Question about Video Cameras
Jvc gr-dvx9 E04
Hi everytime i turn the camera on a warning flashes on the screen saying E04 : unit in safeguard mode/ remove and reattach battery.
i have removed and reattached the battery countless times just for the same warning to flash up again. please help!!
  • 1 more comment
  • Anonymous May 09, 2008
    I have the same problem i took off the batterie many times and the same thing pops up safegaurd also it wont accept tapes.please help.
  • Anonymous Oct 16, 2008
    the massage on screen saying E04:unit in safeguard mode/remove and
    reattach battery.
    done that but problem is still there.
    please help.thankyou.
  • nbrown9249 Apr 10, 2009
    Exactly the same - sometimes works for a few minutes though then gives the error.
    Happens on Battery or using tyhe 'battery-mains' adapter
The mechanism is out of sync, put a tape in and hold it, it wont go in but will try to open don't let it, remove the battery and reattach, let the tape eject, rinse and repeat 3 or 4 times and it will finally accept the tape.
Posted on Jun 12, 2009
How can I Release cassette from my JVH 300x
Posted on Aug 03, 2010
When i switch on my JVC GRDVX9 it says on the screen E04 unit in safe guard mode remove and reattach battery
Following are the solutions:<br /> 1. Through your camera in dustbin;<br /> 2. crush it with hammer <br /> 3. Put it on fire
Nov 09, 2009 | JVC GR-DVX9 Mini DV Digital Camcorder
Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Apr 28, 2009 | JVC Video Cameras
Hi, Regarding the above fault with my JVC camcorder, I have solved the problem by removing the tape and replacing with a new one. Thanks anyway.
Regards,
**** Coupe
Mar 30, 2009 | JVC Video Cameras
Safeguard Mode
What error message appears,it should say E0..
May 27, 2008 | JVC GR-D20EK Camcorder
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
E01-E06 Unit in safeguard mode
I had this same problem, and indeed it was from leaving a tape in the camcorder while in storage. All I did was remove the tape and put a new one it. Solved my problem! Thank you!
Dec 03, 2007 | Video Cameras
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
Video Cameras Logo
920 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
