Question about Sewing Machines
I have a GE Spacemaker XL 1800, and it suddenly has stopped heating. All things appear to work except there is no heat. I would assume a faulty door switch wouldn't allow anything to work, so potentially am ruling that out. Only thing that seems a little odd is the keypad panel is loose at the top. I tried holding it in incase there was something there, but no difference. We cleaned the interior last night, and again I shouldn't think that would make a difference. There is a circular panel in the ceiling of the oven that shows a direction to open or close, but it won't turn. Any ideas? Some sort of reset switch inside? Thanks
  • knickc Nov 13, 2009
    Does it make sense to have it repaired, or like most things these days just replace it?
    Thanks
    Unfortunately I can't repair it myself, unlike clothes washers, dryers, etc, so it would appear a new machine is in the offing.
  • Sewing Machines Master
  • 3,051 Answers
Hello there:
If everything comes on when it is started, like the light in the cavity and the fan (which one can hear running), and the timer counts down but it doesn't heat, the problem is probably isolated to the high voltage section of the oven.
If the display is on and the oven won't come on and run, there may be a problem in the door interlock system or the thermal protection system.
The cited symptoms and possible causes are general and some slight variation may exist in a specific machine. But the bad news is the same. It's this: there isn't much a user can do to fix the problem without exposure to extreme hazards. There are dangers lurking inside the metal box we all use so frequently (to the point we just about take it for granted). And they can be fatal. Don't even think about trying to repair a microwave. Be smart and be safe. The life you save may be your own.
Posted on Nov 13, 2009
  • Michael Thomas
    Michael Thomas Nov 13, 2009
    Hello there again
    thanks for the post
    To be honest with you you would probably spend more money on having it repaired than what you paid for it.
    simply because of this the labor and the parts will probably be around 150 dollars alone
My machine stops working, the lights are lit up on the computer head, but doesn't do anything when the peddle is pushed.
there is an electronic unit that is failing and over heating
I suggest that you take it to a service agent to have it properly diagnosed
it could be the motor itself or the speed control that is faulty.
Oct 01, 2015 | Sewing Machines
Bernina activa 145. suddenly the machine doesn't stop stiching. it continues stitching at a lower speed. help it's driving me nuts !
There are a few possible issues that could cause this. Over time the carbon contacts inside the foot control can corrode and send a faulty signal to the machine. It is also possible that one of the needle stop sensors is out of place or faulty. These are the two most likely causes of this symptom, however it could be caused by a number of things including a faulty main PC Board. My recomendation would be to take your Activa to the nearest BERNINA dealer and repair center to get it checked out.
Sep 30, 2015 | Bernina Sewing Machines
How to unlock the handwheel of my signer quantum xl-1000
Check the bobbin area and make sure there's not a tangle of thread keeping the hook from turning.
Feb 14, 2015 | Singer Quantum XL-1000 Computerized Sewing...
I have a Keurig B66 and it has suddenly stopped working. The Keurig heats up and the display shows ready, however we cannot choose cup size. Is there something that we can do to fix it?
Call Keurig directly. They have awesome customer service and if they cannot assist you they will send you a replacement. This is the link to their troubleshooting page which also has their contact information:
http://www.keurigtroubleshooting.com/Keurig-Coffee-Brewer-Problems.html
Jan 13, 2014 | Husqvarna Viking 1
Singer quantum xl 1000 sewing machine
. sounds like a PC board issue. Can be $$$.
Oct 18, 2013 | Sewing Machines
Machine keeps stopping and says to turn it off
Hi. Is there an error number on the screen? may i have the exact error message that appears on the screen.
Sep 11, 2010 | Singer Quantum XL-5000 Computerized Sewing...
Everything appears to wok except it does not HEAT
sounds like your high voltage fuse is blown if your microwave has one also you may have a high voltage problem like blown diode capacitor or transformer to check these you need the right test equipment remember microwaves run on very dangerous voltages please take extreme care if not confident call an expert
Nov 06, 2009 | Sewing Machines
Stops sewing
Your machine is over heating. Sometimes it may also get stuck and just continue to sew and you will have to unplug it. Mine would also flash to just a blue screen. It had a pinched wire on the inside that caused it to over heat.
Apr 22, 2008 | Sewing Machines
Wheel won't turn
The same thing happend to me with an older model (Singer XL 10). I have been sewing a decorating stitch and the machine stopped suddenly. Now I am not able to turn the hand wheel anymore like I should (I can move it a little bit, but the needle does not move up and down and the wheel is getting stuck). When I try to use the pedal the motor makes a horrible noise and stops. The needle is not moving up and down.
Is there a solution for that problem? I moved from Europe to Australia and have not used my machine since. Today is the first day, I was cleaning and oiling it and it first sewed perfectly. In case that there would be thread stuck somewhere, how could I possibly clean that? I already took off the plastic from the head, but I can not see where the problem is.
Any help is appreciated. Thank you!
Best regards,
Nelly
Jan 12, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
20 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
