Question about Toshiba TEC B-472 Thermal Label Printer
TEC 472 QP PRINTER
HI
TRYING TO INSTALL TEC 472 PRINTER BUT DRIVERS DO NOT HAVE A MICROSOFT SIGNATURE????
IS THERE A FIX FOR THIS PLEASE?
THANK YOU
  • MGOMEZ684 Jul 28, 2008
    HI
    THANK YOU
Try with CUPS --- oh, sorry, it's for Linux only, my bad
Posted on Sep 10, 2008
Tec b-472 gap sensor
use detection transmissve in the driver
Aug 13, 2012 | Toshiba TEC B-472 Thermal Label Printer
I HAVE B-472-QP TOSHIBHA THERMAL PRINTAR. BUT STILL NOT WORK. sOTWEAR and dreives is good and use cables 21 pin lpt cables in local. plz tel me detail wt happan our printer. any cable...
Take care the DB25 at the back of the printer is a serial port
2 =RX
3 = TX
7 = Gnd
Speed 9600,
No parity
1 stop bit
Un less you have a centronics connector but it is optional
Jul 01, 2011 | Toshiba TEC B-472 Thermal Label Printer
Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
Apr 22, 2010 | Toshiba TEC B-472 Thermal Label Printer
All ok but not print
2 possibilities.
- The communication parameters are not correct
Try 9600 bds
8 data bits
1 stop bit (defaults)
Or the control character is not correct
See parameters
Jul 21, 2009 | Toshiba TEC B-472 Thermal Label Printer
Our tec b-472 qp only blinks the online green led when a job is sent to the printer but does not print. we have set up printer with proper driver from Toshiba and are using serial cable 25 to 9 pin. Serial...
The serial cable for the Tec printer must be wired straight through (not a crossover cable). Are you using the original cable that came with the printer? Do you still have the manual? there are some dip switches in the top right hand corner of the inside of the printer that control the serial port settings. If you have the manual and look in there check that they are set to default settings.
Feb 06, 2009 | Office Equipment & Supplies
Toshiba TEC B-472 is not recognised by PC
This printer is not plug and play, you will need configure with the driver. If your driver is from Seagull, you have a option TOOLS, and it is possible to send a test.
Jan 26, 2009 | Toshiba TEC B-472 Thermal Label Printer
TEC B 472 QQ
Swapping the parallel port to the printer should allow it to connect via parallel. Run through front panel diagnostics before/after install. depending on firmware it will tell you if the parallel board is installed.
Nov 09, 2008 | Toshiba TEC B-472 Thermal Label Printer
Tec 472 qq no print
First of all can you print just from the printer ie
Turn on the power while
holding down the [FEED]
key and [PAUSE] key?
May 18, 2008 | Toshiba TEC B-472 Thermal Label Printer
Toshiba TEC B-472 Thermal Label Printer Logo
870 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
 steve
steve
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
