Question about Motorola Mobility KRZR K1 Cellular Phone
White Screen. My screen started freezing now
My phone is new. My screen started freezing now and then. Then the inside screen turned white and the outside blue. A week later the outside screen shows again but the inside screen is still white. Any help on how i can fix this?
The screen will turn white and freeze up
how to fix my verizon wireless cell fone when the screen turns white?
Sep 20, 2009 | LG VX5500 Cell Phone
Blank or White screen on new Motorola Krzr k1 cell phone
i am having a same problem with my krzr phone. it is picking up the screen. solve if you can
May 27, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Phone continually goes to white screen, freezes, turns on/off
hi insane,
ur phone needs to b re-flashed. i.e its file system is corrupt. if u r not a techie guy then better take it to an repair center. otherwise chk this site out: mobilejunkies.net
this will work it out. good luck!
Jan 02, 2009 | Sony Ericsson W300 Cellular Phone
I dont know what is happening, nothing happened to my phone to my knowledge, it just went to a white screen. on the white screen it says --download started-- blank then it says, emergency @ usb, then at...
buy a new phone and try real hard nt to drop it the a920 tends to pack up when dropped as it happened to my last a920 and even telecom went to repair it but it was going to cost more than the price of a replacement a920
Sep 17, 2008 | Samsung MM-A920 Cellular Phone
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Samsung E250 white screen
Hello if you want you could get it repaired or type *#8999234*348# it restarts inside the phone so u will lose all your data on phone like games music pictures videos and phone book but it will fix it or pay $80 dollars for new screen if you want more help my email is danielp1236@hotmail.com and i fix phones all time i fix them my self pay $80 or come to me ill fix it for $25 plus warranty if it stuffs again. The white on screen means it forgot what was happening and just froze white and restarting by the code, Not just turning it of by holding red button, full restart by typing the code in the call screen any more worries about mobiles send me a email.
Mar 25, 2008 | Samsung SGH-U600
White screen on Motorola RAZR
I use to work for Cingular Wireless and this happened often. Try opening and closing the handset a little forcefully. It should re-seat the screen onto the contacts. If that doesnt help, have it replaced since its new. Best of Luck.
Sep 05, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Blank screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Aug 27, 2007 | Motorola Mobility RAZR V3i Cellular Phone
White screen
I have the same problem with my z3. I left my phone on the table, and all of a sudden, my normal screen was replaced by a flashing white screen. I called T-Mobile, and they had me try to reset the phone. You can do this by going to settings, then Master Reset. This will restore the original settings, and the rep said that sometimes this helps. Master Clear is the next step, which wipes everything off the phone. Nothing has worked for my phone, so I have to call Motorola today to try and get a new one. Good luck with your phone.
Aug 21, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Motorola Mobility KRZR K1 Cellular Phone Logo
555 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
