Question about HP Officejet 5610 All-In-One InkJet Printer
No Solution Center?
I can't find the CD, my printing works, but it tells me that there are no scanning options when I try to scan. I tried finding my HP solution center but it doesn't seem to be on my computer. Is the software (the same as on the disc) available to download online, free?
  • 975 Answers
YES !! go to www.hp.com , then go to downloads , enter model num. , hope it helps
Posted on Nov 13, 2009
    Problem Solver:
  • 7 Answers
HP Drivers Download
Simply select your OS and download the full software suite.
When trying to scan to my HP J4580 Officejet J4580 All-in-One printer it says "No scan options, refer to device documentation". What does this mean?
It means you need the HP scanning software running on your computer. The computer tells the scanner how to scan, what to scan and where to save the image after scanning. The scanner has no options until received from your computer.
Feb 09, 2010 | HP OfficeJet J4580 All-In-One Laser...
Scanning option won't work - everything else does!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr4
Aug 19, 2009 | HP Officejet 5610 All-In-One InkJet...
Won't scan. Copies and prints. But the scan button does nothing.
Did you try scanning from your pc? I never use the printer scan button. Most scan buttons won't work without the "print center" program open as the scan always goes to the pc. I mostly use the windows scan program in the control panel. Try this.
Jul 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
No Scan Options
hi,
alkkk-3
Jul 01, 2009 | HP Officejet 5610 All-In-One InkJet...
Scan to computer, message telling me to Refer tp device manujal
Scanning to computer does not work if the Solution Center is not installed properly. Make sure the printer status is ready before scanning from Solution Center.
If you cannot open solution center, try adding a device using the CD. If not resolved, you may have to uninstall and then reinstall the entire Software.
Mar 04, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
NO Scan Options
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is
the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel
menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Feb 18, 2009 | HP Officejet 7210 All-In-One InkJet...
OCR application error with the Dell ALL in ONE
OCR is a software provided by Dell to convert a scanned document to editable text(word) document. If you scan without OCR software, printer will scan it as a Picture and you can not edit it.
Now here is your answer.
When you install Printer CD, it also install OCR software (Abbyy Fine reader) along with it.
You might have uninstalled the printer drivers and reinstalled them by downloading it from Dell support site.
I must tell you that Downloaded drivers from Dell site DOES NOT contain OCR software.
Solution:
1. You can download free trial version(15 days) from Abbyy.com
Click here to download
2. If any of your friend or relative have printer listed below then you can use the same CD to install the OCR software.
List: Dell 924, Dell 926, Dell 928, Dell 944, Dell 946, Dell 948, Dell 964, Dell 966, Dell 968.
location on Disc:
D:\OCR\setup.exe
3. You can scan using MS Paint.
Click on Start > All Programms > Acccessories > Paint
Click on "File" on Top left corner.
Click on "From scanners and cameras"
Click on "Scan"
It should be able to scan.
4. If you want to use Dell All In One Center.
You can disable OCR option for scanning and it will scan as an image.
Open Dell All in one center.
Click on Advanced scan options Under scan,
Uncheck "Use OCR software".
Click OK and try to scan again using Dell All In One center or using the printer operator panel.
Please revert for any further assistance.
Nov 05, 2008 | Dell 924 All-in-One InkJet Printer
HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Oct 20, 2008 | Office Equipment & Supplies
HP PSC 1510 Vista issues
what happens whenever you are trying to scan.... any error message or any error number?
try scanning from the printer to the computer using the scan to option on the front panel of the printer.
try scanning from hp solution center installed in your computer.
try scanning from mspaint. to do so, open paint and click on "file-->from scanners and camera".
how did you installed the driver. have you got the correct cd to install the printer in windows vista???
if not that may be the problem. the printer can print and copy well as you are having the drivers which will work in win vista. but for the scanning functionality you need to get the cd to install the printer in windows vista. you can download it online.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47767-1&lc=en&cc=us&dlc=en&product=428800&os=2093&lang=en
the above link will help yu to download the win vista software and drivers for this particular printer.
Thanks and regards
Agnel
Mar 10, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP Officejet 5610 All-in-One scanner will not work
Windows Vista causes an error with the scan feature of the HP officejet 5610. To work around it use the paint program:
1. open paint program
2. click file
3. click "from scanner or camera..."
4. scan menu opens
from there simly select the type of scan you would like to do and click the scan button
Jan 07, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
