Question about Samsung CLP-510 Laser Printer
Says transfer belt and imagining unit are bad. Still working. Are these things I can replace or are these warnings early just to get me to buy parts?
    Guru:
  • 1,049 Answers
Transfer belt is not an essential replace. But a bad imaging unit may cause heating issues, lost toner to fill your printer with dust interfering with sensors, and a slew of other issues left unchecked. That said, you could run for a while before either became a serious threat.
It's a lot like running your car without oil...you can do it, but when it goes it will be gone!
Posted on Nov 13, 2009
Fuser unit
can you explain more the functions of each are as followed fuser melts the toner to the paper so it dosnt rub off ozone filter filters out the ozone so you don't get headaches and turn al the rollers to bubble gum transfer roller pushes the paper onto the transfer belt applying the image to the paper and imagine unit is where thetransfer belt gets the image from
Aug 16, 2014 | Konica Minolta bizhub Office Equipment &...
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
My printer can`t print and shows me to 'Check the transfer belt'
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
Nov 26, 2012 | Samsung CLP-610 Series
HI HAVE SHARP MX 3501N COPIER , TORE TRANSFER BELT
You really dont want to do this. It is tricky. The new belt can be pinched and ruined extremely easily, and you are required to apply it with a special lubricant. In case you really want to, The supply item is MX-4501Y1. That is just the belt. There is another kit for the transfer rollers inside. If you want to buy. $150 email me.
Remember, kit wont work without lubricant
just4fixya@gmail.com
Feb 27, 2010 | Sharp MX-3501N All-In-One Printer
Worn transfer unit
The printer is giving you early warning to buy a new Transfer Unit, which on many other printers takes the 4 seperate colours from each toner, building the full graphic page before transferring the complete page onto the drum unit prior to applying it to the paper. My info on this model does not show a transfer unit being available. Perhaps the mean the drum unit? Your printer manual should tell you, or simply contact your countrys Epson centre.
Cheers
De Judge
Sep 15, 2009 | Epson AcuLaser 2600N Printer
I'm getting a message about "transfer belt life warning" on a LEXMARK C522. I thought this should have done loads more copies before it needed replacing.
What is new to you might not be so new. Sometimes these things can sit on a shelf for months and you buy it not knowing how long it has been there in that store. Being that the belt is possible plastic it wears even if its not being used then it gets old and cracks now you have to have it replaced. Your best bet is to always check to see how long the equipment have been sitting on the shelf before you buy it.
Jun 02, 2009 | Lexmark C522n Laser Printer
Hp 2600 n
OK. This sounds like a bad transfer belt. Does this printer have a lot of use? Do you think you have like 75,000-100,000 copies on it? If so it is very likely.
If you are SURE the fading is on ALL cartridges, then it has to be the transfer belt assembly. (that wide film part on the inside of the front door). You can buy this part, and instructions to replace it are very straightforward. Its not just the film you replace, its a module.
One last hing, if it is only happening on ONE cartridge, then all you have is a bad cartridge. All 4 = transfer belt.
Apr 20, 2008 | HP Color LaserJet 2600n Printer
ImageRunner c3200 Color Registraton
With my experience, it's not the registration nor calibration problem, it's either transfer belt is bad or inside the transfer belt is dirty or dusty as well as transfer rollers. here is what I do first
take the transfer belt unit out of the machine, take transfer belt out from the unit, clean inside of transfer belt with damp cloth and rubbing alch. clean all rollers and reinstall.
What it is if the transfer belt and transfer rollers are dirty and dusty, it slips and make it like it's not align. I think most of time it fix the problem with my exp. if not replace new transfer belt
Jan 15, 2008 | Canon imageRUNNER C3200 Copier
Samsung CLP-510 Laser Printer Logo
245 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
