Question about Poulan Garden
CAN'T FIGURE OUT HOW TO RE-STRING PULL CORD - Poulan Garden
  • 486 Answers
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Posted on Nov 13, 2009
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
The starter pull cord on my gas trimmer will not pull.
Hi Mark
Perhaps a bit late now.... Just spotted this so I imagine it's all fixed by now.
But for others with this sort of problem.
Assuming the pull cord is not broken, stuck or tangled. Switch off or short plug to ground, for safety then remove the spark plug to allow the engine compression to escape. You should be able to turn the engine over really easy with the pull rope, otherwise the engine might be seized or the rotary pull mechanism jammed.
Also... can the shaft to the string line be rotated as in the crankshaft of the engine.
Good Luck
Aug 30, 2014 | Echo New String Trimmer SRM-225 2 Stroke...
Jessie doll string in the pulled position
Sometimes you can get the string cord to release and retract back. Hold the doll firmly and gently pull the string out about an extra two or three millimetres (eighth of an inch) or as much as possible. Keep the string tight for a short while and then allow it to retract slowly. It may take a few attempts, the skill is in pulling the string that little extra distance, holding it for a few moments, then slowly releasing it again.
Dec 30, 2013 | Toys
I have a 22in self propelled, how do i change the pull cord
Remove the motor shroud encasing the pull cord assy. What I do is turn the shroud over, leave the spring in it's slack position and gather up the two broken pieces of string. I lay then down in a circular motion on top of the recoil spool until the string is all coiled up, counting each loop made. That and once more is how many times you'll need to wind that spool up. When you are done winding, "round up" to make the hole in the spool meet up with the hole in the recoil housing. Once you're there, get a medium sized flat-head screwdriver and wedge it between the spool and the housing, hindering the spool from unwinding. Wedge it good. Melt the end of the new pull cord and begin outside the housing and feed the string thru the eyelet on the recoil housing. Keep feeding it ( recoil housing still upside down ) thru until you visibly see it pass thru the eyelet and into the hole of the spool. You may need to use a small pick to grab it and pull it home. Once it's out, it's not over. Pull enough string thru to tie a double-loop knot. When you're satisfied with the strength of the knot, reach down and grab the string, holding it tightly. Next reach in and pull the screwdriver loose. Nothing should move-you're holding the string. Hold the shroud with one hand and let the string slowly pay into the recoil spool. Bolt the shroud back on and go!
Sep 23, 2013 | Poulan Pro " Pro" Self Propelled Mower
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
The pull cord for starting the cutter has detatched
normaly there is 4 bolts holding the cover on take them out and the pull clutch in under there,,, put the string back in the cover and tighten the clutch up first so it pulls the strin in when you let it go,,,tiy a good knot in the pull start string or you will just pull it out again!
Jul 01, 2010 | Ryobi Garden
I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Apr 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
Bosch cannister vac: Cord is stuck--won't rewind
It probably is, these cords are usually 15-25' long ;-)
What you can asssume is that the cord is simply twisted upon itself and doubled up so cannot easily come out, and will not go in... therefore.
Pull gently on the cord and twist in a clockwise direction. Does the cord seem to get a bit longer? If not, or if it gets tighter, try counterclockwise. If you keep trying eventually it will loosen and you can fully extend the cord. Compare this to holding a piece of string between your hands by the thumb and index fingers. Hold one end still and twist the other 20 times (twisting the string). then relax the string between your hands. See how it immediately forms a loop? That is the problem with your cordreel too. There is a loop in there that we need to undo. Now pull a bit so you can still see the loop, and then start untwisting to see what happens. You can also do this with a YoYo ;-)
Be patient, observe, sensitize your tactile senses and see if you can figure out which direction loosens your cord - and get it out ;-)
Good Luck
Hopefully you wont have to take it all apart. that cordreel spring is very strong. Be careful if you do go in there.
Mar 26, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
Garden Logo
470 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
