Question about Rancilio Silvia Espresso Machine
The steam switch was left on. Now the machine does not heat up. Help!
  • 1,089 Answers
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also an other problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
Posted on Nov 13, 2009
Testimonial: "Thanks a bunch. It's a tiny button but it fixed the problem perfectly!"
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
I left my Artisan espresso machine on between brewing coffee and making hot milk and got an electrical burning smell. Should the machine be switched off if not in use for quarter of an hour or so?
Always off when not being used, it only takes 4 minutes to heat from cold and that can be while you are sorting coffee and cups. Get the electrical smell investigated, these have a problem with seals in the steam boiler which causes switch problems from the steam.
Dec 25, 2012 | KitchenAid Artisan
Ascaso dream wand wont heat or steam
You should descale the machine, as you may have a blockage in the steam tap.
When descaling make sure that the descaled water goes through the steam wand as well as the group. JURA descaling tablets
Mar 26, 2017 | Ascaso Dream Espresso Machine
Our machine is about 4 years old now and has recently begun tripping the GFI sporadically. In most cases it does this when the steam pump is on, either for steam or heating for hot water. Sometimes, it...
Hi
Your seals in the steam boiler are gone and it is leaking water to the switch below. The steam boiler is located just above the switch on the lower left side. You just have to replace the seals (O-rings)
Dec 31, 2010 | Saeco Magic Comfort Plus Espresso Machine
MY SILVIA NOT WARMING THE WATER. I LEFT THE MAIN SWITCH "ON" AT STEAM FUNCTION WITH THE SCREW-KNOB OPEN AND THE STEAM SWITCH "OFF". TOMMY.
Hi
If your lucky.
Dec 22, 2009 | Rancilio Silvia Espresso Machine
I accidentally left my Silvia on overnight, with the Steam button in the "on" mode. Now the machine won't heat u at all. Help!
Hi
Nov 25, 2009 | Rancilio Silvia Espresso Machine
Old 1996 nuova simonelli mac digit no pressure or heat
There is a reset thermostat on the right side of the machine above the element, check to see if it tripped. If it did make sure there is enough water in the machine and when turning it on, open one of the steam valves and turn off the cup warmer. Leave the steam wand open until it hisses or small amounts of steam or air will vent out.
Feb 11, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Rancilio Silvia Espresso Machine Logo
133 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
