Question about IBM NetVista PC Desktop
IBM Netvista powers up for only 3 seconds
I have a new refurbished IBM Netvista computer that turns on (fans & DVD drive lights) for only about 3 seconds and then shuts down. This computer powered up fine the first day I got it and then the second day it will not power up. Every time power is applied it gives the same result: power for about 3 seconds, then it dies.
Any ideas on what could be causing this?
Thank you
k1224_2000@yahoo.com
  • jitt May 11, 2010
    for this type of problem you have to check SMPS output voltage also.do one thing just remove all connection like hdd,fdd,cdom drive and then try.
    Scholar:
  • 152 Answers
If you have to wait some minutes to restart it, that is overheating...try putting a ventilator (the bigger the better, the thing here is give lots of air to the processor > CPU) and see how its working...
Posted on Jan 08, 2008
When turned on will not start
hi
check the master and slave settings if you are using IDE hard drive.
if using SATA drive check bios setting is set to detect drives at boot up
some motherboards use ide settings for Sata drives
if this is not the problem check ram is inserted in the correct slots on the motherboard too
Nov 17, 2012 | IBM NetVista M42 PC Desktop
NETVISTA CANT DISPLAY AFTER XP INSTALLTION
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Aug 15, 2012 | IBM Netvista Intel Pentium 4 1.8GHz /...
Pisplay not shown
Display not shown?
1) Does the monitor show No Signal?
If so go on.
If not;
Use another known to be good monitor, and monitor cable, on your desktop computer. Be aware that the problem may be the monitor cable.
Or use your monitor cable, and monitor, on another KNOWN to be working computer.
The monitor isn't receiving a Video Signal. Means the signal is not reaching the monitor. Could just be a bad monitor cable.
2) If the monitor is good, and the monitor cable is good, the problem is the computer itself. The computer isn't working.
You may see LED lights light up, hear fans running, and maybe even the Harddrive spinning.
Problem could be the Power Supply.
A) IF, all of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan only uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
(Older Intel Pentium III processors, and AMD Athlon processors, use less power than 51 Watts)
Not enough power? BIOS will not turn the Processor on.
Solution is to test the Power Supply's 3 main voltage power rails, or use another KNOWN to be good, COMPATIBLE power supply, for a test unit.
The 3 main voltage power rails are;
A) 3.3 Volt power rail
B) 5 Volt power rail
C) 12 Volt power rail
Test is done with an economical Multimeter, set to DC Voltage.
Post the model number of the IBM Netvista desktop computer. You will find it on the back of the computer, next to the Windows product key,
(XXXXX-XXXXX-XXXXX-XXXXX-XXXXX), or up on the side of the computer tower.
Post in a Comment.
Regards,
joecoolvette
May 20, 2012 | IBM NetVista PC Desktop
I have a refurbished ibm netvista. when i turn it on, the cpu fan will start to spin for a few seconds, then i'll hear a weak beep, then the fan will stop spinning (power off), then the fan will...
Remove the hard drive and RAM. See what it does. It should go into BIOS and complain. If it doesn't you have a motherboard issue as it won't POST.
Dec 24, 2010 | IBM NetVista PC Desktop
Not startup
You need a another
harddrive.
Jun 07, 2009 | IBM NetVista Intel Pentium 3 1GHz / 256MB...
Ibm netvista trying to boot from a non-existant lan system.
With my netvista I was able to get boot options with F12 when powering up. I don't know if this will help you because I was installing a new hard drive. Larry
Mar 06, 2009 | IBM NetVista A40 PC Desktop
I just bought a refurbished netvista pent4 2.4g. from computer geeks. it has no O.S. or drivers
Dear Transtripper,
It shows that your IDE option is not enabled in the BIOS. So, enable the IDE Controller in your motherboard.
Thanks,
Sep 26, 2008 | IBM Netvista Intel Pentium 4 2.4GHz /...
IBM NetVista Doesn't Start up
"the computer does not turn off"
So something started up? Fan? Hard drive?
Jul 10, 2008 | IBM NetVista PC Desktop
IBM netvista won't power up
might be a faulty motherboard, RMA the board and see if still occurs
Jun 09, 2008 | IBM Computers & Internet
IBM NETVISTA P4 2.4G. no O.S.
If your old copy of win xp is not being used by any other computer then reformat the entire drive with xp. Also make sure that your drive is not divided into 2 or 3 sections. All updated will be available on the windows update site. The reason that I prefer tostart from scratch is Everything is new with no lingering Junk programs in the background. Need help email me at ddugard@cox.net
Apr 13, 2008 | IBM Netvista Intel Pentium 4 2.4GHz /...
IBM NetVista PC Desktop Logo
214 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
