Question about Dell Inspiron 6000 Notebook
I need to swop my line in and line out ports round as the line out dont work any more can you help
  • 3,940 Answers
You have 2 choices:
  1. Replace the motherboard (If you are extremely good at circuit card soldering you might possibly be able to replace the, but that is beyond most people)
  2. Disable the on board audio and use a PCMCIA audio solution like this one:
http://www.soundblaster.com/products/product.asp?category=1&subcategory=205&product=10769&nav=4
Posted on Nov 14, 2009
Need diagram of the back of a emachines Desktop that shows where everything plugs in
what model do you have? most older emachines, gateway and dells are very similar...1) round purple ps2 to keyboard, 2) round green ps2 to mouse, 3) teal oblong serial 1 is older output to modem, 4) blue oblong vga output to monitor, 5) reddish long oblong is parallel port to printer........ all these are usually not used on newer models...others include a white oblong for dvi to monitor, or small rectangular for hdmi to monitor, as well as the traditional usb 2.0 and usb 3.0 for a multitude of input and output usages...... small round female ports are for sound.. pink for mic, green for main speakers, black for rear surround, gray for side surround, orange for center surround, and blue for line in....may also have an esata port (not used much) and a ethernet port for internet connection (looks like a slightly bigger telephone jack port).... might have a spdif (sony phillips digital interface) for digital audio.....hope this may help...
Jan 03, 2014 | ASUS Essentio Desktop with Intel Core 2...
My xbox 360 slim doesent read my games any moore it just says open tray it does not work!!
hello mate you need replacement drive dont try it your self because its not like the ps3 where you can just swop over the drives il do it for you visit my website xbox360repairspro.webs for more help
May 24, 2011 | Microsoft Xbox 360 Console
One handset on our Panasonic KX-T7730 system has gone wrong. I can get a line on Co 1 and Co 2 but the Sp-Phone mode is always on. As soon as I switch back to Co 1 or 2 to speak direct into the handset the...
Swop the handset for another working one and see if you have the same problem. If it nows works on then its the handset that has gone faulty. if its the same then the extension on the system that has developed a fault. If you have any spare extensions (keyphone ones that is, then just swop the plugs on the system and the faulty extension will now be a new extension and should work ok.
May 23, 2011 | Office Equipment & Supplies
Tiolet not flushing right. Water not coming down the side of the bowl when flushing and 90 percent of the water is gone from the bowl.
1- Check ports out under rim all round bowl.
2-Check tank fill level for required amount to with in 5/8" to top of over flow tube.
3-Make sure 1/4" fill tube is connected to over flow tube. From fill valve to overflow tube.
Below is a few details to go by I hope will be helpful for you to take care of this problem.
Under the rim of the bowl check the ports and make sure they are not stopped up. You can open them up with nail or pin to clean out ports.
Next check tank level and make sure the fill valve has a line run from it to top of the overflow tube. This line allows water to goe to bowl and tank to fill required amount needed.
Water in tank should be within 5/8" to top of over flow tube.
Jun 22, 2010 | Pegasus Technologies Two-Piece Round...
Mouse can not work
this is usually do to a port going out or the total failure of the mouse.. or if it's a rather old mouse, the ball underneath is too worn to work.
if it's the port, there are 2 kinds, one is a round port (PS/2), you will have to turn off the computer to remove the mouse from this type of port.
if it id the round ps/2 port, you will have to either get a new mouse using usb, or you can try a new ps/2 based mouse.
REMEMBER you cannot plug in or remove a ps/2 mouse while the computer is still on!
The next port, and most common is the usb port. it's a small rectangle.
You most likely have atleast 4 of these on the back of your computer, and most of the newer computers have 2 on the front, sometimes in a hidden panel.
Sometimes if you are a windows user, windows will set a usb port aside for what normally resides there, and a mouse in a port that usally houses a printer usb plug will make windows not see the mouse sometimes.
Removing a usb port mouse is rather easy, you dont need to turn the computer off to do so.
Before considering replacing a usb mouse, try putting it into another usb port. sometimes this will work. also, see if the lights are working underneath when plugged in. (optic mouse, not ball mouse).
if you have determined that your mouse is broken, then the next step is to replace it. bestbuy sells mice for about 25-30 dollars.
if you dont mind waiting 3-7 business days, a reputable online retailer like 3btech.net can sell you a mouse for about 15-20 dollars, and 3btech does not charge for shipping.
usb mice can be found here:
http://3btech.net/keyboardsmice1-us.html
ps/2 mice can be found here:
http://3btech.net/keyboardsmice1-ps.html
Jun 17, 2010 | Computers & Internet
A/C is blowing warm on a 2005 Trailblazer
Not for absolute sure on this, but look on the passenger side firewall. There is a round aluminum can. That is the filter/drier. The port will either be on it or on the line coming out of it running toward the front of the motor. Hope it helps.
Jun 24, 2009 | Heating & Cooling
Cant find low port for AC charging
The high side is a big red cap on it. follow the other line around should be a blue cap smaller dia. it should be a round the engine bay, so you can access it with your gauges.
look hard and you will find it.
Jun 23, 2009 | 2000 Ford Focus
Hi i have 2x alpine swr-1222d'd and need to build a ported box for them. I am running a alpine mrd-1005 to power them. I'm trying to work out how to use the program WinISD to work it out but really dont...
what you do is, you find the volume of the inside of the box, then go to a port calculating website and type in what you got....be 100% sure your numbers are right, then pick if you want 1 or 2 ports, round or square, again be sure you get all the numbers right....if you dont, youll end up with sloppy joes in the trunk.......need any more help let me kno....
Mar 13, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Web cam
Most of the Web cams dont have build in mic, but if you had it with your cam, try to plug in the red plug at the back of your CPU in the red plug in beside the green plug in. use plug and play wizard that helps you to try the mic of your cam if it really works.
Feb 27, 2008 | Dell Microsoft Windows XP Home Edition
Dell Inspiron 6000 Notebook Logo
46 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
