Question about Samsung SGH-G600 Cellular Phone
Flickering screen/back light when using - Samsung SGH-G600 Cellular Phone
My new Samsung SM-T310 tablet screen flickers so much I cannot use it. is there a fix?
find out if the actual display or just the back lights are flickering first .
turn on a good flashlight lay it on the face of the display when lights go out if the picture remains then it is the back lights not the display
but either way i believe you will end up replacing the display (backlights included( and probably LEDs) ) i will look at availability and feasability of this, come back with item model number and year
Jan 12, 2015 | Samsung Galaxy TabPRO SM-T320 16 GB Tablet...
P206HV acer screen flickering
I believe that screen has a fluorescent light as the backlight. It could be going bad. If it's still under warranty, contact Acer support. If not, you could try replacing it, or look into getting a new one.
Jul 14, 2014 | Computers & Internet
My hp CPTOH-0602 was flickering and then stopped and now the screen is dark with a big black area in the top left corner
it was a screen back light failure, the lamp get busted in the upper portion of the panel display. to access this part you will need to remove the back cover using a philip screw driver. the back light is covered with metal shielding.to replaced the back light, be careful in disassembling the cover not to damaged the lcd screen panel.
Nov 26, 2012 | Televison & Video
Flickering screen like bad flouresent bulb
you need to remove the back cover of the tv to gain access the internal part. and then you need to look if their is a loose contact or dry joint connector at the power inverter board for the screen back light. if the connection is good then their is a flickering the back light is need a replacement.
Nov 12, 2012 | Televison & Video
Pinstripe cinema display flickers on momentarily then goes black. Image comes back for a split second while when power light glows steadily then goes away while power light flickers. this is a 22"...
when the screen is black and the power light is steadly lit, shine a flash light at the screen. if you can see something, the inverter board is bad and the back light cannot turn on. if the power light flickers, reseat the power plug and put your ear to the back of the monitor where the power plug is. if you hear a buzzing or any high pitched noises; the power supply is bad. use the macufactures warranty for repairs.
Nov 18, 2009 | Computers & Internet
I have a fujitsu lifebook N6460 the screen flickers and goes out
Sounds like you back light or LCD inverter is going out, If you don't hear a whine then it is just the LCD screen, if you hear that whine then it is the inverter. An inverter will run 40-60 dolloars as opposed to and LCD screen which usually start around 100 and go up...
Hope this helps, if so please rate my solution accordingly.
Since it seems as though you dont move it very much you might be able to hook an external monitor up to it and using the Fn+F5 button swap it to use the external monitor untill you can get it repaired.
Mar 18, 2009 | Fujitsu LifeBook N6460 Notebook PC...
Hp Laptop screen flicker
I am sure that the issue is related to the cable that connects to the LCD Display or the LCD Backlight.
There should be some connection shortage because of which the LCD flickers few times as stated by dan231.
I Recommend you to get the Notebook examined as soon as possible before something really goes wrong...
Dec 05, 2008 | HP Pavilion dv6000z Notebook
Samsung SGH-G600 Cellular Phone Logo
55 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
