Question about Samsung SGH-D900 Cellular Phone
Phone keeps going through start up but dosent stay on
Alternators not charging the battery. vehical starts and runs but battery light stays on and the voltage guage keeps dropping any ideas????
It sounds like you have just about answering your own question...Replace the alternator if it is not charging.
Feb 27, 2011 | 1998 Ford Explorer
I keep rerecording the out going message for the system and it dosent change how do I get the message to take and why does it keep asking for a selector code
Selector codes are the codes that tell the system to do a certain task then that digit is pressed(press 1 for bob, 2 for nancy). If your not changing any of the digits, press *# to get to the part to record the main greeting. Press 1 to start and 1 to finish. Make sure that you press # to save the recording or it will use the old recording.
Jun 23, 2010 | Avaya Lucent Partner 616 Phone
Coldstart/1997gmcjimmy.won't start in morning without starting fluid.once started,will start all day.
Check the fuel pressure in the morning when you are trying to get it started. Do not use the starting fluid when doing this. With the key turned to the run position the pressure should go up to 55 - 60 psi and stay there. If it dosent go up or it drops quickly the fuel pump is bad.
Nov 05, 2009 | 1997 GMC Jimmy
LGKF600 will not charge or turn On
This is currently happening to me too.
When this sign comes up you may need to hold the charger in place for the kf 600 sign to stay up. The longer it stays up it will then show the charging sign after this.
Best thing to do when you see this is just to keep the charger in leave it for about 10mins and then try turning on. You probaly have a fault with your charger.
Jan 06, 2009 | LG KF600 3MP InteractPad Triband Phone...
DRL PROBLEM
check fuses, check wiring.
Oct 24, 2008 | 1994 Honda Accord
Samsung SGH-D900 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
