Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Plasma tv television will not switch on.no power getting to it. checked fuses, leads etc
    Genius:
  • 1,153 Answers
Can you check R964 for loose solder or open? for more info ctechnicians.com
Posted on Jan 08, 2008
Hitachi LCD TV Dead
There is a internal fuse on the power supply board. When you plug in the set, does the standby light come on?
May 10, 2013 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
Lg 50pq20d plasma tv not switching on but voice comes out
Aside from checking the fuses it likely will require a technician or a shop to examine the set to see what is wrong and what needs to be replaced.
Sounds like a power supply issue but that would need to be checked.
Jun 10, 2012 | LG 50PQ20D 50 in. HD-Ready Plasma TV
Sony wega KE-42M1 .power lead ok . no power at tv. (no standby or power light showing at on switch). house power went off , when it came on tv wouldn't work
This confirms that the main power supply which is the SMPS is faulty.
The fuse could have failed and must be checked, if the fuse fails the SMPS is confirmed to be faulty due to the power outage.
please check the links below for tips and support:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Sep 21, 2011 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
No power going to LG 42 inch plasma, tried changing fuse in plug and tried a different power lead and still nothing (no standby light etc)
since you have change the fuse in plug, this indicate that your plug is okay, the likely problem is from the television which will require you to open the television to check for fuses, bulged capacitors, but if otherwise your power supply is dead.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this help.....
Jun 16, 2010 | LG 42PC3D 42 in. Plasma Television
Plasma lg 42'' not powering on after electricity went and came back , when tv was on(electricity blackout)
NO LIGHTS ATALL ON TV/ SURGE OF ELECTRICITY CAN BLOW INTERNAL FUSE/OPEN IT UP WERE THE MAINS LEAD GOES TO BOARD CHECK GLASS FUSE/SILLY I NO BUT CHECK PLUG/IF NOT DAMAGED POWER SUPPLY
IF SO OHM SUPPLIES FOR REPAIRS OR PARTS UK ONLY
Dec 04, 2009 | Televison & Video
No power - have checked fuses, power leads and master switch
Well yes, there a problem in the power supply modual.
It does sound like a failing power supply , becuse of the
fact you don't get charge up spark from the plug , wich is normal
affter it's been off /unpluged for 20 min or so .
check the resistance of the plug coming from the set with a volt meter if you have 10 meg ohms or higher,
it's an open circuit and more than likely a 1.50 fuse in the power
supply. If the fuse blows instantly then it's a shorted output transistor or rectifier diode in the switching power supply.
Be a shame to pay 300.00 plus for a stupid fuse.
hope that helps a little . if you have any questions just comment
an i'll respond
Rob
Oct 03, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Dell w4201c burning fuse...
hello, definitely if your fuses are blown and your not able to circut trace and find the fualty compnents on the pb then repalce it with a working power supply this may help but also keep in mind you may want to check everything out first get your models service manual so you can verify voltages at test points. something is cuasing the fuses to blow so if you do change the power board and you blow the fuses again then you will need to trace the circut and find out where the short is and what panel or part is cuasing it .
hope this helps
Jan 10, 2009 | Dell W4201C 42 in. Plasma HDTV
TV switch off randomly
It is a Rely in the Power Supply. Need to have it changed out. Cheap part.
Dec 29, 2007 | Samsung HP-R4262 42 in. Plasma Television
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
