Question about Refrigerators
Whirlpool Designer Style Refridgerator Model # E8220KXFW01
Freezer is not cold. It is approximately 20 degrees F. Food that was previously frozen is remaining frozen with the exception of the Ice cream and ice packs stored in the door. Vents and returns are not blocked. I cleaned and dusted the exterior of the fridge and the interior of the freezer and I can hear the motor running. I can also feel cold air blowing into the freezer. Any ideas on what the problem may be?
  • tiredandpoor Jan 12, 2008
    I tried defrosting the fridge. I emptied it and shut it off for 24 hours. I then turned it back on and waited another 24 hours. The freezer now ranges from 30 degrees to 50 degrees according to the thermometer I put in the freezer. Any other suggestions?
  • tiredandpoor Jan 13, 2008
    - Thermostat is at the coldest setting
    - Location of unit is the same location as the last ten years (not hot and well ventilated)
    - Outlet is ok, same outlet as last ten years.
    Maybe refrigerant has leaked out, although the refrigerator section stays at the proper tempature. I guess it's time to call the "qualified technician" Thanks for your help.
Check the condensor coils in the base - probably choked full of dust and lint. RTFM!
Posted on Mar 31, 2009
  • 236 Answers
Maybe there some ice formation in the evaporator, try to defrost the unit.
Posted on Jan 09, 2008
  • Felizardo Erilla
    Felizardo Erilla Jan 12, 2008
    - Check the thermostat setting if it is manual it should be set at the cold and for digital setting it should be set at negative 18deg C or lower .
    - Check the location of the unit if will ventilated, hot location of the unit can effect the operation.
    - Check also the outlet of the unit ac outlet if not loose , loose outlet can cause the tripping of the compressor.
    If all of the above are ok then you need a qualified technician to check the unit. May your unit have leaking and all refrigerant escapes. Or the system is restricted, this works need a qualified technician.
Model EEV-163F Whirlpool Upright Freezer. Defrosted this week, already seeing ice buildup. Freezer is cold and appears to run fine, but frost buildup seems excessive this quickly. Frost throughout
This freezer is not frost free. Being an upright limiting the amount and frequency of opening the door will reduce the build up of ice. Ice is expected and depending on humidity and quality of seal around door affects the amount of ice.
Using a thin ribbon check the seal integrity around the door. Confirm nothing is prohibiting the full closure of the door.
Adjust door if necessary. Replace seal if defective. Freeze open unsealed items in a frost free freezer before locating frozen food in this unit.
These units are likely located in the garage where the humidity is high. If used only as needed planning transfer between this and the kitchen unit frost can be minimized.
Being a conventional freezer not frost free freezer burn is less likely and frozen food will not dry out as quickly. Confirm that the freezer maintains about 0 degree F.
This unit is likely more efficient and will maintain the food frozen longer in the event of power outage.
Hope this helps?
Jun 24, 2017 | Whirlpool Refrigerators
Ge refer model psc25mstass fresh food section not cold enough freezer cooling fine
I realize this is an old post but information is always helpful if it is correct. I have a GE Model TFX22ZRB, Main tools needed are a refridgerator thermometer, a cheap multimeter, 1/4" hex driver, phillip screwdriver and regular blade scewdriver, above all, alow time for tempeture change when measuring tempeture. The freezer is running at -8 degrees C or aproximately 28 degrees F. I don't care about 1 or 2 degrees at this point in the freezer, the defrost system is working ok, The freezer is cold enough. The fresh food section is running at 48 degrees F, the damper is wide open between the freezer and cold food section, I manually removed the damper door and controls since I am only interested in seeing if I can drive the fresh food section colder. Looks like the fresh food thermostate controls the compressor and not the damper to shut off the cooling process when the tempeture gets cold enough. Since the fresh food section does not get cold enough (this should be in the uppers 30s F) there is no need to move the fresh food thermostate out of the normal range setting (mid point in my case) with the operator control. Defrost heaters ok, this unit uses 2 heaters hooked in series with a evaporator coil thermostate also in series with the heaters. Heaters aproximately 25 ohms total risistance, coil thermostate open at room temp and closed when below 32 degrees. Only other item in circuit is the defrost timer, this can be manually advance to open and close the defrost circuit, in my case, when in the defrost mode, the evaporator fan stops and the heaters heat up. The defrost timer in my case has a 12-16 hour cycle time and a 30 min defrost time, so in a 24 hour period I may get only one defrost cycle. One item of importance. make sure something has not fallen in the lower back or the fresh food section of the refridgerator to block the air flow return, this will effect the coo;ing process. Now with the damper wide open, the defrost circuit working ok I am going to look at the evaporator fan itself for speed, shifted blades or the air circulation between the freezer and the fresh food section, I have cleaned the condenser coils but I am leaving the condensor and compressor out of the equation since the freezer is cold enough but at this point I am considering the possibility, I may need to replace the fridge if the compressor is not working to par.
Jul 18, 2012 | Refrigerators
The freezer has an inch of ice frozen on the back inside the freezer but the refridgerator side does not get cold.
completly frozen up behind the panel.
must be completely defrosted.(not with ice pick)
defrost timer or heater may be bad.
call a repairman
he can do it in an hour or less, then fix the problem and you won't have to throw your food away
Jul 01, 2009 | Whirlpool GS5SHAXN Side by Side...
We just bought this house and the fridge that came with the house is a whirlpool designer style. The problem we are having is that it's leaking water all over inside the fridge and it's coming from the...
This is a common problem with old top mount refrigerators. The foam between the the two cavities starts to break down and sweat due to the differences in temperature between the two cavities. You can try emptying the unit, turning it off for a couple of days and leaving the doors open giving it a chance to dry out, if the condition returns after a short amount of time, then it is time for a new refrigerator, there is no cure for the breaking down of the Styrofoam inside the unit
Jun 16, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refridgerator temperature
I think it may be a defrost system problem. If you have frost on the back wall the problem is related to the defrost timer or defrost heaters or thermostat.
Also check the condenser for dust. If plugged with dust the system can not get rid of the heat. If dust is present clean it out completely.
Remove the toe plate under the refrigerator door to check the condenser.
May 24, 2008 | LG Refrigerators
Refrigerators Logo
2,162 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
