Hello, it's me again.
It is external powered.
When i turn it off, i hear a beeping sound, like the one comming from a tv or something, and when i turn it on, it doesnt sound clear, it sounds more than usual.
A friend told me to take it out from its original shelter, and to put it in my computer, and try to boot it from there, what do you think about that?
SOURCE: Problem to start my external packard bell usb 2.0 250 GB hard drive
Sounds like the drive is dying. Is it externally powered, or powered through the USB port? How old is the drive? When you say 'strange' what does it sound like?
SOURCE: maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
SOURCE: I have a packard bell store and save 3500 250gb.
You need to know the voltage and minimum current for the device. The old adapter should show both, as in 5V, 100 ma (V=voltage, ma=milliamps current) Places like Radio Shack have multi-voltage, high current replacements.
The voltage MUST match, the current CAN be higher but NOT lower.
SOURCE: We understand that your problem is: We understand
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Testimonial: "Very helpful and thank you!!!"
