Question about Yamaha RX-V563 Receiver
Auto-setup failed with error e-5: check sur.
Auto-setup failed with error e-5: i have installed only 5 speakers not 7. I hope this is not the problem?
What can I do to solve this problem? I can't complete the auto setup. I always get this error.
Thanks...
5 Suggested Answers
SOURCE: no sound back two speakers
After using the method of last resort (RTFM) I discovered that Yamaha 7.1 amps assign an order of priority to the speakers. The surround speakers have higher priority than the surround-back speakers. I had connected the rear speakers (in a 5.1 configuration) to the surround-back speaker terminals and since nothing was connected to the surround terminals the E-6 error happed on auto-setup.
I eventually fixed this by connecting the rear speakers to the Surround L/R terminals and then, via the manual setup menu, set rear surround = NONE. This causes the amp to route the rear-surround signals to the Surround L/R terminals. The auto-configure then completed successfully.
Posted on Jun 30, 2008
SOURCE: Subwoofer won't work after Auto Setup
hi can you try this it might work, take off all the connections to your receiver and the reset your receiver to the original factory settings then turn it off and disconnect it from the socket. connect all the the speakers and turn on and start auto set up. hope it works
Posted on Feb 07, 2009
mlapres
  • 757 Answers
SOURCE: 6140 will not complete the AUTO SETUP
If you would like to bypass the auto setup which is apparently the root cause, use a test cd/dvd for your test tones. The auto setup while convenient is not the optimal way to get the best result as the test tones it uses are bandwidth limited pink noise. If you would like to use the auto calibrate however, it's likely needing repair to do so.
Posted on Dec 24, 2009
dunnbiker
  • 8546 Answers
SOURCE: e-6:sur sp on auto setup
Page 102 under troubleshooting: it thinks you have Surround Back speakers but NO Surround speakers. This would be an invalid configuration. Refers to page 13 for the remedy.
Posted on Jul 21, 2010
No sound from speakers
1. Make sure the speaker power is ON.
2. Need to check the Audio IN/OUT at the back of the PC.
3. If there's a way to test the speakers to other computers or even a laptop to check if speakers might be faulty.
4. Try a different speaker to the computer.
5. If this fails then check the configuration of Audio from the control panel.
6. Make sure the settings are correct.
7. If all settings are correct and you tried already a different speaker this means that the audio card is faulty. If the audio is integrated to the motherboard then it needs replacement.
8. Replacing motherboard is expensive, I rather suggest installing an audio card to the motherboard would be the easiest way.
Hope this helps.
var geo_Partner = 'f6f528bb-844d-4751-bb3f-a2a99775d943'; var geo_isCG = true;
Sep 24, 2011 | Computers & Internet
Tip
How to Install any Driver/Software which isn't Supported by Windows Vista/7
Hello!!
There are lots of old Soft-wares and Drivers available which are not compatible with Higher Version of Windwos.
So some Windows XP exclusive setups can be installed under Windows Vista/7 As Under.
1. Try to install the drivers in compatibility mode.
2. For that right click on setup.
3. Go to properties.
4. Go to compatibility Tab.
5. Set it to win xp sp2.
6. Hit ok
7. Run setup as administrator
8. Ignore any error and hit continue anyway during installation
9. Restart pc
If the above trick doesn't work, then use the device in VIRTUAL XP MACHINE
You can use XP MODE or VMWARE or any other Virtal Machine Application.
Hope it Helps..!!
on Jul 13, 2011 | Computers & Internet
E-6:sur sp on auto setup What does it mean?
Jul 17, 2010 | Yamaha RX-V661 Receiver
Adobe Flash Player ActiveX Setup failed to install
use mozila firefox then download he latest version from internet. just go to www. google.com and in here just type what do you want.
Apr 08, 2010 | Computers & Internet
Cant install windows 7? i put the cd in and go to auto boot but it gives me a code 5 error.
To resolve Windows 7 Error Code 5, all you need to do is start the installer through a different installer. Either find an old Windows XP boot disk and then direct it over to the Windows 7 installation DVD and run Setup.exe. This should kick off the installer normally and allow you to install the operating system.
Jan 10, 2010 | Asrock K7VM3 Motherboard
Dec 23, 2009 | Yamaha HTR-6140 Receiver
I had seven speakers hooked up and went to a 5
check all your speakers and wiring. remove any unused cables from receiver. use the setup mic and it will do the rest
Dec 07, 2009 | Pioneer VSX-815-K Receiver
WHAT speaker distace & delay .sitting and Db in my AVR AS MY ROOM SIZE
Hello, if you have the speaker set up microphone I suggest that you use it to calibrate the speakers and it will set the distance and delay. Thank you, Onkyo USA
Mar 02, 2017 | Onkyo TX-SR605 Receiver
No sound back two speakers
May 18, 2008 | Yamaha RX-V661 Receiver
Error (E7)during auto set up
An internal system error occurred.
Repeat the AUTO SETUP procedure
Aug 30, 2007 | Yamaha YSP1000 Main / Stereo Speaker
Yamaha RX-V563 Receiver Logo
113 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
