Question about Polaroid TDX-03211C LCD TV
Polaroid TDX-02611c was on and fine, until it just turned off by itself and wont turn back on. More than 1yr since purchased. Now what!?
  • 1 more comment
  • Jorge Morales Nov 13, 2009
    I just located the fuse in the power cable mount, and the fuse is ok. I tested continuity with a multimeter... it is ok. Any other hints!? I also searched for blown out caps... they look fine and dandy the lot of em. I merely opened the rear plastic cover... the center part. Its all good so far... any hints will be amazingly appreciated...
    Following the post on Solution #1 I checked the boards again, and completely removed the screws on the input panel (where you plug all the cables on the back of the tv set) and inspected the back of the two boards in there. Nothing burnt, or outta the ordinary. Fuse as I said on comment1 is ok, and capacitors do not appear blown up on the power board (assuming the board on top is the power board...).
  • Jorge Morales Nov 14, 2009
    Emaili sent
Polaroid should stop making tvs untill they can make one that will last longer than a year
Posted on Jan 25, 2010
  • 11,361 Answers
Look at the power supply module first, see if you see blown fuse, burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 13, 2009
Testimonial: "Step by step budmrtn helped me diagnose my problem via e-mails with pictures and everything. Truly a great help indeed! Thanks!"
  • 3 more comments
  • Bud Martin
    Bud Martin Nov 13, 2009
    OK, now we need to take some voltage measurement, we need to look for 5vdc standby voltage, you MUST have this voltage before going any further. Look at the coonector for labelling such as 5vstby, 5vby. Can you also the number of the board itself, send me some pictures will be great, budmrtn@aol.com
    What ever you do, you must plug the TV into GFCI outlet or isolation transformer before working on it, lethal voltage presents!
  • Bud Martin
  • Bud Martin
  • Bud Martin
  • Bud Martin
TDX 02611C. Why doesn't it turn on?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 09, 2016 | Polaroid Televison & Video
Polaroid hdtv tdx-03211c turns on for 10secs or so and goes blank
More than likely your t.v has bad capacitors that power up the light bulbs that light up the screen. I had the same problem with a similar Polaroid t.v. and replaced two bad capacitors and that solved the problem. Take the back off of the t.v. and look for capacitors that are bulged at the top. The capacitors have the model number on the side. I found replacement capacitors at www.digikey.com for a very low price. Here is a video that you can watch on how to replace the capacitors. https://www.youtube.com/watch?v=YCSNWi3UHf4
Jul 11, 2014 | Polaroid TDX-03211C LCD TV
Remote control code for the tdx-02611c
02967,02917,02911. Try these codes. If you wish to get more, check the sites linked here.http://electronicshelponline.blogspot.com/
Dec 23, 2013 | Polaroid TDX-02611C TV
Polaroid TDX-02610B 26 LCD TV DVD Combo dvd, card reader and monitor in wont work.
how do I get my dvd to work it says loading and the after 30 second it reads no disc?
Jul 05, 2012 | Polaroid TDX-02610B LCD TV
Polaroid TDX-02610B, Tv was working fine, turned it off, now when I turn it on it flashes polaroid then goes black.
If it is only the screen going black but the TV remains on and you can hear audio, then there is a problem with the backlight. It could be due to bad capacitors or it could be a faulty inverter. It requires repair by a competent engineer.
Mar 07, 2011 | Polaroid TDX-02610B LCD TV
No Picture only sound polaroid tv tdx 03211c
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Nov 25, 2009 | Polaroid TDX-03211C LCD TV
No picture on 32" Polaroid
Your inverter boards need to be tested and serviced, these are circuits designed to control the light behind the LCD glass panel. It could also be the power supply not feeding 24volts too the inverter circuits. In that case the power board would need servicing.
Take it back if its under warranty if not get it serviced at your local repair center..
Nov 08, 2009 | Polaroid TDX-03211C LCD TV
No sound with HDMI connection.
COULD BE A BAD HDMI,,CHECK TO SEE IF ITS TURNED ON ON THE CABLE BOX
May 15, 2009 | Polaroid TDX-03211C LCD TV
Polaroid TDX-03211C LCD TV Logo
1,294 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
