Question about Oster 6260 1500 Watts Toaster Oven with Convection Cooking
Door can not get the door to shut will only close half way
  • Anonymous Apr 26, 2009
    I have exact same problem!! The hinges are so poorly made and I hate to buy a new toaster oven when the heating elements are working fine. I guess I'll try e-mailing Oster because, for the price, the hardware should last!!!
  • 59 Answers
On my toaster oven, sometimes the plate at the bottom of it would get stuck when shutting because the arms it uses to close it weren't very good.
I had to push it in with my hand to get it closed. (make sure it's cool)
Posted on Jan 08, 2008
The toaster says shut door and door is shut
The micro door switch is bad if you can not find one for your oven try one for a microwave oven it will worl
Jun 08, 2015 | Toaster Ovens
Door will not remain closed
sorry we can not see it from here but possibly you lost a spring
May 30, 2015 | Toaster Ovens
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
Amana self clean oven has the locke on with the door open I can't take the lock off tu close the oven
Hi there.
Check the door interlock switch, contacts may be bad and needs replacement.
Regards.
Aug 03, 2011 | Toaster Ovens
I need a New Glass door for my Salton Vitantonio VT6? The glass door completely shattered just past half way done cooking biscuits???
I would check with Salton and if that doesn't, here is an address that gives you a list of sites that carry oven parts.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 14, 2011 | Salton Vitantonio VT6 Toaster Oven with...
Door does not close
After 3 years of perfect service, our toaster oven's door stop closing easily. After reading the internet and trying to contact Cuisinart for a solution I was stumped and frustrated. Someone on the internet mentioned using wd-40, but I didn't want the smell when I toasted! I try cleaning the metal arm that held the glass door using an alcohol pad and that actually helped a little! After thinking about something to lubricate the door are with that won't smell awful and hopefully won't catch fire -- I decided to try olive oil! I took a little, very little on a paper towel and rubbed the metal arm a few times -- It worked!!!!!!! The Door now closes with the greatest of ease! and doesn't smell awful when you toast, so far it has not caught fire. Give it a try! I love to give it 4 starts, but Cuisinart support didn't have a solution... I'm sure even if I suggest to them my fix that won't share the info, but use at your risk! I am certainly not responsible for any mishaps that may occur if try my fix, but worked for me.
Dec 31, 2010 | Cuisinart TOB-50 Toaster Oven with...
Door won't shut
another faulty door catch by the sonunds of it..!
Feb 26, 2010 | Toaster Ovens
Toaster Oven Repair
Toaster switch does not stay down. I have to hold the switch down to get toast. The heating element works fine as does the oven. Can we fix the switch? Or, do you know someone to whom we can send it for repair? Thanks!
Sheila Newton
Winston-Salem, NC
Aug 16, 2008 | Toaster Ovens
Toaster oven
THERE IS A SAFETY MECHANISM ATTACHED TO THE DOOR THAT TURNS OFF THE OVEN WHEN YOU OPEN THE DOOR. INSIDE, BEHIND THE KNOBS THERE IS A SPRING THAT ATTACHES TO A WIRE THAT IS CONNECTED TO THE DOOR. WHEN THE DOOR OPENS THE WIRE RELEASES THE SAFETY MECHANISM AND THE OVEN SHUTS OFF. WHEN CLOSED THE WIRE PUSHES AGAINST THE MECHANISM AND THE OVEN WORKS. I WAS ABLE TO FIGURE OUT HOW TO RECONNECT THIS FEATURE SO THAT THE OVEN WOULD WORK.
Feb 24, 2008 | Black & Decker TRO210 Toaster Oven with...
Door will not close shut
I have one in from of me, but it has no troubleshooting section.
Dec 26, 2007 | DeLonghi EO1258 - Stainless Steel Toaster...
Oster 6260 1500 Watts Toaster Oven with Convection Cooking Logo
459 people viewed this question
Top Oster Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Craig Butler
Craig Butler
john h
Are you an Oster Toaster Oven Expert? Answer questions, earn points and help others
