Question about HP ScanJet 8290 Flatbed Scanner
Bad or fading scanner lamp (-4430) - HP ScanJet 8290 Flatbed Scanner
  • 468 Answers
Replace scanner lamp
Posted on Nov 25, 2009
HP imaging device could not be initialized because of lamp error.
Does the lamp in the scanner come on at all? If not, then it is most likely bad. You can try disassembling the scanner and check that the lamp connectors are not loose.
Jun 21, 2011 | HP Scanjet G4050 Flatbed Scanner
ERROR MESSAGE lamp was over Canon DR-1210C driver
lamp was over Canon DR-1210C driver verion 1.01.10601.23003(-4430)
Sep 29, 2010 | Canon DR-1210C Scanner
We have a Cannon DR2580C, it has been working well for several years. The image is now starting to fade on the right side, so we no longer have the entire image
I would try and clean both sides of the glass.
If this does not help, probably time to either replace or look for a replacement lamp
Aug 04, 2010 | Canon DR-2580C Path-Through Scanner
Lyris F199 fades in and fades out
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 24, 2010 | Mag Innovision LT976S 19" Flat Panel LCD...
HP Scanjet 5590 Lamp Error "Bad or fading lamp (error -4430)" Fixable? Can I do it? Best source to purchase?
From HP forums:
The first thing I would do is to make sure your TMA is properly attached. Next, make sure your software is up to date and that any applicable patches have been applied.
Next, what OS are you using? What application are you trying to use to scan with? Can you scan from any other application such as word or another graphics program?
Oct 06, 2009 | HP Scanjet 5590 Flatbed Scanner
"warming up" all the time
If you go to the Canon Support site for this scanner they have a firmware upgrade that seems to specifically address this problem:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2204&modelid=13057
May 02, 2009 | Canon DR-1210C Scanner
Dark area on scanner output
you need a new CIS array, or the lamp is going bad. With all due respect buying office equipment on ebay is like shooting craps.
http://www.websitetoolbox.com/mb/copierquestions
Nov 13, 2008 | Ricoh Aficio IS420 Flatbed Scanner
Unreconizable image
Try updating your scanner driver/software to isolate the problem. If same issue still occurring after uninstalling/reinstall, then source of the problem may be a CCD/lamp failure or some sort of dust, lint, on CCD causing calibration failure.
Sep 03, 2007 | Pacific Image PrimeFilm 1800u Film Scanner...
Horizontal Banding
From the Microtek KB: www.microtek.com Scans that produce lines, fading, and discoloration generally result from a corrupt scanner driver installation or a burned out lamp. To determine if your problem is caused by a burned out lamp, simply open the scanner lid and check the color of the lamp. If the color is a shade of red, pink, or green, then the lamp is burned out. Perform a scanner preview to get a clear view of the lamp. If the lamp is a bright white and the problem still exists, please contact technical support.
Jun 06, 2007 | Microtek SCANMAKER 4850 Flatbed Scanner
HP ScanJet 8290 Flatbed Scanner Logo
785 people viewed this question
Seeker5211
Seeker5211
