Plasma tv connections
I have 2 satellite dishes and 2 receivers How do I hook both along with a DVD hard drive recorder to my new plasma tv. I am in my late 60's and am not real good with electronic gadgets - can you help me
  • 2,427 Answers
Hi ,,
Ok First off your Plasma has 3 inputs , 1 ,2,3
Here is what i would have done and what you can do.
First of your recivers has RCA output, thats 1 yellow cable and 1 red and 1 white,
The red and white are audoi and the yellow is video
1.) Connect your dvd player to input 1 in your Plasma.
just follow the color codes, yellow to yellow, white to whit, red to red,
2.) connect the other Reciver to input 2
using the same method
3.) connect the dvd to input 3
using the same method..
So now if you want to view reciver1 you set the tv to input1, reciver 2, input2 , dvd , input 3
In the event that your tv does not have 3 seperate inputs
you can go to your locol electctronics stor and purchase an RCA switch box
this is a device that has 3 seperate RCA inputs, a switch to slect which one you want to use and an output to connect to the tv, Simply connect all your devices to the RCA switch, and then connect the rca switch to your tv..
There are other methods of doing the same thing, but i chose this one as its the most simple solution
let me know if you are having any problems
Posted on Jan 08, 2008
  • Rishi Roshan Ali Jan 08, 2008
    Please Note :: In the unlikely event that you may require an RCA switch, you can find it at your local electronics store. Some people have it listed as an RCA Multi Switch, Multi Switch and SpNT Switch, Tell tham you want an RCA switch or a Multi Switch For RCA Cables
    Genius:
  • 1,153 Answers
With your Plasma tv, you have many inputs like Video1,2,3 and so on. You also have Composite Video inputs and also DVI-HD, all you would have to do is to hook Satellite 1 into 1st input and Satellite 2 into 2nd input and Dvd can go to any or all inputs. If you use the Composite video, just make sure you get the right cables for it, because this is a different color then the regular Red, White, Yellow cables, These will be the Green, Blue, Red cables input. Hope this helps! and just change tv input to the one you place the sats on.
  • 796 Answers
I fear tat is not possible.....do u have two jacks on the dvd recorder....is yes means reply,,,,,by the time i ll search for your problem.....thank you
    Novelist:
  • 189 Answers
What you need is a device called a multi-switch. Here's a page which details some of the switches available with different satellite setups. You would hook up your sat recievers, your TV and your recorder up to the multiswitch:
http://www.satellite-connection-systems.com/Multiswitches.html
I have aquired a dish dvr, i do not have the dish servicem however. I want to know if i can still record a program and watch it later. Thank you
It is highly unlikely. The unit unlikely has any inputs other than the coax cable coming from the satellite dish. This will is the same 75 ohm cable connection you see on your tv used with antennas or cable service, but the tuner in the satellite box only decodes satellite signals.
Sorry about your luck. I recall some manufactures such as LG making DVD recorders with hard drives inside them. Those units can capture any analog signal. Another idea is to get a TV tuner card for your computer.
Jan 05, 2015 | Televison & Video
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
Connecting tv with dish satelitte reciever and dvd player
"I would like to be able to record from the satelitte."
Are you trying to record your satellite programming onto a DVD recorder? If so, the recorder needs to be connected between the satellite receiver and the TV. If this is still a problem please indicate the recorders make and model number.
Mar 16, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
How to hookup vcr to TV to tape from satelitte
have a look at ur install bock it will tell u how to do it...connect antenna to ur vcr then use cable from ur vcr output to ur tv antenna ,,,,,after u have done this read instruction .....to connect ur dvd ....just plug ur cables from ur dvd to the back or ur tv....marked as dvd input....
cheers and good luck......very simple.....
Mar 06, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
How do I hook up the recorder
Hi....
Take the output of the Satellite box to the "In from antenna" or "in from cable" then out to TV from the VCR to the TV.
TV should either be on 3 or 4 depending on what the satellite box is set for
Feb 18, 2009 | Sansui VRDVD4005 DVD Player/VCR
Dvd recorder to satillite
if your dish satellite has an extra A/V output or if your plasma tv has the outputs and the recorder has the same type input AUDIO/VIDEO jacks
Oct 11, 2008 | Televison & Video
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
Composite Video hook-up question
Generally, you only need one 'full' set of connections. If you are using s-video, you'll still need audio red and white or fiber...not both. Fiber is better. Where are you going to get your audio from? That's where you'll want to direct your feed. Some people cheat and run the red/white to the TV when they're too lazy to turn on the receiver! Mute it if it annoys you.
Dec 28, 2007 | Yamaha HTR-5730 Receiver
Denon DRA 395 volume creeps to max by itself
I also had this problem with my Denon DRA 395. I fixed it by replacing the batteries in my remote! Apparently when the remote batteries are nearly gone, but not 100%, they are capable of prompting the remote to unilaterally increase the volume at irregular intervals. It was kind of spooky!
Oct 01, 2007 | Audio Players & Recorders
Changing Channels
Unfortunately, no. The tuner in your DVD recorder works differently than how your satellite receiver works. You *must* use the satellite receiver to select the active channel, and then send that channel to one of the inputs on your recorder. You can then record that channel. Unless your satellite receiver is has "dual tuners" in it, you are stuck watching the same channel that the DVD recorder is recording. If your goal is primarily time-shifting of shows (as opposed to archiving shows forever to DVD), you might consider getting a different satellite receiver with a built-in DVR (hard disk recorder). These allow you to mark shows in advance, have them recorded to the hard drive, and then you can watch them whenever you want, skipping all the commercials. You also get the ability to pause and rewind live TV.
Apr 14, 2007 | Panasonic DMR-E50 DVD Recorder
Computers & Internet Logo
436 people viewed this question
Alun Cox
David Payne
David Payne
