Question about Microwave Ovens
I have a frigidaire dishwasher model # FDB345LBB1 and it will not drain out all the way, I have taken the hoses of clean them and still water in the bottom.
  • 715 Answers
A little water is supposed to stay in bottom so the pump will not loose prime
Posted on Nov 13, 2009
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
I have an older model kelvinator dishwasher and there is water in the bottom of the dishwashwer and the diswasher will start and then stop but will go through all of the cycles. It just doesn't do the...
Pull the dishwasher out of the slot. There is a motor underneath that runs the pump to drain it. The usual cause is the it has a bad connection.
May 28, 2011 | Microwave Ovens
Purchased Model # EWDW6505GS from Lowes in Tigard, Oregon today. It was the floor model and did not come with a manual for use and care (I got online) or with a drain hose. Where do I find a drain...
the drain hose for your dishwasher needs to fit the plumbing in your home. Measure the size of the connection at the drain (under the sink) and possible use the old hose as a model for what you will need. Lowes sells a hook up kit but be careful to measure the size of the outlet on bottom of the dishwasher and size and distance to the drain connection. Sometimes addaptors are used to size down the outlet side of the hose. Also if you have the manual it may show the size of the outlet on the dishwasher.
May 01, 2011 | Electrolux Microwave Ovens
Machine goes thru all the wash cycle but gets to last min and keeps spinning then comes up with f11
Not knowing what sort of machine you have, one of these should help.
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
F11 - Pump cannot be activated - Book a washing machine repair.
F11 - Heater timed out. The heater has not reached the required level. Book a dishwasher repair.
F11 - No pump connection - Book a tumble dryer repair.
Mar 17, 2011 | Microwave Ovens
Water is leaking on then freezing on the floor of my upright frigidaire freezer. At first I just thought it was a fluke and cleaned it out, but he next day their was frozen water again. I also am finding...
Your freezer goes to a defrosting cycle and actualy melts away some ice formation inside the freezer, normaly this melted ice (water) drains trough a tube in the back of the frig... the drain is probably clogged and the water spils out... to unclogg it you need to find the uper end of the drain (where the water drips in) usualy way in the back of the frigidaire, than try pushing a long wire in downwards to unclogg the drain, also check underneath or in the back of the frig. ther should be a back to hold the water for the time it evaporates, see if it is not full of water or dirt (dust) i even foud some pet toys in there once ha! ha!
Hope this helped!
Mar 02, 2011 | Microwave Ovens
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    When my dishwasher drains both sides of sink fill with water...then they both eventually drain back into the dishwasher.
    Sounds like your sink drain trap or line is clogged. When the dishwasher drains, the sink drain can't keep up, the water backs up, then backs down the dishwasher drain line into the dishwasher. You may not notice the slow line when you run a little water into the sink, but with the amount of water coming from the dishwasher the problem is worse. You can try taking off the trap under the sink and making sure it's clear. If the problem is farther down the drain line, you can try snaking it yourself, or call a plumber. I don't recommend using Liquid Plumr or Drano because if those don't work, they leave the line full of caustic chemicals for the next person who works on it. That can be dangeerous.
    Dec 07, 2010 | Microwave Ovens
    I have a bosh dishwasher that has not drained of water and the tap light is red on the indicator board
    Hello there:
    Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
    If the motor isn't turning or working, the unit won't drain. Some dishwashers are susceptible to getting stuck if you don't run them regularly. I you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
    Jul 08, 2010 | Microwave Ovens
    Dishwasher does not drain. Drain valve is very hard to work and has burned out the solenoid. Can you tell me exactly how to get these parts out of the dishwasher. Do I have to replace the pump to replace...
    Hi
    Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
    First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Feb 09, 2010 | Microwave Ovens
    The dishwasher will not drain during the normal cycle. I turned the power off and removed the drain hose and the water drained out. I disconnected the drain hose from the sink drain and was able to...
    Can you here it drain pump when it time to drain. If you do not Then your pump is bad or the control board is not sending a signal to the pump. To see if you get a signal to the pump you can use a electrical tester to see if you get current.
    Jan 06, 2010 | Microwave Ovens
    Microwave Ovens Logo
    60 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
