Question about Garden
Homelite zr08111 carburetor parts brake down part of leaf blower
  • jeremy fountain
    jeremy fountain May 11, 2010
    per my parts break down of ut number 08111 does not show the breakdown of the carb itself, let me know the make and model of the carburetor and we can go from there ;)
4 Suggested Answers
SOURCE: Homelite leafa Blower Model 08010B
They also provided the address of this parts supplier:
Gardner Email Address: customerservice@gardnerinc.com Address: 3641 Interchange Road
Columbis OH 42302
614-456-4000
Posted on Nov 08, 2008
bulldogchief
  • 388 Answers
SOURCE: how to position the two little plastic hoses going
This is much easier than you think; the carburetor has two ports, one supply one return, the return port is the top port which allows excess fuel to be returned to the fuel tank when pressing the primer bulb. The bottom port is the intake that supplies fuel to the carburetor to be mixed with air and pushed into the cylinder for the combustion cycle. Both lines connect to the tank, the line with a cylindrical looking object is the supply line, that object is the fuel filter, so it would be connected to the bottom port of the carburetor. I hope that helps.
Posted on Oct 08, 2009
  • 203 Answers
SOURCE: homelite gas leaf blower losing power
There might be a small screen in the exhaust (it's a spark arrestor) that gets plugged with carbon. Will cause loss of power and eventually the machine will not run. You can just take the screen out and it will run better. Check the exhaust ports (look into the cylinder area after you take off the muffler) and see if it/they are plugged. If so, use only plastic or wooden items to clear the carbon out. Be careful not to get any in the cylinder. If you do, pull the starter rope several times to blow out the carbon.
Otherwise, some fuel line cleaner would be a good try to assist in the problem.
Posted on Dec 29, 2009
NEED PART # FOR PRIMER BULB ON HOMELITE BP30185
Thanks for providing the UT number.
When cross reference the carburetor part of up00651 it came as as Zama C1U-H36 which has a Zama 0057003 which is superceded to Zama 0057030
Mar 18, 2015 | Homelite Backpack Leaf Blower
My Homelite mightylite blower vac starts but won't stay on unless choke is closed down the unit is only one season old. The unit is supposed to be in warranty for two years but Homelite said not the...
The unit is under warranty. The person you talked to must be new. Find a warranty service center in your area. Take your receipt with you and they should be able to take care of it for you.
Good Day
Dec 13, 2009 | Homelite 'Yard Broom' Leaf Blower
I am looking for carb kit for my homelite leaf
Does your model #ut-08010, Have a letter after it. Homelite lists 5 or 6 models of that unit. Plus the kit they show is a complete carburetor with gasket. You will have to figure out which carburetor they put on your blower. Either a Walbro or Zama carburetor and it model to figure out which kit it will need. The homelite kit lists for about $67.00 USD.
You can go to www.precisionope.com and look it up under OEM parts.
Hope it helps.
Good Day.
Oct 20, 2009 | Homelite Garden
Need to repair Hpmelite leaf blower UT08930A. Where can I download repair manual Some spark, but may be weak? Carburetor does not seem to get gas to cylender when starting rope is pulled ? Plug shows no...
I think Home Depot carried Homelite these days. Im 99% cerain that there is a web site for Homelite.
I think you have a carb problem ... address that part first.
Oct 12, 2009 | Garden
Blower
You need to rebuild the carburetor. Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then under select OEM select Homelite then do as instructed. You should find the parts you need and hopefully the parts breakdown for the carb. this will help you in the rebuild. If it does not have the parts breakdown for the carb. find what mfg and model carb. it is then go to that site for breakdown.
Apr 04, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite Leaf Blower won't stay running
Hey .. Did you replace the inlet screen in the carb ?
or
Either the carburetor, block behind it, or the cylinder are loose. Common Homelite problem.
Let me know ....
Mar 27, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
270 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
