Question about Frigidaire FGB24T3EC Gas Double Oven
After 2 years, the hinges have already warped and broken. Can they be replaced, or will I need a new oven? Is this a problem with this particular oven?
  • Frigidaire Master
  • 3,463 Answers
Generally speaking, it is possible to replace the door hinges on the majority of ovens be they gas or electric.
Please leave feedback.
Thanks.
Posted on Nov 13, 2009
This hinge has snapped in two Can it possible be welded back together again?
It depends on what material it is made from. The easy answer is yes most materials can be successfully welded but some materials are more problematic than others and need specialist equipment and skills.
If the material is mild steel you will have no trouble getting the welding done once the hinge has been removed from the door and the oven. I think that could be the major problem of the exercise.
A hinge wouldn't break for no reason. I think it would be wise to discover the reason before carrying out a repair. I suggest checking the price and availability of a new replacement hinge from the manufacturer before going ahead. The broken hinge might be a design flaw (whoever heard of a broken oven door hinge?) and a replacement might be a modified part that would resist breaking.
It is possible a new part could be cheaper than having it welded but you won't know until you check.
Apr 02, 2016 | Ovens
Why does oven door stick out at the top about 1/2 inch when closed?
then call him back to fix what he forgot to do Adjust it
Oct 28, 2015 | Ovens
What replacement parts should I order to keep my Kenmore oven door from just dropping down when it is opened?
If the hinge is not broken "Check the Springs".
They sometimes come off at one end or can be broken.
There are 2 one on each hinge. They are strong so be VERY careful.
As I remember they have a color code according to how strong that are according to the weight of the oven door.
The surest way is to get the MODEL NUMBER from the tag on your oven. The parts store will be able to look up the proper replacement.
I may be able to tell you more with a model number for Identification, the oven is likely a Whirlpool Product made for Kenmore. Let me know if you are in New York City area.
Hope this helps.
May 19, 2015 | Kenmore 47783 Electric Single Oven
GE Oven door lock 'engaged' while door was open and door will not close - how do I release the lock?
If your oven door has gotten bent or warped (maybe you rested something heavy on it...), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Dec 06, 2010 | GE JTP27 Electric Double Oven
Door hinge on hygena single electric oven broken
You neede to replace both door hinges.
To get more detailed instructions on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR HINGES.
You should then click on the appropiate link, and follow the instructions.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Ovens
The hinge on our westinghouse silhouett oven door may be damaged as the door will not give a tight seal can it be repaired or replaced and how, the rest of the oven works like new.
If it is a drop down door, then the hinges are not repairable, the only solution is to replace both door hinges, and not just the broken one.
Hope this helps.
Jan 30, 2010 | Ovens
Door does not close tightly ? problem with bottom hinges
Yep, sounds like the hinges/springs have been overloaded.
Dont know if it's a Neff problem in particular, but I had a Neff oven with exactly the same problem - it was already installed when I bought my house.
Spoke to Neff who advised this ocours if heavy things like a roasting tray with a heavy bird / joint in it is rested on the door whilst it's open.
Only cure is new spring/hinge units which are not cheap !
Sep 18, 2009 | Neff B1421 Electric Single Oven
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Replacing the ceramic top
I remove the whole hinge and top from the back put the old hinge on the new top then move the burner to the new top put the whole hinge on the back of the oven.. hope is is a little help
Jun 11, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
Frigidaire FGB24T3EC Gas Double Oven Logo
85 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
