Question about Denon AVR-2802
Front speaker connected to A only,turned of A turn on B still sound coming from B without connection
  • 561 Answers
Do you get no sound when a and b are off?
suspect "a" switch is sticking in on position if it is an analogue switch it may need cleaning wih some switch cleaner spray and switcing on and off rapidly (do this with the receiver switched off) if not the switch may need replacement.
Posted on Nov 13, 2009
No sound from rear speakers Kia Sedona 2005 Front work fine with full sound but nothing from back speakers
Assuming the radio has an output for rear speakers and it is connected to them and you have selected the front/rear fader and attempted to adjust it to the rear, you can't do much more without removing the radio and checking the connections and the wiring to the rear speakers.
When I am faced with this problem I disconnect the speaker wiring from the radio and using a 9 volt battery and two lengths of wire I test the speakers and the wiring by connecting to each speaker in turn. A good speaker with good wiring will produce noise when the 9 volt battery is touched to the terminals. If there is no noise the speaker or the wiring is defective.
If all tests ok then the radio is probably faulty. This can further be tested by connecting temporarily to alternative speakers.
Jun 13, 2016 | 2005 Kia Sedona
Front Speakers stopped working
turn on your video and start something playing, press the speakers button repeatedly until the sound comes back. this should bring back your front speakers, if it doesn't, double check your speaker connections and sound field program.
the speakers button should cycle through all available front speaker options.
Nov 16, 2007 | Yamaha HTR-6030 Receiver
No sound from the speakers
check your connections if they are good another problem I could see possibly happening was if the wires for the speakers were plugged into the amp while it was turned on the wires may have touched together and blew the side out of your amplifier.
Dec 21, 2013 | Sony STR-DG510 Receiver
When I do a noise test I get no sound out of the woofer. I am getting no bass from the woofer
These are "decent" quality 5.1 speakers, usually without any trouble.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect but bass should be hear. Please switvh power off to the speakers and disconnect all cables from spaekers and connect them for best quality as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box, control pod is just cable connection to it
3. Connect all cables to they respective speakers
Establish location of the speakers, from experience, in ideal world:
1. Sub should be on about your knee level or below, about twice your hight from you.
2. Front centre speaker should be about some distance as sub or bit closer on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not while you are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre speaker, then on sides front speakers till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
Aug 12, 2010 | Logitech G51 5.1 Multimedia Surround Sound...
I bought these x 240 speakers used. do i need a driver to run them? where do i connect the plugs, black and green?
These are "decent" quality 5.1 speakers, new were on about $100.00 to $150.00, have two years warranty from time of purchase.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect.
Connect speakers as follows:
3. White plug is connecting to front left speaker
4. Red is connecting to front centre speaker
5. Black is connecting right rear speaker
6. Yellow is connecting left rar speaker.
Establish location of the speakers, from experience in ideal world:
2. Front centre speaker should be about twice your hight distance from you, on front and slightly above your head.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not whil eyou are standing.
5. Increase sound on centre button of the right fron speaker till you achieve equality of the sound
Aug 06, 2010 | Logitech X-530 Computer Speakers
Left speaker has developed a hum. Checked connections and all seems well. Sounds raspy like the speaker has blown.
This is likely due to a problem with the amplifier. You may have turned up the amp to the point of overdriving the speaker. The distortion at these high levels cause clipping and turn what was once crisp, clear sound into a muddied, garbled mess.
If the speaker is left connected to that source long enough, damage to the speaker and the amp may occur.
Without changing positions of the speakers: You can disconnect the affect Front or Rear L & R speakers and swap them (connect the L speaker to the R output of the amp and vice-versa). If the buzzing / hum "moves" to the other speaker, then the amplifier has the problem. If the buzzing / hum stays with the same speaker, the speaker has issues and is likely "blown".
Either way, it is probably not going to be a "cheap fix"
Jun 24, 2010 | Boston Acoustics VRS Micro Speaker
How do you install it correct
the audio source's output should connect to the inputs of the TS-WX11. caution on power supply connection: don't reverse the polarity of the positive and the negative wires.
Remember also to set your HU's output in order for it to work. If it does not work yet please give the details on your HU and other devices being used.
Aug 10, 2009 | Car Audio & Video
I removed my stereo for my 86 bmw 325 and now i am lost with the wiring.where do i start?
How to set up radio without wiring diagram : First you need to hook up the lead and ground power wire to your radio.(the lead usually has a line all the way down it). Turn power on to the radio and switch to am/fm. Locate any lead speaker wire and connect it to front right -. Then take all ground speaker wires one by one and touch them to front right +. As soon as you hear a sound, find out which speaker it is coming from, as soon as you have identified correct speaker remove wires from right speaker and mark them carefully. Do this with the rest of speaker lead wires an speaker ground wires and you will be able to connect your stereo.
Jun 16, 2009 | 1986 BMW 3 Series
I have my amp hooked up but it isnt getting any power can you tell me if i have a bad amp or if i need the speakers and sound for it to come on?
With all amplifiers for a car, you must have the main power connections B+ and ground connected, and then you must also have the remote turn on connected as well. This is the way the amp turns on. It comes from the radio and is usually the blue wire from the harness off the back of the radio. When the radio is turned on, the blue wire gets 12 volts sent to it so it can turn on an external device like an amplifier or the power antenna. Make sure you have this connected to the amp and that the radio is turned on. Then check the voltages at the power terminal of the amplifer. You will have the ground, the main B+ of 12 volts, and then the turn on voltage of 12 volts. If you have all of these, then you need to troubleshoot it more. It will turn on without the speakers connected, but I am not sure why you would want to connect it without the speakers. It will also turn on without the RCA cables connected for the audio input as well. But just to turn on the amplifier, all you need is those three things i mentioned. Let me know if you require any further help.
Jan 23, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Can't get all speakers to turn on in AV-1 function
can't seem to get the sound to come on. i knowe i have sound but will not turn on
Feb 09, 2007 | Amphion Mediaworks T-365 System
Denon AVR-2802 Logo
46 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
