printer. I got online help from TheBestPcDoctors. If you need, you can contact them or call them
www.thebestpcdoctor.com or via 877-407-9229
Sep 27, 2011 | HP LaserJet 1320n Printer
What does the "heart beat" symbol/light mean?
I assume you mean the symbol that has a pair blackened circles and then a pulse up and then down below the starting line before returning to the starting line.
That is the paper jam symbol. If the continue light is on (steady) and the paper jam light is on, then you have a paper jam. Press Continue twice to see any secondary error message (this will show where the problem is).
See the manual for the list of the lights that show where the jam is occurring. Different groups of lights will be lit. The manual is available as a PDF at the bottom of this page: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN . An example: if the Continue, Toner Low and Paper Jam are all on, then the jam is in the fuser area under the print cartridge assembly. For a paper jam, even a small corner of torn paper could be in the mechanism.
In all cases, you should check the entire paper path. When you pull out any paper, grip it so that you can gently pull the sheet straight out. Remove all paper from the output tray. Then remove the paper tray if you are using it. Pull any paper from this area. Press down on the green duplex flap and remove any paper from there Reinsert the paper tray. Open the front door of the printer and remove the print cartridge assembly. Lift the green flap and remove any paper from the area. NOTE: the fuser and the fuser area may be hot. Open the rear exit door and remove any paper from that area. Use a flashlight to check for small pieces of paper that may be stuck. Once all the paper is removed, reinstall the print cartridge assembly and close all the doors. Press Continue to reset the printer.
The page that jammed may be reprinted.
I hope this helps.
(please note that frequent paper jams may be a sign of excess humidity in the paper. Put less paper in the tray at each refill and keep the remaining paper in a dry location. If the paper jam light is coming on when no paper jam is present, one or more of the paper jam sensors may be bad. Contact Lexmark for more information.)
Nov 30, 2010 | Lexmark E250dn Laser Printer
This morning I thought I would print out some Shamrocks (for T.S. windows) on green paper. I put the green 8 1/2 x 11 in the bottom tray and asked the printer to print 5 copies. It would print 1 copy and a...
Was the green paper the type kids use in school. When my kids were little we called it contruction paper. If this is the case, your printer is smart enough to know that this paper is thicker than normal. It's responding as it should. Next time you want to print on this type of paper - select this in your printer's software control panel.
Feb 26, 2010 | Office Equipment & Supplies
Printer will not stop printing
look at bottem right there is a little printer symbol right click on it then cancel all jobs
Sep 20, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Printing problem
try re-installing or updating the printer driver
Jun 07, 2007 | OKI C5200n Laser Printer
283 people viewed this question
jasbo
jasbo
