Question about Slik ABLE 300DX Tripod
I need to mount a ball head on it. What do I need?
    Scholar:
  • 105 Answers
Here is a guide to tripods with ball heads CLICK HERE
I hope this helps.... Good Luck!
Posted on Nov 13, 2009
  • Eric Malinowski
    Eric Malinowski Nov 13, 2009
    I found a nice ball head that can be mounted on a tripod.
    CLICK HERE
    Have a great day!
How to attach a canon 60D to pico dolly?
I use a ball head screwed to the pico dolly, then mount the camera on it. It allows me to lever or tilt the camera as I need. This is a small but easy head to operate: http://www.manfrottotripodparts.com/cgi-bin/commerce.cgi?preadd=action&key=1436
Jun 19, 2014 | Photography
How can I mount rc498c4 on my bogen 3001 tripod legs
Go to http://www.bogentripodparts.com/repairs.htm and the top right video shows how to remove and replace the head.
Mar 28, 2013 | Bogen Manfrotto 498rc4 Midi Ball Head W/rc...
How to change rear ball joints on 2002 dodge stratus
Instructions
  1. Remove the Upper Control Arm
    • 1Disconnect the ground battery cable using a wrench.
    • Loosen the front wheel lugs located on the same side of the upper ball joint you need to replace. Use a lug wrench.
    • Raise that same front wheel off the ground using a floor jack and support the vehicle on a jack stand.
    • Finish removing the tire.
    • Take the cotter pin off the upper ball joint stud holding the steering knuckle arm. Use a pair of nose pliers.
    • Remove the castle nut from the upper ball joint stud using a wrench or ratchet, ratchet extension and deep socket.
    • Loosen the two bolts securing the back of the upper control arm to the mounting bracket. Use a wrench to hold the bolt head as you loosen the retaining nut with a ratchet and socket.
    • Pull the control-arm ball joint off the steering knuckle arm. You may need to use a Pitman arm puller to free the ball joint.
    • Finish removing the two bolts from the back of the upper control arm and lift the upper control arm off the vehicle.
    Install the New Upper Control Arm
    • Set the new upper control arm in place and install the two bolts and retaining nuts to secure the back of the upper control arm to the mounting bracket. Remember the bolt heads should point inward toward the shock absorber with the retaining nuts on the outside of the mounting bracket. Do not tighten the bolts yet.
    • 11Insert the control-arm ball joint on the steering knuckle arm and start the castle nut with your hand over the ball joint stud. Do not tighten the nut yet.
    • Tighten the two bolts on the mounting bracket to 67-foot lbs. (91 Nm) using a torque wrench. Hold the bolts with a backup wrench as you tighten the retaining nuts with the torque wrench.
    • Tighten the ball-joint castle nut to 45-foot lbs. (61 Nm) using the torque wrench, ratchet extension and deep socket.
    • Install a new cotter pin through the joint-ball stud hole using the nose pliers. If necessary, tighten the castle nut just a few degrees to clear the stud hole through one of the castle nut slots.
    • Mount the tire on the wheel assembly and install the wheel lugs using the lug wrench.
    • Lower the vehicle and finish tightening the wheel lugs.
May 31, 2012 | Dodge Stratus Cars & Trucks
I am looking for advice on how to mount a Ball Head on the plate of a regular tripod, So far I have not found a Ball Head that has the same size thread in the bottom. Is an adapter available as a solution....
The bottom threads on most tripod heafs are 3/8", but some are 1/4"/ The mounting screws on MOST tripods are 3/8", but I have seen `/4" (especially on monopods. IF:
tripod=3/8 head = 1/4 need mounting plate 3/8 female to 1/4 male
tripod = 1/4 head - 1/4 nothing
tripod 3/8 head 3/8 nothing'
tripod 1/4 head = 3/8 there is an adapter/reducer that screws into the 3/8
' female and reduces that to 1/4"
Feb 20, 2011 | Photography
HI, I have a Bogen/Manfrotto 468/3435 Pro Ball head on a 3011bn tripod. How do I get this off of the tripod?
Hi, extend the extension and look under the mounting head. You will see three set screws requiring a slotted type screw driver. Loosen these off so the head is just protruding from the flange. Have the ball head locked in position and unscrew it from the center mounting stud Left to loosen Right to tighten.
Dec 12, 2010 | Cameras
I'm trying to attach a Canon EOS Rebel XS to a Manfrotto 190XPROB tripod, but the tripod socket on the camera is too small. How do I attach them?
You need a head. The tripod has a standardized screw for accepting a tripod head, which is a larger screw than for the tripod mount on the camera. There are a variety of heads available, ball heads, three-axis heads, geared heads, pan-and-tilt heads, and more.
Here's a page showing Manfrotto heads:
http://www.manfrotto.com/Jahia/site/manfrotto/cache/off/pid/1888?livid=80&idx=80
Aug 11, 2010 | Cameras
How do you replace ball joints
Removing the Ball Joint Step 1 Loosen the lug nuts on the front wheel assembly with the ball joint you need to replace. Do not remove the lug nuts.
Step 2 Set the transmission in neutral (manual) or park (automatic) and raise the wheel off the ground using a floor jack. Then support the car on a jack stand.
Step 3 Chock the rear wheels and apply the parking brake.
Step 4 Remove the wheel lugs and the wheel assembly.
Step 5 Remove the mounting nut and dished washer that secure the stabilizer bar to the control arm. Use a wrench or ratchet and socket.
Step 6 Unscrew and remove the mounting bolt and nut holding the inner side of the control arm to the car's body. This will relieve the tension on the stabilizer bar. Use a wrench to hold the mounting bolt as you unscrew the nut with a wrench or ratchet and socket.
Step 7 Unscrew the bolt on the steering knuckle that holds the control-arm ball joint to the knuckle. Use a wrench or ratchet and socket.
Step 8 Spread the steering knuckle joint that holds the control-arm ball joint to the knuckle. Use a large screwdriver or pry bar. Then separate the ball joint from the steering knuckle.
Step 9 Pull the control arm from the stabilizer bar.
Step 10 Remove the stabilizer bar spacer from the control arm and keep it in a secure place. You will need to use it on the new control-arm ball joint assembly.
Installing the Ball Joint Step 1 Insert the new control-arm ball joint stud into the steering knuckle joint. As you look through the mounting bolt hole on the steering knuckle, align the notch on the ball joint stud with the hole. Insert a new ball joint mounting bolt and start a new nut on the bolt. Tighten the nut.
Step 2 Mount the stabilizer bar spacer in the control arm, then insert the stud bolt at the end of the stabilizer bar into the control arm mounting hole and spacer.
Step 3 Set the other end of the control arm in its mounting position and insert the mounting bolt. Then start the mounting nut on the bolt by hand.
Step 4 Hold the head of the mounting bolt that secures the control arm to the car's body using a wrench, then tighten the nut.
Step 5 Secure the stabilizer bar to the control arm with the dished washer and mounting nut. Tighten the nut.
Step 6 Install the wheel assembly and lugs. Tighten the lugs with the lug wrench just enough to hold the wheel assembly firmly in place.
Step 7 Lower the vehicle and finish tightening the wheel lugs.
Step 8
Remove the chocks from the rear wheels.
Aug 08, 2010 | 1998 Ford Escort
How to replace headlights bulbs in a grand cherokee 2001
  1. Remove the jack screw attaching the top of the head lamp to the head lamp mounting module.
  2. Grasp the upper inboard and lower outboard corners of the head lamp and pull the head lamp outward.
  3. Remove the bad bulb socket from the head lamp module and remove bulb from socket.
  4. Install new bulb into socket and reinstall socket into head lamp module.
  5. Position the head lamp on the vehicle and align the ball studs with the sockets.
  6. Push the head lamp inward to secure the ball studs with the sockets.
  7. Install the jack screw attaching the top of head lamp to the head lamp mounting module.
Do not touch glass of halogen bulbs at the oil can cause the headlight to blow out
Nov 12, 2009 | 2001 Jeep Grand Cherokee
How do i replace a sidelight on a grand cherokee '53
The whole head lamp assembly has to come out to replace the headlight bulb. Here's how to do it.
REMOVAL:
  1. Remove all of the bulb sockets from the head lamp module.
  2. Separate the head lamp from the vehicle
  3. INSTALLATION: CAUTION: Do not touch the bulb glass with fingers or other oily surfaces. Reduced bulb life will result.
  4. Install all of the bulb sockets in head lamp module.
Aug 17, 2009 | 2003 Jeep Grand Cherokee
Gitzo off centre ball head
Go to big lots or other discount house (I went to sears and spent $4.00) and buy the cheapest mini tripod you can find and scarf the screw/knob off that. That is what I did.
Jun 04, 2008 | Gitzo Photography
Slik ABLE 300DX Tripod Logo
170 people viewed this question
Top Slik Photography Experts
JP Services
JP Services
Rochell Cruz
Tony Parsons
Tony Parsons
Are you a Slik Photography Expert? Answer questions, earn points and help others
