Question about Lincoln Conveyor Oven - 1133-000-A
We just replaced the ignighter on our linclon impinger model 116. Question: Should the burner be starting and stopping without any drop in temperature and would this be causing the ignighter to fail? Thanks
    Problem Solver:
  • 7 Answers
There is a low and high flame ignightor only should heat up only on first startup when turned on.
Posted on Dec 02, 2009
Convert LP Lincoln oven Impinger II series 1700 to natural gas series 1600
Yes. You need a set of natural gas orifices to replace the LP ones on the oven and all the burners too.
Jan 28, 2014 | Ovens
Once rich the temperature the flame is stinguish and then do the same thing
Yes thats a normal oparation for the oven. once the set temparature is reached the main burner flame goes on and off to regulate and maintain the set temparature
Sep 11, 2013 | Lincoln Impinger 1116 Gas Oven
Can you converta lincoln impinger from natural gas to propane
Yes you need to go to your gas company and ask them to convert it to LP use they will change burner orfis hrom Natural use to LP use.
Jan 06, 2012 | Lincoln Conveyor Oven - 1133-000-A
The pre heat is taking a long time over 30 minutes
SOUNDS LIKE THE IGNIGHTER IS GOING BAD, OR GLOW ROD. OPEN THE BOTTOM DRAWER AND WATCH THE AND SEE WHEN YOU TURN THE OVEN ON HOW LONG DOES IT TAKE TO GLOW BRIGHT, THE GAS BURNER WILL NOT START IF IT DOSNT GET A READING FROM THE GLOW PLUG
Dec 24, 2010 | Ovens
I have a GE Spectra XL44, model #JGBP40BEC4WH gas oven. The 4 burners on top work but the oven will not. I replaced the oven safety valve (dual type 1), thinking that it was stuck and not directing gas to...
Most likely, you're oven igniter is not getting hot enough to open the gas valve to ignite the burner. It glows like normal, but does not reach the temperature required to open the gas valve. Replace the igniter. Before you replace that, make sure that the small shutoff lever on the appliance regulator was not accidentally closed, which would turn off the gas to the oven, while still allowing gas to the stovetop. The silver lever should be sticking straight out or up. Douglas
Sep 12, 2010 | GE JGRP17 Gas Single Oven
Viking gas stove operators manual....I was working on my stove ...it was not lighting up....the stove......and I noticed that there was 2 burners...and when I replaced one of the ignighters and tryed the...
The way it works is the igniter gets voltage signal from the control and will start to glow. The gas valve for the burner and the igniter are wired on the same circuit. When the igniter starts to glow it takes all the voltage from the circuit. As the igniter increases in temp the resistence changes and the voltage starts to travel to the gas valve. Once the gas valve registers 3 to 4 volts it will open allowing gas to the burner for ignition. The igniter needs to reach approx 2200 degrees for this to happen. So it could be the igniter or the gas valve. The igniter should test approx 500 to 700 ohms with a ohm meter. The gas valve could also be sticking. If the igniter is glowing bright and you tap the gas valve with a wrench and it comes on then the gas valve is sticking and needs replacement(as long as the igniter tests good)...Hope that helps.
Oct 11, 2009 | Viking Ovens
The top burners do not light?
your ignighters are not working,,,you need to have it serviced for them to work again..the ignighters are what start the heat process.
Jan 08, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven repair
just because it glowes dont mean its up to par try changing the ignighter it can be weak
Oct 27, 2008 | Ovens
Phantom ticking
wait about three days to see if it stops this is typical when you clean one this way as water can get in the ignighter switches if not you have to replace the switches which are on the knob shaft behind the panel and come in sets of four and its not hard
Jun 20, 2008 | Ovens
Lincoln Conveyor Oven - 1133-000-A Logo
130 people viewed this question
Top Lincoln Ovens Experts
Dan Webster
Dan Webster
jasbo
jasbo
Colin Stickland
Colin Stickland
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
