Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore side by side
Model # 106.56566400
seriel # SR2329669
Ice maker not working. no ice in ice maker. I checked water supply to valve. All OK. LED beam is solid red. OK What gives power to water valve? I filled water to ice maker, waiting to see what happens.
  • Anonymous Mar 24, 2014
    kenmore model 59429801
    kenmore model #59429801
    Scholar:
  • 27 Answers
Your motor module is bad on the ice maker. It is located on the left side when mounted in the refrigerator. It is under the White Cover over the end. It is brown in color. To verify the correct problem, the ice stripper arm in the ice maker that turns and pushes the ice out of the mold, should be pointing up towards you when it is in the mounted in the refrigerator. I call it the 2 O'clock position. If the ice stripper arm is pointing another direction, it is broken. I sell the module on Ebay as username, themackshack. My parts are genuine factory parts. Good luck!, Mack
Posted on Jan 08, 2008
I have a Kenmore model number 106.51552104 my ice maker stopped making ice.. The water on the door still works but no ice what should I do??
I believe I answered this one on another page of unsolved problems HERE. Thanks for the model number. If the ice slots inside the ice maker are empty try pouring tap water in the slots and allow the water to freeze. If after the water freezes the ice drops into the ice bucket and the ice maker does not refill this would indicate that the side of the=> W10408179 Water Inlet Valve is defective on the side that controls ice maker water supply. If the ice maker just sits there and does nothing this would point to a defective ice maker. Depending what is wrong with the ice maker will determine what parts are replaced. Here is a list of those parts here=> Kenmore Refrigerator Model 106.51552104 Ice Maker Parts and if need you may be able to find a complete ice maker replacement by asking. Most people don't like replacing ice maker parts. I am here should you have questions or comments, Sea Breeze
Aug 30, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
HI THERE.ice maker not working has many reasons.but try these checks first1-stop /start leaver or switch.2-water in ice tray.if not fill manually first and try.if works once 3-check inlet valve or water supply.if all ok then is either the ice machine or pcb .good luck Ali
Aug 23, 2012 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
What's your problem?ice maker isn't working
Assuming the coils underneath the ice box are clean and the ice box freezer section is running under normal operating conditions so that the ice mold thermostat can close contacts @25F, their are 2 suspects. The ice maker itself and the ice maker's water supply valve. Most of these supply valves have 2 solenoids for ice maker and water through the door. If the water valve is ok then the ice maker is bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 27, 2011 | Kenmore Side by Side Refrigerator
No ice is being made.
Most likely either water valve is bad or ice maker is bad. You would need to determine if Ice Maker is sending voltage to water valve. If it is, replace valve. If it's not, replace ice maker. Also be sure filler tube going through back wall is not frozen. If it is, replace water valve.
Sep 02, 2017 | Kenmore 22.0 cu. ft. Side-By-Side...
The ice maker is not working. The freezer
check the water valve located at the back/lower portion of the unit,get check for continuity, if your tester deflected to the right coil is ok, next, check for possible clogging, sometimes trapped dirts accumulates in the valve filter, it restricts the water going to the icemaker module.check your tap sir or flojet pump, if you are using bottled water.,
Mar 18, 2010 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 5483300 side by side. no ice!
your fridge will have a dual water inlet valve, one for water and one to supply water to the ice maker. it could be that the solenoid on the valve that supplies water to the ice maker is not working.
Nov 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker not working.....water is working....
This is techcrazy
the solution to the problem is as follows
Feb 02, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice maker not getting water from water valve
you will need to replace the water inlet valve on the lower back of frig.easy,let me know how you do-mike
Oct 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore side by side refrigerator model 106.5702 will not make ice.
your ref board seems to be working fine
Did you test the water valve???
if yes and water valve works, than replace the Ice Maker
May 11, 2008 | Kenmore 53703 / 53706 Stainless Steel Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
155 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
