Question about SonicWALL TZ 170 SP Firewall
I changed a setting in the admin panel disabling access via HTTP this morning thinking that I would still be able to access the admin panel from the HTTPS setting but now I can't get to any part of the admin panel. I think I have to reboot the device to make this setting active and allow a new IP address to be changed. Can you help?
  • 131 Answers
Look in network comuters an devices for it or try router.com from internet explorer or use pen in hole to reset to default, push button and hold in, unplug router while holding the wole time then plug back in until all lights flash wait a coulple more seconds then release buttom, alow to power up then unplug for 10 seconds and plug back in.
Posted on Nov 14, 2009
How do I reset the Admin password?
The default ID and password are "11111" and "x-admin" respectively. When accessing the administrator menus on the copier the code 11111 is used. I couldn't find a way to reset specifically.
I believe you should be able to access the Admin Menu by pressing the System button on the operator panel. A password is required to enter Admin Menu when Panel Lock Set is set to Enable. To Disable the Panel Lock you will need a password. The factory default panel password is 0000. Hopefully you haven't changed that. This procedure is described in the manual on pages 315 ff. I believe from there you can go in and assign a new Admin password if required.
http://www.fujixeroxprinters.com.hk/downloads/uploaded/CM215_UserGuide_Sec_c3b3.pdf
Jul 25, 2014 | Fuji Xerox® DocuPrint C3055DX Laser...
Tip
How to disable user account control in windows 7
It is very easy to deal with UAC Settings in windows 7.You dont need to completely disable UAC, if you really dont want to do. Here is the step to be followed to disable UAC in windows 7 Step
1: Access UAC settings by typing UAC in the start menu or control panel search
OR
Go to start -> Control panel - > user accounts
Once you double click on user accounts you will get a window like below. There double click on Change user account control settings option
Now you will get options to change user account control settings. You can move the slide to 4 different posiotions according to your choice. The first is more secure and the last means its disabled
Disable UAC via Registry Editor
1.Type regedit in the Start -> Search bar. 2.GotothefollowingKey:HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionPoliciesSystem 3.Locate REG_DWORD: EnableLUA
4.Set the value of EnableLUA to 0.
5.Locate REG_DWORD: ConsentPromptBehaviorAdmin
6.Set the value of ConsentPromptBehaviorAdmin to 0
7.Restart
Disable UAC via Group Policy
  1. Type “gpedit.msc” in the Start -> Search bar.
  2. Double-Click: Computer Configuration -> Windows Settings -> Security Settings -> Local Policies -> Security Options.
  3. Locate: “User Account Control: Behavior of the elevation prompt for administrators in Admin Approval Mode” and modify to “Elevate without prompt”
  4. .Locate: “User Account Control: Detect application installations and prompt for elevation” and modify it to “Disabled”
  5. Locate: “User Account Control: Run all administrators in Admin Approval Mode” and modify it to “Disabled”
  6. Locate: “User Account Control: Only elevate UIAccess applications that are installed in secure locations” and modify it to “Disabled”
  7. Restart.
on Mar 03, 2010 | Computers & Internet
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
Changing password to my router
Hello you have not entered the routers name.
Basicly it`s just to visit the routers homepage for downloading a user manual.
Here is some homepages that tells how:
http://pcsupport.about.com/od/fixtheproblem/f/change-router-password.htm
You will probably have to hold the reset button from 10 to 30 seconds depending on your brand of router. If you hold it for too short a time it will simply reset the router but won't revert back to its factory default settings. On some routers you may have to use a pin or thumbtack to press the button if it is recessed inside the router.
2. Connect a computer to one of your router's Ethernet ports (but not the one that says WAN)
Most router's have a web browser-accessible administrator page that you must log in to in order to access the router's configuration settings. Some routers disable administration via wireless, so you will need to ensure that you are connected to the router via an Ethernet cable before attempting to access the router's configuration page.
3. In the browser address bar, enter the IP address of your router's administration interface
Most routers have what is called a non-routable internal IP address such as 192.168.1.1 or 10.0.0.1. This is an internal address that cannot be accessed from the internet.
Here are the standard admin interface addresses used by some of the more popular wireless router manufactures. You may have to consult your specific router's manual for the correct address. The following list is some of the default IP addresses based on my research and may not be accurate for your specific make or model:
Linksys - 192.168.1.1 or 192.168.0.1
DLink - 192.168.0.1 or 10.0.0.1
Apple - 10.0.1.1
ASUS - 192.168.1.1
Buffalo - 192.168.11.1
Netgear - 192.168.0.1 or 192.168.0.227
4. Enter the default administrator login name (usually "admin") followed by the default administrator password.
You can locate the the default admin name and password for your specific router by checking the manufacturer's website or by Googling "Default Admin Password" followed by your router's brand name and model.
5. Click on the "Admin" page from your router's configuration page and create a strong password
Be sure you enter a strong complex password for your router's admin password. If you ever looe this password you will have to repeat the steps above.
If you didn't lose you router password but just don't know how to change it, you can skip steps 1 and 2 and enter the admin user name and password that you have into step 4. This will allow you to change your wireless router's password without wiping out all your other router's settings.
Good luck
Nov 24, 2012 | Computers & Internet
Linksys not working
log in this ip 192.168.1.1 user name and password admin if u not change password and go wireless section and check enable and disable option
Jun 01, 2012 | Linksys Computers & Internet
I do not know how to find my the WPA passphrase. I have window XP.
Connect to your wireless router via one of the following:
http://192.168.1.1
http://192.168.1.0
http://192.168.2.1
Once you get the wireless router page, use Admin and either blank or admin as the password.
If that doesn't work, you'll have to reset the router. There's a small pencil sized hole on the back of most wireless routers. You use a paperclip and press in the hole gently. You'll feel a light click, hold in while the wireless router is on for about 5 seconds. That will reset the router to it's original settings.
Once you have access to the wireless router there is typically a heading called security or wireless security that has the options for WPA2, WPA, or WEP.
Use WPA2 if you can.
Disable the broadcast of your SSID.
Change the password for the admin account of the router to something long and then write that down and lable the bottom of the wireless router with that info.
Apr 28, 2011 | Computers & Internet
I cant get on my facebook account it says its disabled
more info please ..but can you open other account or just your face book account ?
try changing your security settings and it think its not on the router but the ISP settings if so .. try contacting them for more info
or try contacting the admin in face book
1 check first
did you do something to break the agreement>?
did you received any warnings from the admins ?
have you opened you FB acc on other computers?
did you share your password w/ others?
and have you offended someone in face book?
these are the main reasons why the account gets disabled in facebook
here are the link where you can ask for restoration =D hope this helps
http://www.facebook.com/topic.php?uid=68310606562&topic=14245&perpage=30&post_index=31&start=3&post_id=89851&hash=f185e23b9fdb1ca90288f9a58be22b2a
Mar 16, 2011 | Computers & Internet
No access to my router
No access via wireless or ethernet??
Ensure the ethernet card in your computer is working, and connected it to the router using a cat5 cable.
Access the Admin control panel. Usually you can get to this by typing the following IP addresses into your browser.
192.168.1.1
192.168.1.254
The access credentials should be as default unless you changed them. These should be in the user guide.
If you're having a wireless problem, then you can change the code, visibility and other settings in the Admin control panel.
Failing all else, use the hard reset button to restore the router to factory settings. Start at the bottom and work up.
Hope this helps
Wheal
Feb 27, 2010 | Computers & Internet
Admin password has been changed, and cannot access the prompts at start up
Reboot it, and then start pressing F8 until you can go to safe mode. Or 9if it doesn't work there, try pressing "del" until you get to safe mode. Try getting into control panel then look for user accounts. Set up admin password or disable it.
Aug 16, 2009 | Acer Computers & Internet
Can not change my admin password to access my admin user on Vista
control panel>>
administrative tools>>
Computer management>>
local users and groups>>
users, and select the admin, right click asn set password.
OK and exit and reboot
Nov 16, 2008 | Microsoft Windows Vista Home Premium with...
SonicWALL TZ 170 SP Firewall Logo
202 people viewed this question
Top SonicWALL Computers & Internet Experts
Raymond Ramirez
Raymond Ramirez
Frank Zabroski
Frank Zabroski
Steve P
Steve P
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
