Question about Cameras
I've got a Fuji Finepix s700 and it's started throwing an error when I'm importing files to iPhoto -- files can't be imported, unrecognizable file type or may not contain valid data. This is happening with both .jpg and .avi files, I can't see a pattern to which files are deemed unrecognizable (they're not always consecutive or at the beginning or end of the import). I've tried a new memory card, still getting the problem (though the error does not happen with every upload). It happens when I use a card reader or with just straight off the camera. My husband looked at the files themselves and believes there may be a problem in the header of the files (he was looking at something... hex level?) that isn't being written correctly so the files could be understood to be .jpg files (today was the first time this happened with a .avi file).
  • 3 more comments
  • lauragfloyd Nov 13, 2009
    It's not just iPhoto, when I pull the files from the card reader to a
    Pictures folder and try to import them into Word, upload them to
    Blogger, whatever, they are also unreadable. Again, I think this may
    be a problem in the header of the files, which my husband says looks
    corrupted/unrecognizable as a .jpg file. There are two cables I use
    when importing through USB, one for the card reader and one for the
    camera.
    camera.
    Sorry if I'm sending this three times -- can you tell it's my first time using this service? Just in case:
    camera.
    I use two different USB cables to connect to the card reader and the camera, so I don't think it's a USB issue.
  • lauragfloyd Nov 18, 2009
    Thanks so much, especially for directing me to the appropriate link!
  • Cameras Master
  • 19,396 Answers
Hi.
If you are sure that the camera is recording files with a bad header, then there is a problem with camera firmware.
Try updating the firmware follow instructions here.
If that does not work, then the camera logic board must be replaced.
In that case call Fuji and see if they are aware of this problem, if this is a factory defect, then the camera will be replaced.
Regards.
G.
Posted on Nov 14, 2009
  • 2,567 Answers
If this only happens when importing files to iPhoto, then I would assume that this is only a problem with iPhoto.
Another thing, which might be worth checking, is whether the USB cable connecting the Finepix s700 to the computer is defective or not. If you are using the same cable when you connect the camera & when you connect the card reader, then I would suspect that the cable is defective. It is worth trying another cable & see if it solves the problem.
In all cases, please keep me informed with the result, so that I could help you solve the problem.
Posted on Nov 13, 2009
  • Mohamed Omran Nov 13, 2009
    In this case, i would assume that this is a problem with the camera processing the captured photos & videos. An update of the camera's firmware might help resolve this problem.
    What you will need to do is to have an AC mains adapter or a fully charged battery, a formatted card in your camera (there should be a setting in your cameras menu for formatting) and the usb cable connected to your camera and PC. This should all be in your owner's manual if you have one ( if not you can download one from a Fuji website).
    Check for a firmware update on Fuji website & download it to your computer.
    To check your current version hold the display back button down and turn the camera on. It should display the current version and ask if you want to upgrade. If you don't ,or can't, turn off your camera.
    Basically you download the up date, then upload to your camera using the usb lead following any instructions along the way (get the manual for instructions, it will be easier). Mains lead is preferable as a battery could die halfway through and then you will be in trouble.
    Hope this helps
Photos disappear on iPhoto
Hi Linden McNeilly,
In case if you have lost your photos from your iPhoto library. You can recover them back with the help of a photo recovery software. The one which I use is Yodot Mac Photo recovery software to recover iPhoto photos. So if you have any photo loss from your iPhoto library you can use this software.
Jul 14, 2012 | Nikon COOLPIX S9300 16MP 18x Opt Zoom 3.0...
Cannot import pictures to iphoto
I will assume you are using OS-10 Snow Leopard or later and a recent version of iPhoto. I would experiment. First I would locate one of your files in Finder and open the picture in Preview to see if the file is basically good. Assuming it is, click on the Apple icon at the upper left of your screen and click 'Software Update' on the pull-down menu. Make sure iPhoto is up to date. Another thing you could try, would be to take one of the files that will not open properly and temporarily changing the file extension from .jepg to .jpg. Both .jepg and .jpg are the exact same format, but it is worth a try.
Mar 05, 2012 | Nikon D3100 Digital Camera
Fuji finepix s700 camera error message protected card. After making sure sd card in unlocked. I still get this message. I had trouble getting out a sd card,i feel a piece of the sd card broke in the...
Take a small flash light and see if there is a part of a memory card in there, if there is cleaning it out would solve the problem. Also make sure you're putting the memory card in the right way. I've you've done that and it's still giving you problems try going into the menu's and formatting the memory card in the camera.
May 10, 2011 | Fuji FinePix S700 Digital Camera
Why can't I upload my photos from my finepix s1500 onto my mac? It opened the files in my iphoto but they showed up as blank boxes and "Error downloading images - iPhoto cannot import your photos...
Is this a new problem - that is, did it work in the past? Are you trying to import jpeg or raw?
First thing is to see if it is iphoto or the camera that has a problem.
Try uploading the images to another computer (try a PC - not that it is better, but PC is different). If the images can be seen & read there, the images are likely fine and iphoto may need an upgrade to read the format from the finepix s1500. Alternately, try copying the photos from your memory card (use a memory card reader) to your hard disk. See if another application can see the images (even use a word processor to import image), or e-mail the image to yourself and then use your web-browser to see the image.
If the camera images can't be read by multiple computers/multiple readers, then it may be that your memory card is corrupted.
Feb 25, 2011 | Cameras
Lost iphoto back catalog after an import, is there anyway to recover these photos?
the back catalog of your images are not gone. Since the pictures you have uploaded form your camera to iPhoto all those files are still there. All you need to do is re-load the images into the library of iPhoto.
1) Start iPhoto, then in the menu goto File / Add to library..
2) Then a file browsing window will open, all you need to do is locate the folder in which u had specified to iPhoto. (Default location for iPhoto is located at MainHD / Users / Username / Pictures / iPhoto Library
3) Once you have located the folder or folders you wish to add to your library or catalog just press import. And all the images should show in the catalog.
4) if you have more pictures saved in another folder, then repeat steps 1 to 3 again. but in step 2 locate the folder or drive you wish to import from.
Jul 07, 2009 | Apple Computers & Internet
Some avi files download other larger files won't (on iphoto)
If you have larger files to download better use a card reader with USB2.
Jun 03, 2009 | Fuji FinePix S5700 Digital Camera
Can't get pics to my mac computer, won't transfer.
When you get the popup from iPhoto don't click on any iPhoto buttons. Instead, click on command+tab and change to your Finder application (leaving iPhoto open in the background).
1) Create a new folder on your Desktop or in your Pictures folder. This is where you will copy your photo files.
2) Click on File, then New Finder window. Size these finder windows so you can see both of them at the same time. In the second window, go to your computer, and then to the drive that represents the memory card in your camera.
3) Drag and drop to copy the files from the camera's memory card Finder window to the new folder Finder window, dropping the files into the new folder on your computer's hard drive.
4) Use command+tab to change back to iPhoto. Cancel from the import warning window. In iPhoto click on File then Import to Library
5) In the import dialog tell iPhoto to move the photos (not to import them in their current location) so that iPhoto puts the photos in the same place it put your other photos when it imported them directly from the camera.
If you can't do all of these steps, tell me how far you got, and what happened.
Dec 27, 2008 | Fuji FinePix Z100fd Digital Camera
Can't download from Casio EX-Z120 to iPhoto on iBook OS10.4.11
If you can't do all of these steps, tell me how far you got, and what happened and we can take it from there.
Dec 27, 2008 | Casio Exilim EX-Z120 Digital Camera
Cameras Logo
46 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
