Question about Maytag Neptune MDG5500AW Gas Dryer
My dryer is making a high pitched squeal? - Maytag Neptune MDG5500AW Gas Dryer
    President:
  • Maytag Master
  • 1,922 Answers
It could be the rear drum bearing,the front drum glides/rollers or the drum belt is glazed,or the tensioner for the belt needs replacement,all of which require you to remove the front cover by removing the lower front panel screws near the floor, then lift up front cover like a car hood and there are spring clips that will let go, then remove top cover these screws are underneath top cover in front and you can replace those items
Posted on Nov 13, 2009
  • 460 Answers
Sounds like either the motor or drum bearings or bushings are going bad. have your maytag service man look at it and let me know. email..jregsr9304@gmail.com i like feedback. goodday..
3 Suggested Answers
SOURCE: SQUEAKY DRYER
HOW DO YOU ACCESS THE REAR DRUM TO APPLY THE OIL?
Posted on Mar 31, 2009
dragonsthatk
  • 547 Answers
SOURCE: dryer squealing?
you need to replace the felt around the door if it is not this it is in the motor and I would just use it tell it dies then replace. thank you for using fixya
Posted on Jun 19, 2009
HIGH PITCHED dryer SQUEAL but clothes are drying...
Had same problem that went away after replacing each of the drum roller wheel/bearing assemblies. (repairclinic.com) Not the easiest of jobs removing & replacing the drum, but a lot cheaper than a new machine.
Nov 23, 2013 | Frigidaire Washing Machines
When i run my GE Clothes Dryer, It has a high pitch squeak How can I fix this
remove the front panel inside there is what is called the top door bearing,its probably worn through the drum slides and into the plastic bearing creating this squeal part # WE3m26
Feb 10, 2013 | GE Dryers
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
Dryer makes squealing noise when running. What's wrong?
the idler or tensioner wheel that your belt rides on has a bearing in the center of it. This bearing is going out causing the high pitched squeal your hearing
Jan 23, 2011 | Fisher and Paykel DGGX2 Dryer
Squeal when dryer turning
The problem is that your dryer needs a new drum bearing.
Jul 25, 2010 | Fisher and Paykel DEGX2 Dryer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
There is a high pitched squeal when i use my dryer
Jockey wheels are worn you need to renew if not too old ...over 7 yrs
Apr 08, 2010 | Frigidaire GLEQ332A Electric Dryer
High pitch squeal-metal on metal contact
A lot of dryers have plastic or felt slides on the drum. This is to reduce friction as it rotates. They are probably worn off.
Dec 24, 2009 | Maytag MDE4806 Electric Dryer
Squealing noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
98f
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
High pitch squeal
IT IS MORE THAN LIKELY A STUCK DRUM ROLLER OR IDLER PULLEY. I HAVE SEEN IN WORST CASE SCENARIOS WHERE IT HAS BEEN THE MOTOR ITSELF WHEN SUBJUCTED TO LOTS OF LINT AND DUST FROM PLUGGED VENTING. I WOULD CHECK THE FIRST TWO AS THEY ARE THE MOST COMMON. DO NOT OIL THEM.
Dec 28, 2008 | Maytag MDE2600 Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
402 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
