Question about Stanton STR8-60 Turntable
I need a replacement for broken dust cover hinge model str8-60
I just broke mine, argh. Did you find a replacement part?
Posted on Jun 07, 2010
Looking for dust cover hinges for a SL-1900 turntable
Fixya does not sell replacement dust cover hinges.
Sep 18, 2016 | Audio Players & Recorders
Where do I get set of hinges for dust cover of AKAI AP-X1 turntable
Check on ebay for that tt and maybe someone has parts listed. Or try the manufacturer but if a unit is more than ten years old parts are usually no longer available.
Nov 22, 2015 | Audio Players & Recorders
Where can I find dust cover hinges for the above model?
Dust cover hinges can be like hen's teeth!
The message I am looking it from you shows no above model, but you can ask the makers if they are still around for spare part suppliers. Otherwise it's off to E-Bay to see if anyone has one second hand.
Nov 04, 2015 | Audio Players & Recorders
Mu laptop hinges are broken. I wanted to know what problems this may cause? Sometimes when I tipe words, it doesn't work in the screen. This could be related with the broken hinges?
Laptop hinges are generally made of low-cost metal alloys, or "pot metal yeah this may cause problem you can fix your broken hinges easily by spending little time ." Pot metal is not particularly durable, and over the course of a laptop's life cycle, repeated opening and closing of the computer's lid can cause wear that prevents the lid from staying in an open position. Hinges can also wear to the point that they break at the point of attachment, either on the lid or the computer's body.
Hinges are usually attached to the computer's frame via machine screws. In order to get the most life out of your computer's hinges, it is not a bad idea to perform a yearly inspection. Remove the hinge covers and check that the machine screws that secure the hinges are tightened fully. If screws are missing, contact the computer's manufacturer to order replacement screws; hinges missing screws are subjected to additional stress and can wear out faster if steps are not taken to replace the screw.
Lubrication of the hinge is possible, but not recommended; if the wrong type of lubricant is used, it could damage the computer's case or seep into the electrical components and further damage the computer. Consult a professional technician if you feel that your hinges require lubrication.
o Hinges can also be damaged when the computer is picked up by its lid, dropped from various heights or opened beyond the angle at which it should stop. In these situations, damage to the hinges may be of secondary concern, as component damage and data loss might have occurred. Depending on the amount of damage and warranty status, the computer may require complete replacement.
Laptop hinges are not indestructible, but their coverings and trim may show wear long before the hinges are actually in any danger of failure. Most laptops on the market include plastic hinge covers. The hinge covers can develop stress fractures from repeated wear; most of the time, this is not indicative of a hinge problem.
Some laptop hinges are housed within the bezel or trim of the computer's monitor or body. This, too, is generally made of plastic, and might develop stress cracks after a few years of use. Hinge covers and bezels are usually modular, and replacements are generally easy to find at low to moderate costs.
Repair
o Hinge problems can be mitigated with adjustments to the hinge's tension or additional hardware installation by the user. Brackets can be installed on the outer case to allow for hinge-like performance, or the screen can be mounted in a fixed position. If the screen is left permanently open, care should be taken to prevent damage to the screen and to prevent dust accumulation in the keyboard.
The lid and screen assembly can also be replaced, if the correct parts can be found. Replacement of the lid and screen can be cost-prohibitive, with parts and labor sometimes exceeding the cost of the computer.
Sep 01, 2011 | Computers & Internet
Hinges for top cover for HP officejet 6210- Q5820A
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
TECHNICS SL-B280 DUST COVER W/ HINGES
All parts are discontinued for this model. The SL1200MK2 dust cover will not fit this turntable. You can actually have a dust cover made rather simply and cheaply (depending on where you live). Just take the dimensions to a PLEXIGLASS or even a GLASS shop. You can even purchase the Plexiglass yourself, cut it, and glue it together. I would suggest getting it professionally done. You can use any high impact plexiglass. Get something that is resistant to scratches and discoloring.
- DJ PRO LAB
www.DJPROLAB.com
Apr 08, 2008 | Technics SL-1200 Turntable
Stanton STR8-60 Turntable Logo
766 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
