Question about Gateway GT5220 PC Desktop
My 2 year old out of the box Gateway GT5220 boots up as usual but there is no video signal from the onboard video card. No modifications to this unit at all.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi, When you first turn the computer on do you see a splash/post screen or is the computer beeping at all?
    Problem Solver:
  • 12 Answers
After verifying this issue with a second monitor, it would seem a new video card would be in order. As far as I cant tell this model has built in video, often referred to as integrated. therefore replacing the current video component will not work. You will need to install a PCI-E video card. Often referred to as PCI express. This computer has one slot available for a PCI-E card. If that doesnt solve the issue then the problem extends past simply the video signal.
Posted on Nov 13, 2009
Install new video card in Gateway GM5072 with Pheonix bios and disable oonboard video
There should be an option to disable the onboard VGA connection within the BIOS of the computer.
Plug your monitor into the onboard video output to do this.
Dec 24, 2011 | Gateway GT5220 PC Desktop
I have a mobo C51PVGM-GB that I would like to upgrade the video card and not use the one built into the Mobo.
You are upgrading the graphics.
Instead of using Integrated Graphics, you will be using a dedicated graphics card.
Integrated Graphics is also referred to as OnBoard Graphics.
On the motherBoard.
The GPU (Graphics Processing Unit) is soldered to the motherboard.
It is not a video (Graphics) card.
A dedicated graphics adapter card has it's own GPU, and graphics ram memory.
http://en.wikipedia.org/wiki/GPU
Information on the Gateway 4006136R - Nvidia GeForce 6150 AM2 uBTX 1394 motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006136R/4006136Rnv.shtml
Viewing this small photo of the motherboard, the Orange long slot you see is a PCI Express x16 slot.
1) The Northbridge chip is a C51PVG
2) The Southbridge chip is an MCP51
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100_and_6150_series
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply Processor for short)
3) Made by ECS
4) Has an AM2 processor socket on the motherboard, for AMD processors.
Continued in an additional Comment.
Jun 12, 2010 | Gateway GT5220 PC Desktop
Signal to monitor not coming through. monitor works fine on another computer.
This could happen if you have two graphic cards installed ( Eg. Onboard as well as an expansion Card ). Try Connecting it to the other port if you have more than one.
It could also mean that your Graphics Card is broken.
Feb 24, 2010 | Gateway GT5220 PC Desktop
Turns on fan runs but no info to the monitor doesnt seem to boot
If the Monitor is displaying no infomation at all, your display signal from the PC to the monitor has failed.
1: Check the cable between the monitor and PC
2: If you are using onboard graphics then that display port is faulty.
3: If you are using a graphics card then remove it and try the onboard graphics.
4: Your monitor maybe faulty aswell so test it on another computer to be safe.
Its more likely to be option 2
Jan 15, 2010 | Gateway GT5220 PC Desktop
When I turn boot up my gt5220 the monitor briefly flashes and then goes into power saving mode- desktop stays on, fans running and all, until turned off by holding power button down or unplugging it.... my...
first try to connect another power source if it does work that is good then try the other options 1- rams 2- vga card 3- cpu 4- of course there is always the motherboard option....
i had the same problem several times mostly it is the power supply ( the power source ) sometimes gives a weak voltage or amps....
Dec 02, 2009 | Gateway GT5220 PC Desktop
Gt 5220 video card problems
The pcie slot in which you are using the card may be some problem , you can try by clening the same by some electronic card cleaner liquid spray. And again try to put the card and boot the system.
Apr 22, 2009 | Gateway GT5220 PC Desktop
Signal to monitor goes in and out, mostly out
Hopefully, it is just the on board video that has gone bad, and not the motherboard. When you install a video card on a PC, that has on board or integrated video, you will need to access the BIOS screen on start up and disable the on board video. That way the video signal will come from the new video card and not the on board video.
I hope this helps,
Eric
Jan 18, 2009 | Gateway GT5220 PC Desktop
No Video Signal
reboot in safe mode, safe mode will put the pc in vga mode and use whatever video it can find.
If no good U may have a problem with the MB.
May 23, 2008 | Gateway GT5228 PC Desktop
Motherboard - disable onboard graphics
1. open your cabinet.
2. remove the battery form the motherboard.
3. wait 15 seconds and then replace the battery again.
4. connect your screen to the pci ex card.
now it should work.
CS
May 15, 2008 | Gateway GT5220 PC Desktop
Gateway GT5220 PC desktop boot issue.
I had this same problem and tried a million trial and error steps to try to fix it. Finally, I tried replacing my keyboard that came with the GT5220 with an IBM keyboard from an old PC. I have had no problems since. I believe the root problem in the keyboard was affecting somehow they way the system unit was coming out of sleep mode. Good luck.
Jan 22, 2008 | Gateway GT5220 PC Desktop
Gateway GT5220 PC Desktop Logo
178 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
