Question about Philips 37PF5521D 37 in. HD-Ready LCD Television
Taking TV from UK to Australia
I've bought teh Philips 37PF5521D in London and I am now moving to Australia (Brisbane). I believe that PAL I, used in the UK, is 625 lines, UHF PAL G is 625 lines UHF but with a different audio frequency.
Can I get my TV to work in Australia? Is there a setting on my TV? Is there a converter I can buy?
regards
Denise
    New Friend:
Hi we have just moved out from the UK. I had to buy a digi box to get my Sony and panasonic to work. Both flat screen tv's with in built tuners.
Posted on Dec 18, 2012
  • 476 Answers
The TV has a setting for Australia in the Digital setup menu, so there shouldn't be a problem.
The mains voltage in Australia is 240V - 50Hz, so you should only need to change the mains lead.
If you decide to go ahead, when you set up the tv:
Switch on tv.
Press and hold "MENU" on the side of the tv.
Menu will appear on-screen.
Continue to hold until menu clears.
Wait.
TV will reset to factory settings, allowing you to re-tune the tv.
Posted on Apr 18, 2008
We bought a veon tv in NZ and now have moved to Australia. The tvs country is still NZ. How do I change it to Australia.
get the on screen menu up and look for the area transmission format
Australia is PAL
Sep 22, 2016 | Cell Phones
Power board for 37pf5521d
hello!
You don't need to replace power supply in most cases. If you can to the board itself, it buried deep under metal shield, up side down, remove it from the set by unscrewing 6 machine screws, unplugging few plastic connectors. Be careful, connectors are fragile, gently move those in every direction, while pulling out male part of connectors. You will find at least 1 "bloated" electrolytic capacitor, remove and replace those. It's good have "in circuit" capacitor checker to determine quality of "hot side" of power supply capacitors. If you won't find and replace those, small: 1mf 10mf or 22mf, your set will start up, might even work fine for a while, then will quit for good! I've seen that happen! If you don't have capacitor gizmo, then replace all small electrolytic capacitors on "hot" side of power supply. "hot" is that side, what connects to main power in plug area, contents one large capacitor, I.C. chip diver, power mosfet, etc. worst case scenario: if you can't replace those parts yourself, remove the board and take to local TV repair shop. It won't cost you that much to do so, compare to complete TV repair.
Good luck,
Alex.
Feb 19, 2012 | Philips 37PF5521D 37 in. HD-Ready LCD...
Hi there! I have a KDL-46NX800 that i bought in the USA will it work in London lime watching cable tv. I know that tv in the USA is NTSC and in London is PAL but does the Sony have both? Thanks!
Hello bryanj_t,
Yes there are Sony tv's that does have both. When your looking for these tv's, look for tv's that are multisystem. Multisystem tv has both NTSC and PAL. Good luck
-Joe
Aug 29, 2011 | Televison & Video
Does anyone know if the L37G10A supports PAL I as well as PAL B/G. I'm moving from Australia to UK and am wondering whether to bring the TV
Screen Type LCD Panel Type IPS-alpha Progressive Full-HD LCD Panel Panel Aspect Ratio 16:9 (Widescreen) Aspect Ratio Control Modes (TV/AV modes) 4:3, 14:9, 16:9, Just, Zoom1, Zoom2, Zoom3, DTV: 16:9 & 4:3 Full Aspect Ratio Control Modes (PC mode) 16:9, 4:3 Comb Filter Yes Progressive Scan Yes TV Tuner Receiving System DVB (Digital), PAL-B/G (Analogue) Tuner Type Integrated SD/HD DVB-T 7MHz Australia, PAL B/G
Contrast Ratio 1 - Dynamic: 20000 Picture Adjustment Modes / Film Modes Normal, Dynamic, Cinema, Eco Colour Temperature Control Cool, Standard, Warm
May 21, 2011 | Televison & Video
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
Cant get the new digital tv schannels
HELLO
There are differences in the frequencies used in NZ and Australia and this is why you cannot pick up ALL digital stations in Australia.
Example: NZ uses PAL B @ VHF and PAL G @ UHF
AUSTRALIA uses PAL B @ UHF and this is why the channels differ.
I would think the only way to get round this problem is to buy yourself a terrestrial set-top box or satellite box and then you will get all digital stations.
I have a motto: Always buy your TV in the country you live in. It would be like me taking a UK TV to France - the systems are different including the digital channels. Put this down to experience - you've learned the hard way!
ALL THE BEST!
Oct 05, 2009 | Samsung Televison & Video
We are moving to the UK and have a couple of
you need to have an AC converter, also the tuner from the TV's may not work since they have another format (PAL) and the DVD players are a different region.
Apr 24, 2009 | LG 42LC2D 42 in. LCD HDTV
We have just moved from he uk to perth
I beieve you have a TV standards prolem. According to the chart available at the website below, the UK is PAL I and the Aussies use PAL B/G. So if you bought a TV in Australia and are using the DVD Combo from the UK I think you are out of luck. A reputable TV repair shop would be able to answer further questions about this without charge.
http://www.kropla.com/tv.htm
Nov 27, 2008 | GE 27GT271 TV
I am looking to replace my TV with a Flat Screen LCD. This will be used in France in conjunction with a Skybox to receive Free to air transmissions. I believe the system used by the skybox is PAL. Are the...
edtwit, In my honest opinion, Philips does more than a campble job of adjusting to skybox's requirements. I would also suggest a adaptor if you find out that you need one of those too.
Overall it should be straight plug and play.
Please post what you do and how you did it. I look forward to your posts.
Nov 11, 2008 | Philips Televison & Video
Open Questions:
See all Philips 37PF5521D 37 in. HD-Ready LCD Television Questions
Philips 37PF5521D 37 in. HD-Ready LCD Television Logo
237 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
