Question about Endless Summer (GA200209) Stainless Steel Open Flame Patio Heater
Patio heater model 233000 has clicking when pilot light held down but will not ignite with gas open holding down for 1 minute
  • 193 Answers
Clicking is electric iginitor making a spark. I WOULD CHECK the pilot orifice for blockage
Posted on Nov 14, 2009
No pilot light, been standing unused for some time.
You may well have to purge the gas line as there will be air in there , as the pilot injector is very small it would take ages for the air to come out .
Sep 05, 2011 | Endless Summer 233000 Open Flame Patio...
Will not fire up!
If the pilot comes on but goes out straight away then replacing the thermcouple should sort out the problem. If not pilot you may need to run a gas leakage test, see patio heater problem solving on how to do a leakage test. There are some very helpful guides from a specialist patio heater company.
May 13, 2011 | Endless Summer 233000 Open Flame Patio...
Pilot light wont ignite on patio heater
It may be that your cylinder is malfunctioning, cylinder has a leak, or the pilot is clogged. Please see steps below to troubleshoot. Note:Regular maintenance is critical to the successful operation of your patio heater.
  1. Is the cylinder valve closed? If so, open the cylinder valve but not fully.
  2. Check to see if you can light it manually. If the unit lights manually but not with igniter, service or replace igniter switch.
  3. Ensure that there is no air in the gas line. Open the gas line and bleed it (pressing control knob in) for not more than 1 - 2 minutes or until you smell gas.
  4. There may be a blockage in the orifice or pilot tube? Bugs and spiders get into the pilot assembly, venturi tube and burner ports causing the unit to either not light or poor performance.
  5. Is the regulator hose pinched or kinked?
  6. Cleaning the pilot assembly.
  7. If the piezo igniter won't spark to light the pilot, check the wiring to the igniter, It may simply have lost it's ground. Slide the wire off the igniter prong (looks like a thick needle) on the pilot assembly and then push it back on. That usually will reestablish the ground.
If you continue to have problems with the heater, contact Blue Rhino (the manufacturer) Customer Care 800-762-1142.
Hope this helps you to troubleshoot and solve the problem. Please let me know.
Apr 21, 2011 | Uniflame 200209 Open Flame Patio Heater
The pilot seems to light but then when I turn the knob to ignite the main burner, the pilot goes out. Is there a technique to clean the igniting assembly?
let the pilot light burn for a few min and get hot after this try slowly moving the knob over to full burn. Sometimes it just need to heat up.
Feb 14, 2011 | Endless Summer 233000 Open Flame Patio...
Once I get the pilot light lit , hold for 30 seconds, and the let the knob out to turn to low or high, the pilot light won't stay lit.
From what you're describing, either the Thermocouple needs cleaning or it needs replacing, However, these are not easy units to work on for a Do it your-selfer. so I would recommend taking it in to a pro who can get the part if necessary and replace it if necessary. Most independent hearth stores that sell and service gas logs and gas fireplaces can help you.
Jan 24, 2011 | Endless Summer 233000 Open Flame Patio...
Can't light. Pilot lights but then wont light when turned to on.
There will be a flame sensor on the gas valve. Replacing the gas valve (if it comes with the sensor) will get it working.
Dec 27, 2010 | Uniflame 233000 Open Flame Patio Heater
The pilot light will not stay lit to light the heater.
The power pile (pilot generator) is defective. It produces a milivolt signal to ensure to keep the gas valve open. If it goes bad, the valve thinks the pilot is out, even when you are holding the button down, so when you release the button, it shuts the gas off to prevent excess gas buildup and a possible explosion.
Sep 10, 2009 | Coleman (5040B750) Patio Heater
Unit will not light
you probably have a clogged pilot assembly or pilot tubing this is usually an aluminum tube that runs to the sparker try to pullit apart and clean it
Jul 05, 2009 | Uniflame 233000 Open Flame Patio Heater
Endless Summer (GA200209) Stainless Steel Open Flame Patio Heater Logo
156 people viewed this question
Top Endless Summer Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
