Question about Arcam AVR-100 Receiver
I have an arcam delta 60 amp the mains
I have an arcam delta 60 amp the mains transformer has had it the mod is now discon arcam have no parts i live in
norwich can you help 077 46 383713
Display on arcam say initialising... And nothing happens
It can be a faulty "cd drive unit" or "main board". In my case it was the main board.
Feb 06, 2014 | Arcam Solo Movie 2.1 Home Theater Receiver
I've been given a Technics sl-bd22d turntable, an Arcam amplifier and a Cambridge 551P pre amplifier. How do I connect them all together?
Depends what type of sockets these have. If the Pre-Amp has a RCA phono sockets you just need some RCA leads. I don't know if the Arcam Amp works with any pre-amp. But if it does, it's likely to have the same type sockets as the others. So you just buy another two RCA leads and connect it up.
Apr 19, 2013 | Audio Players & Recorders
I need a power transformer for an Arcam AVR100. Do you seel these or could you point me in the right direction?
As Transformers are safety parts they should only be replaced with a approved part from (in this case) Arcam. I suggest you contact them and they will put you in touch with someone or supply the correct part.
Jul 01, 2011 | Audio Players & Recorders
We just purchased an LG, LED, LCD, TV and just realised that our existing Arcam AVR 100 does not have an optical out. Does this mean we need a new amp or are there alternative solutions? Many thanks.
Actually, it doesn't have ANY digital outputs. Just what do you require one for? Name specific models and functions when replying.
Do you think the TV NEEDS optical audio from the receiver? Maybe the TV could survive on just analog audio from the video source, while the GOOD audio goes to the ARCAM since the ARCAM is going to do the hard work of managing and driving the REAL speakers.
http://www.arcam.co.uk/_ugc/file/avr100e_manual.pdf
Feb 06, 2011 | Arcam AVR-100 Receiver
Problem with my alpha arcam 7 amp.. internal 240v 25a fuse blows right after switching it on even when all speaker and RCA cables were disconnected.i need the schematic diagram. Where should i start the...
hi,
I have the service manual of ARCAM AVR 200 with me. send me a mail on my mail id. I will send u the service manual. its a large file having a size of 4.8 mb. I can sent it through fixya.
agingopakumar@yahoo.co.in
Check the standby transformer T752 first. if its primary winding is short the this problem can occur.
ok
Jan 17, 2011 | Arcam AVR-200
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
How to hook up a computer sub to a hometheater amp
http://www.arcam.co.uk/_ugc/file/avr280e_manual.pdf
If you have the whole Z5500 package you could run the Arcam's optical- or coaxial digital audio output to the corresponding input on the Logitech.
But I'd be careful about letting BOTH the Arcam and the Logictech perform Digital Sound Processing on the sound. DSP's aren't meant to be stacked. My money says the Arcam is better in the DSP department than the Logitech.
If you have just the sub, run the Sub PRE out from the Arcam to the Sub/Center input (adapt it to 3.5 mm) on the Control Center and set the switch to "6 ch direct".
Mar 06, 2010 | Jensen JW250 Main / Stereo Speaker
1996 GMC 1500 Pickup. Keep blowing 20A ECM-B fuse. Replaced Ign Mod,Coil,Cap/Rotor & pickup. Any Ideas Out There? Afraid to go any futher...dont want to ruin these new parts!
if you keep blowing a fuse there's a good chance it's not a faulty part but a short in the main harness most likely under the dash where all the connectors tend to get brittle over time and short out constantly. also check the ecm connection there is a 60 pin type.
May 19, 2009 | GMC Sierra 1500 Cars & Trucks
I have recently purchased a arcam alpha 10 amp to go with my arcam alpha 9 cd player and my monitor audio rs8 speakers. I am pleased with the amp and i am thinking of adding the power amp, the problem is i...
A better solution is like I have mine; use the Arcam 10 connected to the tweeters of your speakers & the power Amp connected to the woofers & link the pre out's on the 10 to the power Amp. using phono cables. The Manual can be downloaded from Arcams discontinued section of their website.
This Bi-Amp method gives a far superior sound than just using the 10 as a pre Amp.
May 04, 2009 | Audio Players & Recorders
Arcam AVR-100 Receiver Logo
318 people viewed this question
Top Arcam Audio Players & Recorders Experts
 Grubhead
Grubhead
Sock Puppet
Are you an Arcam Audio Player and Recorder Expert? Answer questions, earn points and help others
